Old Sep 22, 2012, 11:57 AM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
Originally Posted by stgdz View Post
less rudder
as much people, as much suggestions... just full rudder, elevator, and play around with aelerons to find out how much you need.. since i maxed out ruder on my 42, there is no plane im not nailing 9 out of 10 ke entries and all my planes spins as long as i want with no need of moving sticks...
rimaarts is offline Find More Posts by rimaarts
Old Sep 22, 2012, 12:23 PM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
Its different on every plane. 42 slick your right, 48" ef extra is the same, PA ultimate was simply full down elevator with very slight rudder no ail., 60" ef extra is different depending on the servos mine is currently half rudder full down and little bit of ail, 48" laser is 3/4 rudder full down 1/3 ail.
I could keep going but every plane is different depending on rudder throw, elevator throw, CoG, ect. But everybody gets the general idea of control inputs you just have to play around with what works and understand what is causing the plane to do what.
shadow102 is offline Find More Posts by shadow102
Old Sep 22, 2012, 12:39 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
well on my 42 i swapped gear once when cheapy esc crapped out, flew great half year...
my 57, single motor box repair, going great soon to be year....
48" sc not a single repair...
1.5 buck huck, swapped motor box once in half year, than trashed in another half year...
msx? every time i go out something happens... guess that airframe just is not for me...
I've had both the MXS and the 42" slick. The MXS is far easier to fly and is less twitchy. That being said both are tuff as hell. Edge to the slick on carbon gear, but rest of plane the MXS takes it. Also put them both through hundreds of tough flights.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Sep 22, 2012, 01:30 PM
rimaarts is offline
Joined Jul 2011
42" - i had people telling me to reduce rudder throw but for me did the opposite...
pa ultimate, full rudder, full elevator does work, maybe not so violent...
dont have 60" extra, but 3dhs 57"SC, also full rudder and elevator...
actually i need to play with reducing rudder in ke... maybe it will make more violent... but you know, if it ain't broken, why bother fixing it?
p.p.s just maidened my second 42...(airframe i have most flights on) and all i can say is, msx does 10x more locked in ke flight, but the rest... well, i need new hinges to keep studying msx...
Old Sep 22, 2012, 01:36 PM
rimaarts is offline
Joined Jul 2011
twitch... depends from what plane you are comming... after i fly my micros, 42" seems soooooo nice and gentle... after a while of flying my big 57, 42" seems super twithcy...
but on the positive note, today was my battery nr 5 when i wasnt actually fighting the plane but just throwing it around... still, the airframe style is very new to me, but it gets easier... i REALLY enjoy how locked in it is on ke flight! did my first takeoff->ke circle around 10' off the ground(wich i would never do under tree line on my 3dhs planes lol) finally got harrier turns and harrier landings more or less sorted... and second thing i enjoy more than my 3dhs planes is elevator autority! my guess is that even if i put 80* elevator on my 42, it wont be so powerful!
but still, this is my bad luck airframe....
Old Sep 22, 2012, 02:28 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Originally Posted by Space Bat View Post
One thing I have learned on building these frames - is the stab is critical - I spend possibly 20mins being absolutely sure that it is spot on and that equal distance each side that the wing tube to corner is spot on both sides and that the elevator is perfectly level with a meter both sides....before I epoxy it in and guess the MXS it is more critical to get this right due to its pitch nature....
I don't have that experience, *BUT* I do now take my time putting in the horizontal stablizers as you describe. I know it doesn't hurt anything, and I guess it helps...I just don't *know* since my flying skills and building skills are both improving as time goes on. I should go fly a plane with a crooked horizontal stab once--then I'd know.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Sep 22, 2012, 03:48 PM
rimaarts is offline
Joined Jul 2011
on a side note, how you are getting wingtips on? lately im itching to try tips+sfg but cant figure how to get screws trough... >.<
Old Sep 22, 2012, 03:56 PM
Joined Oct 2011
They should be wood screws and not the machine screws like it says in the manual. SFG will greatly improve post stall performance on top of KE performance. Slight wing rock without, and none with SFG's.
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
I had a friend who had a MX2 can't remember the make - but it was a lovely 60" plane.....and when we flew together he had so much trouble putting it into a wall or hover and he didn't like the flight character of it......on closer inspection the stab was at a slight angle not a huge amount...possibly 2mm out where one side closer to the wing tube..and the stab was higher on one side than the other.....totally spoiled it for him and he became to hate it....and the way it just wasn't right....he wasn't too bothered when he clipped a tree and smacked it down to its death.....and we went to a show where he bought a EF 60 edge which he now flies and loves and is perfectly setup and he made sure the stab was perfect on the build....
Personally I have also come a cropper with me not getting a stab perfect...it really does make a plane wrong...and having to add trim to compensate does little to make it right - I ended up having to add some carbon fibre shims to straighten out the stab and make it level on both sides....this corrected things to where it was better....
Now when I throw a plane up for a maiden - I only require 1 or 2 clicks to to get the plane right - the EF planes do not require that much trim if correctly built they are that good of an airframe...
Space Bat is offline Find More Posts by Space Bat
Old Sep 22, 2012, 04:14 PM
rimaarts is offline
Joined Jul 2011
sfg, no problem, but wingtips?? how do you screw them on? how do you keep screw on screwdriver without falling off?
Old Sep 22, 2012, 04:20 PM
Team Hillbilly (UK)
Space Bat's Avatar
Joined Oct 2011
I slotted the holes so that I could put the screws in first and then slide the tips on and then I could tighten them up....It also made it easy to swap them on and off when you wanted...
Old Sep 22, 2012, 04:29 PM
C_Watkins is offline
Find More Posts by C_Watkins
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
Either use screws that fit tightly to the tool... or a bit of tape, putty, etc.
OR... tape the tip into place, and hold the wintip so you're looking up into the holes.
Then you can place the screw on the driver and have it stay in place while you push it up into place to get it started.
C_Watkins is offline Find More Posts by C_Watkins
Old Sep 22, 2012, 04:33 PM
rimaarts is offline
Joined Jul 2011
in 1 word, PITA... so guess ill keep flying without wingtips....
Old Sep 22, 2012, 09:05 PM
propchief is offline
Find More Posts by propchief
JKasprak
propchief's Avatar
Fayetteville, NC 28304
Joined Jan 2010
Get a screwdriver with a magnetic tip or use a cap screw to get the wing tip on.
propchief is offline Find More Posts by propchief
Old Sep 22, 2012, 09:13 PM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Put the rear screw in first but not all the way. Then put the front screw in but you will have to rotate the tip away from the the SFG. Once the screw is through the tip rotate the sfg out and push it through. Then comes the tricky part, you have rotate the combined two back with the screw barely out and put it into your hole that you made when mounting the SFG by itself.
Cause if you try to screw in both at the same time on fresh wood will result in nothing but swearing.
stgdz is offline Find More Posts by stgdz
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
