Old Nov 26, 2012, 08:14 AM
jw357_23043 is offline
Find More Posts by jw357_23043
Shut up and Fly!!!
jw357_23043's Avatar
United States, VA, Hartfield
Joined Aug 2011
Originally Posted by C_Watkins View Post
Good luck.
After an embarrasing showing at a contest, I really worked on KE spins on all my planes this summer and hit them about 90% of the time now
I've found that most of my planes will go in at considerably less than full throttle, and that they wind up faster if I relax the rudder once they lock in.
Yeah, I had my son for the holidays and decided to show off for him with the MXS. Regardless of the failed attempt he was still impressed with rolling circles, harriers etc.
jw357_23043 is offline Find More Posts by jw357_23043
Old Nov 26, 2012, 02:12 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Originally Posted by jw357_23043 View Post
Yesterday I took my MXS out and tried to do a knife edge spin and it wanted to flatten out. My entry works with other planes but not this bird. I stall and drop either to the left or right with full down elevator along with rudder input. Any suggestions??
Do you have the racing wing tips on? Try taking them off, but keeping the SFGs on. I get KE spins pretty easy this way.
Also, somebody else taught me a way to get into KE spins...at apex, wing over with full rudder, keep going, and as you pass nose down, add your elevator. I don't do it this way, but it was a good way to learn for me.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Nov 26, 2012, 02:27 PM
Shut up and Fly!!!
Joined Aug 2011
I took the tips off as I wanted a faster roll rate so yes the tips are off for now. I will try that next time I'm out. Thanks.
Old Nov 26, 2012, 06:26 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
I have found that the entry into the ke spin with the MXS is the key. Once you get past the entry it generally locks in pretty good. For me it seems like a little less rudder and rolling on the throttle up to a little over half throttle gets it most of the time. WOT doesn't work well for me and half or even less once it's locked in makes it spin like crazy. Since switching over to a 14x7 prop the ke spins are much easier for me as well.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Nov 27, 2012, 08:41 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
entries are easiest for me this way
upline, stall upline and full down elevator+some left aileron, as it starts to spin down add full right rudder.
If you run full speed brake elevator with an 85mg you will be blown away and the rate of of rotation.
stgdz is offline Find More Posts by stgdz
Old Dec 06, 2012, 06:10 PM
GPT is offline
GPT
Find More Posts by GPT
GPT
GPT's Avatar
Sydney,Australia
Joined Dec 2004
After a few Edges I finally decided to try one of these. Another winner from EF again
GPT is offline Find More Posts by GPT
Old Dec 06, 2012, 06:29 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
right rudder?
Manta1 is offline Find More Posts by Manta1
Old Dec 06, 2012, 09:46 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Originally Posted by Manta1 View Post
right rudder?
The brain doesnt know the inputs. My fingers sure do though though and yeah manta im wrong there.
Old Dec 08, 2012, 05:52 AM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I was thinking next time I was out flying id try right and see what happened! im all for correction as I think Ive gotten as good as I can get as a pilot. Seem to have plateu'd. May be age/time to fly/ who knows but im ok with it.
Old Dec 08, 2012, 07:48 AM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Try doing 3/4 to full speed horizontal line into ke spin. I'm really close to getting it but you have to roll into it and the apply keep inputs.
Old Dec 08, 2012, 07:54 AM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
ya thats a violent,frame stressing,crowd wowing move right there for sure
Old Dec 09, 2012, 01:05 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
I half expect the airframe to explode in the air someday
not yet though
Old Dec 09, 2012, 03:34 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
That's something I'm wondering about...imagine a 78" or 91" MXS. I know there is video somewhere of a 78" MXS, but still, hard to imagine the g-forces this plane can pull being scaled to a 78 or 91.
Old Dec 09, 2012, 06:19 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
I trust in chris.
Old Dec 09, 2012, 07:52 PM
Motojunk is offline
Find More Posts by Motojunk
Fly it 'till it breaks.
Motojunk's Avatar
Joined May 2011
I've been doing this a lot lately with my Edge. At full throttle I get 3 solid end-over-end rotations before running out of momentum and exiting in a rolling harrier. So much fun!
Motojunk is offline Find More Posts by Motojunk
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
