United States, FL, Altamonte Springs
Joined Jun 2008
I considered a quad/tri but don't know enough about them to build one myself. I do know how to fly a helicopter (even know how to hover inverted), so I figured with the fy20a it'll be even easier... Thanks for the info though
What doesn't make sense to me here, is why you'd make a point of mentioning
how expensive the wing was minus the FPV gear, and then even consider moving to a heli, which has to be quite a lot more expensive airframe than any wing, and just tipping the thing over on the ground with the blades spinning typically results in $100+ in repairs, and hours of fiddling with swash linkages and such. In other words, I think you're moving in the wrong direction. How about a nice reliable and proven, durable, easy to repair EZ* or EZG with lots inexpensive of ready-made FPV gear available for them? If you're REALLY determined to get into into FPV rotorcraft, then I agree with the suggestion above. Build a Tri. There's a proven design out there that you can build from scratch for less than $200 (that's everything, wood, motors, ESCs, gyros.. etc). I've cut a replacement arm for mine out of Poplar with a hand saw, and that's the hardest part. The frame is just plywood. ian |
Latest blog entry: My 2012 FPV year in Review
Shorter flights for the same battery capacity
Trickier landing FPV Harder to eliminate vibration MUCH more expensive to repair Glides like a brick ian |
So I would understand telling someone who has never flown helis before to start with a plane or a tri, but I still don't see the big difference between flying helis LOS and flying them FPV.
| Thread Tools | |
| Idea Digital FPV link, considering designing video/telem/OSD system, need input | FalconFour | Video Piloting (FPV/RPV) | 89 | Nov 21, 2011 05:34 PM |
| Discussion Some questions from a heli pilot considering fixed wing. | green_one | Modeling Science | 3 | Sep 13, 2009 02:59 AM |
| Discussion I lost my FPV Easystar | dadde | Video Piloting (FPV/RPV) | 93 | Jul 19, 2009 05:28 AM |
| Discussion I almost lost my FPV plane. | Tarro | Video Piloting (FPV/RPV) | 10 | May 01, 2009 06:39 AM |
