Old Oct 12, 2012, 06:29 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Originally Posted by Doc Austin View Post
You're right.
Thanks!
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Oct 12, 2012, 07:16 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I wouldn't use a 0255 on the elevator based on one failing in my "don't care if I crash" plane.
Sample of 1, but there you go.
The hitecs are better. Get an HS5085mg if you want digital. We've been using the 85s and 5085s without incident.
As for the 672 arms, you can reuse them on other planes later. But I do wish they were on the order of $5.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Oct 12, 2012, 09:04 PM
propchief is online now
Find More Posts by propchief
JKasprak
propchief's Avatar
Fayetteville, NC 28304
Joined Jan 2010
Originally Posted by Madness_3d View Post
Difficult to get hold of them at a good price in the UK. Looking at the equivalent of $20 just for the horns :-/ I've been fine with the throw I was getting from the included fibre extension with the kit, I'll probably just use that again :P
Find somebody that flies GS and uses 5955 or 7955 servos and see if they any arms they would part with. These will fit the HS85s and give extra arm length and strength.
propchief is online now Find More Posts by propchief
Old Oct 13, 2012, 02:02 PM
Madness_3d is offline
Find More Posts by Madness_3d
Madness_3d's Avatar
Joined May 2012
Ordered a new one
+ A new 12 x 6
+ A new HS 85MG
+ A 3x Turnigy 2200 4S 30C LiPo's
Don't know anyone using Hitec on GS Stuff, mainly Futaba and Savox. Gonna start with the Fibre horn and see how that goes
Madness_3d is offline Find More Posts by Madness_3d
Old Oct 13, 2012, 02:25 PM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
That ought to give you right around 76 degrees or so of elevator, which on the MXS is fine. It's got a short moment and a big elevator, so pitch authority is going to be really good even like that. I've flown mine with 45 degrees befoire and it is really sweet and elevator response is still really good. I'm not even sure the extra 12 degrees I get makes any difference, but it does freak people out, which is always fun.
Doc Austin is offline Find More Posts by Doc Austin
Old Oct 13, 2012, 04:49 PM
Madness_3d's Avatar
Joined May 2012
To be honest the 76 degrees seemed to evoke the desired response from most people that saw it on my last MXS
Old Oct 13, 2012, 04:51 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
People simply can't believe it. When I tell them how easy these planes were to fly they don't believe that either.
Man, it's been a long time since we made an MXS video. I've been tied up with the 60" Extra, the new Laser and the 64" MXS, not to mention that I never let anything keep me from getting enough time on my 48" Extras, even if I don't get to fly planes like the MXS as much as i would like.
I'll try to shoot some more MXS video soon, but hopefully this one will be entertaining for now.........
Old Oct 14, 2012, 03:32 AM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
talk about planes having a souls! swapped servo for my mxs... all the last month i was eyeing 48" laser....i even glued on wingtips(couldnt tighen screws enoug)... went out today... and guess what? perfect!
went home scratching my head, guess mxs felt i want to retire it and decided to fly nice for me!
now i m thinking of pulling out gear from a 48"foamy extra for laser...
rimaarts is offline Find More Posts by rimaarts
Old Oct 14, 2012, 07:34 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
So my crashed MXS I've got flying better but....
It falls forward in hover and climbs on inverted slightly. I've got the 5s pack about an inch away from the tube. I've debated about pushing them father back as the last time I did it the plane became incredibly pitch sensitive.
The laser stays in a hover easier
stgdz is offline Find More Posts by stgdz
Old Oct 14, 2012, 08:02 PM
JKasprak
propchief's Avatar
Joined Jan 2010
Sounds slightly tail heavy to me. The slight down elevator needed to keep the tail up in level flight would cause it to climb while inverted and pitch forward when in a hover. Try moving the pack slightly forward and check it.
Old Oct 14, 2012, 10:38 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Dude....finally ahaha. Glad you got it flying to your liking
Did you damage the motor box when you crashed it? If you accidentally added more down thrust that would explain it but you would also have a hard time getting it trimmed for level flight at various speeds.
hone1er is offline Find More Posts by hone1er
Old Oct 15, 2012, 08:57 AM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Yeah the box got teamed but I think I've gotten the thrust line sorted outwith all of the testing i have done.
Old Oct 15, 2012, 01:10 PM
Stark is offline
Find More Posts by Stark
Don't worry be happy :)
Stark's Avatar
Joined Sep 2001
According to my experience is this an indication that the plane is tail heavy, move the battery pack forward.
Stark is offline Find More Posts by Stark
Old Oct 18, 2012, 10:34 AM
hanzipv is offline
Find More Posts by hanzipv
hanzipv's Avatar
Czech Republic, Olomouc, Prostejov
Joined May 2012
HI !
have HACKER A 30 14 L,Sport BEC,ESC AEOLIAN 45A SW.
I want a slower flying.used propeller 13/4 or 13/5 ?
Li pol Turnigy 4S 2200 30C.
hanzipv is offline Find More Posts by hanzipv
Old Oct 19, 2012, 01:12 PM
rimaarts is offline
Joined Jul 2011
if you want slow-er, go less pitch, so 13x4 is my guess.... but if you want slow, you got the wrong plane! msx HATES slow or not enough power...
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
