Old Oct 10, 2012, 06:15 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Originally Posted by hanzipv View Post
MXS Sergey - Rusian Flag,MXS My- US Flag
Hey, we appreciate the support.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Oct 12, 2012, 03:39 PM
Madness_3d is offline
Find More Posts by Madness_3d
Madness_3d's Avatar
Joined May 2012
So bad times.
Not sure what happened really. Had the plane for over a year and apart from some dodgy Savox (non metal gear) servos I was sold, Plane hasn't missed a beat. Today I just pulled up and for some reason lost power completely. No Engine, No Radio. Went straight down into the ground. Held the last radio position like the battery had been pulled. When I checked it afterwards the 4mm gold had detached itself from the battery, but was also not in the esc connector, it was just loose on the ground. Also the Elevator servo's gears are stripped, servo sometimes works but now sometimes jams.
Think I'm gonna buy a replacement Airframe next week and maybe get a friend of mine (an electronic engineer) to resolder all my batteries. Love the airframe tons, the sad thing was that it was the first flight where I'd had everything perfect. Got the rates just right, and the COG just right for hands off inverted.
Going to put the Savox SH-0255's back in the Ailerons and Rudder, and Put something bigger on the elevator, thinking something Hitec?
So what's the best Elevator servo for a 48" MXS?
Madness_3d is offline Find More Posts by Madness_3d
Old Oct 12, 2012, 03:48 PM
propchief is offline
Find More Posts by propchief
JKasprak
propchief's Avatar
Fayetteville, NC 28304
Joined Jan 2010
I think the HS-85MG is pretty much the standard for Hitec. That's what I've got in mine and it does the job.
BTW - sorry to hear about the crash.
propchief is offline Find More Posts by propchief
Old Oct 12, 2012, 04:11 PM
Madness_3d's Avatar
Joined May 2012
Cheers, and what about a 5245MG? the Hole is big enough for it, it's only a few grams heavier and it's higher rated?
Or a HS225MG?
Old Oct 12, 2012, 04:14 PM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
HS85MG works fine. I've got hundreds and hundreds of flights on multiple MXS' with that servo and no issues at all.
Doc Austin is offline Find More Posts by Doc Austin
Old Oct 12, 2012, 04:17 PM
Madness_3d's Avatar
Joined May 2012
Thought I'd chuck up the photos my friend took from the last flights
Old Oct 12, 2012, 04:18 PM
Madness_3d's Avatar
Joined May 2012
HS-85MG It is then
Old Oct 12, 2012, 04:26 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Originally Posted by Madness_3d View Post
HS-85MG It is then
Use the dubro heavy duty arm and you can get 88 degrees of elevator! Make sure you are running the servos on 6 volts and the pitch authority is astounding.
Old Oct 12, 2012, 04:48 PM
Madness_3d's Avatar
Joined May 2012
Linky to the DuBro? and need to check what the voltage is set to on the ESC. Also is it worth using a seperate BEC? I saw a few pages back someone using a 10A Castle Bec?
Many Thanks
Old Oct 12, 2012, 04:57 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I believe thisd is it, and they have a decent price on them too. I would look on the pack to be sure, but I don't have one on hand. Call them to be sure, but it says they are for Hi Tec.
http://www.hobbylinc.com/htm/dub/dub...source=froogle
Old Oct 12, 2012, 05:11 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Yep, the 672...but will only work on the 85MG and 5085MG (and other big servos) not the hS65/5065mgs.
P.S. Don't buy the hobbyking versions, they are sloppy. (But if you like sloppy, I could send you the hobbyking ones I bought).
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Oct 12, 2012, 05:14 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Originally Posted by LoneWolfRC View Post
But if you like sloppy.....
And who doesn't?
Old Oct 12, 2012, 06:22 PM
Madness_3d's Avatar
Joined May 2012
Difficult to get hold of them at a good price in the UK. Looking at the equivalent of $20 just for the horns :-/ I've been fine with the throw I was getting from the included fibre extension with the kit, I'll probably just use that again :P
Old Oct 12, 2012, 06:23 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Question. A friend of mine is getting one of these or has one but hasn't built it yet or something and he's trying to decide on servos. He likes the Savox SH-0255MG, but it's too small for the elevator servo hole. I think there's a piece of wood that comes with the ARF that is made to be glued into the servo hole in case you want to use the Hitec HS-65MG, but I'm not 100% sure. Am I right in thinking there's a piece that comes with the kit, or am I dreaming? Has anyone done an un-boxing video on this thing? I'm going to search youtube once I hit submit, but thanks in advance for your answers
--Tom K.
P.S. I just searched youtube.. No joy.
Tom K. is offline Find More Posts by Tom K.
Old Oct 12, 2012, 06:24 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
You're right.
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
