Old Nov 10, 2012, 05:49 PM
jw357_23043 is offline
Find More Posts by jw357_23043
Shut up and Fly!!!
jw357_23043's Avatar
United States, VA, Hartfield
Joined Aug 2011
Originally Posted by Space Bat View Post
The red, white,and blue, scheme MXS is so much harder to pick (know orientation) in a clouded sky than the red, white and blue Edge....but is great in blue skies...which for the UK isn't exactly as frequent as would like - surprising the blue Extra is far easiest to see and pick in blue or clouded sky...
Also-
Am I the only one running high kV motor on EF planes....1130kV swinging a 12x7 on a 3s setup is sweet...
Do you have any video's of that plane on 3s? I'd like to see that as all I have is 3s packs. Not sure if I want to go down or up in kv.
jw357_23043 is offline Find More Posts by jw357_23043
Old Nov 10, 2012, 06:01 PM
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
I will try and get some....my son has had a couple of stabs of filming me flying- but he can't use a camera to save his life
Will see if one of my flying buddies is any better..
Space Bat is offline Find More Posts by Space Bat
Old Nov 10, 2012, 07:03 PM
Shut up and Fly!!!
Joined Aug 2011
Sounds good! PM me when you post so I'll know.
Old Nov 16, 2012, 03:39 PM
Skeletool is offline
Find More Posts by Skeletool
Skeletool's Avatar
United States, WA, Camas
Joined May 2009
Anyone know if the landing gear from the 64" MXS will fit on the 48" MXS?
I know, strange question, but I'd like some more prop clearance.
Skeletool is offline Find More Posts by Skeletool
Old Nov 16, 2012, 03:45 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Nope
14" props work
stgdz is offline Find More Posts by stgdz
Old Nov 16, 2012, 03:52 PM
ryan_m is online now
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
I stuffed the landing gear from a 60" Edge into a 3dhs 51" Slick, though I had to dremel about 2mm off so that it would fit into the landing gear channel. The 3dhs 51" Slick landing gear is perpetually sold out, and I had a gear from the 60" Edge laying there... so I made it work. Much stronger 51" Slick gear now!
It would take a lot more dremeling to make them fit into a 48" plane though. The landing gear channel is much narrower.
ryan_m is online now Find More Posts by ryan_m
Old Nov 16, 2012, 03:55 PM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
I have the 46" vyper gear on my mxs. it's a touch taller and stronger.
Irg is offline Find More Posts by Irg
Old Nov 16, 2012, 04:06 PM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
guys, how do i clean control horn slot after epoxy and/or gorilla glue?
for second time i had my rudder horn rip out on me...
and yes, first time i didnt sandpaper it, but second time i did.. second time i didnt clean out the slot....
rimaarts is offline Find More Posts by rimaarts
Old Nov 16, 2012, 05:43 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Are you using gorilla glue or epoxy? I haven't had any problems with epoxy (20 and 30 minute). While I have always roughed up the surface, I haven't always cleaned the dust afterwards.
I usually put some epoxy in the slot, then on the horn/base, then insert.
Which surface(s) are you having trouble with?
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Nov 17, 2012, 02:26 AM
rimaarts is offline
Joined Jul 2011
so far rudder only... but as im just about to finish my 51 slick, and around christmas ill be getting 60 exp,im just thinking to swap airframe next year...
first time i didnt roughen the horn, it came out recently, now i roughened the horn, didnt clean the slot and gorilla glued it, and in 3 flights it came out...im kinda afraid to try it 3rd time, both times it was hard not to trash the plane... much harder than when the aeleron goes lol...
Old Nov 17, 2012, 07:32 AM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
Try drilling 3 or 4 1/16" holes thru the bottom of the horn, then use epoxy to glue it in place. That should hold it.
Chuck
Chuck is offline Find More Posts by Chuck
Old Nov 17, 2012, 09:45 AM
Irg is offline
Irg
Irg
Irg's Avatar
Joined Apr 2009
mxs number 2, rip.
Old Nov 17, 2012, 09:57 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
oh no. sorry
Manta1 is offline Find More Posts by Manta1
Old Nov 17, 2012, 10:01 AM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Looks like the rudder made it!
I'm guessing cart wheel.
Old Nov 17, 2012, 10:05 AM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Doc Austin is online now Find More Posts by Doc Austin
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
