Old Sep 13, 2010, 10:00 AM
dava_2 is offline
Find More Posts by dava_2
Joined Sep 2010
Esky Lama v4 problem
Hi people,
I'm new on this forum.
I'm a beginner in R/C. I don't want to quit, I like it, so please help me with my problem.
Recently I bought Esky Lama v4. I had, let's say, a bit of crashes and falls with it. I broked landing skit, so you don't see it at video. Also, stabilizater is moved. Here is problem:
I turn on transmitter, jostic. Then connect battery to helichopter. Red light flashes on helichopter. And it dosen't stop. I got control of servo motors... Everything was working fine, this was suddenly.
Can anyone help me?
*please wait to video uploads*
*sorry for bad quality, hope you will get what's about*
dava_2 is offline Find More Posts by dava_2
Old Sep 13, 2010, 10:14 AM
borgqueenx is offline
Find More Posts by borgqueenx
Joined Sep 2010
Maby you can fix the landing skit with some good glue, else buy another landing skit set from xtreme productions, very good quality.
Are all trim functions reset to center and all sticks down or centered? If not try to do that, then connect. Also make sure the battery is charged. It sounds stopid but small mistakes are the most causes of problems.
I dont know what you mean with: stabilisator is moved...
Good luck!
borgqueenx is offline Find More Posts by borgqueenx
Old Sep 13, 2010, 10:36 AM
dava_2 is offline
Joined Sep 2010
Good luck!
I bought it, just need time to come to me.
Trim functions? You think on 4in1 controller?
Battery charged.
No problem.
I tought stabilizator: http://www.von-mart.com/images/helicopters/ek1-0314.jpg
Please check video:
http://www.youtube.com/user/davidmak.../0/0Yw8BJSOttg - MOV 0608
Thanks!
Old Sep 13, 2010, 11:05 AM
Joined Sep 2010
Battery charged.
No problem.
Please check video:
Thanks!
that video is really unclear and fuzzy
The remote/controller has trim sliders yes.
I dont know what is wrong with your stabilisator...what do you mean with "moved"?
Old Sep 13, 2010, 11:37 AM
dava_2 is offline
Joined Sep 2010
Sorry, can't do better.
They are on center, on pozition they should be.
Nothing, forget it, just mentioned to know why there isn't it on video.
Old Sep 13, 2010, 12:30 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Battery charged.
No problem.
Please check video:
Thanks!
All your trims should be centered EXCEPT the throttle trim. This should be all the way down. Another thing, don't move your heli while it is trying to intialize (some call it binding which is incorrect). You can lay it on it's side during this process. Just don't move it until you get a solid green light. You'll mess up the gyro if you move your heli.
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Sep 13, 2010, 12:58 PM
Joined Sep 2010
Mike.
everything that i say should be a good advice on this site. everything this guy tells you are facts, so obey :P
Old Sep 14, 2010, 05:05 AM
bladeskiller is offline
Find More Posts by bladeskiller
Athens
Joined Aug 2008
If with throttle stick and throttle trim down position the led still refuses to turn green, within a few seconds after connecting the battery, that meens the 4 in 1 unit does not receive the transmitter signal. If this happens after a crash and you have the 35MHZ version ,firstly check the RX crystal.
Kostas from Athens.
bladeskiller is offline Find More Posts by bladeskiller
Old Sep 14, 2010, 10:57 AM
dava_2 is offline
Joined Sep 2010
I removed cover, and just fit servos back to place(they were out) and now is working.
Thanks!
Discussion Esky Lama V4 vs. Big Lama rr9434 Coaxial Helicopters 3 Sep 11, 2010 02:01 PM
For Sale FS/T Walkera 5#6 Micro Heli + Esky Lama V4 both like new! Blind Aircraft - Electric - Helis (FS/W) 1 Sep 07, 2010 07:23 PM
Wanted Esky Lama V4 stock plastic body Captain Ron Aircraft - Electric - Helis (FS/W) 2 Aug 25, 2010 10:43 PM
Help! HELP Lama v3 Esky Problem! Sgt.Squirrel Coaxial Helicopters 6 Aug 12, 2010 06:27 AM
Discussion Esky Lama V4 counterclockwise rotation problem lb71fish Coaxial Helicopters 10 Oct 19, 2009 11:51 AM
