Old Sep 12, 2010, 05:01 PM
ken_nj is offline
Find More Posts by ken_nj
GSMB Member
ken_nj's Avatar
United States, NJ, Howell
Joined Mar 2008
Mini-HowTo
DIY - Vacuum forming
Have I have few things I need to make for my 1/24 scale boat that I have not been able to find online. Besides learning something, I also probably saved some money making them myself. The pictures should tell most of it. These first items I show here are floodlights that will getting super bright LED's. I started out with .010 plastic cut to 6"x6". Changed to .015 as it sturdier. It was trial and error for a while to correct two issues. One was webbing, the second was bubbles at the bottom of the pattern.
Other parts I will be making are trash cans and coolers. Not sure what else there will be.
ken_nj is offline Find More Posts by ken_nj
Old Sep 12, 2010, 05:23 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Wow, nice work.
freechip is offline Find More Posts by freechip
Old Sep 12, 2010, 05:53 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Brilliant!
Kmot is offline Find More Posts by Kmot
Old Sep 12, 2010, 06:17 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
1:24 scale....
I'll be your official tester.
green-boat is offline Find More Posts by green-boat
Old Sep 12, 2010, 06:23 PM
bgnome is offline
Find More Posts by bgnome
made of fire and pop rocks
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
bgnome is offline Find More Posts by bgnome
Old Sep 12, 2010, 07:03 PM
ken_nj is offline
GSMB Member
ken_nj's Avatar
Joined Mar 2008
Thanks guys! Here are 2 quick video's in action.
Vacuum forming, part I (0 min 19 sec)
Vacuum forming, part II (0 min 29 sec)
Old Sep 12, 2010, 09:25 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
What they all said.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Sep 12, 2010, 11:14 PM
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Twist the frame and pop them out like ice cubes.
Old Sep 13, 2010, 12:09 AM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
Trick I have used to fix the frames is when they get too loose wrap a layer of masking tape around the tongues of the corners (I have the same frames in my windows and the dogs go through them so I am an expert at replacing screens). I that does work you can take a nail and dent the frames into the corners slightly.
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Sep 13, 2010, 05:26 AM
rlboats2003 is offline
Find More Posts by rlboats2003
rlboats2003's Avatar
United States, NY, Buffalo
Joined Oct 2003
A great thread with some neat thinking
Well this is a definate copy for future review and file away into the technique folder
Great Job,
Rich
rlboats2003 is offline Find More Posts by rlboats2003
Old Sep 13, 2010, 01:18 PM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
Nice job.
GILL RC is offline Find More Posts by GILL RC
Old Sep 13, 2010, 01:22 PM
ironman1 is offline
Find More Posts by ironman1
The Sicilian Texan
ironman1's Avatar
USA, TX, Waco
Joined Mar 2010
ken nj, that is a super cool box. I am getting materials together now to build it. ironman1 (Ray)
ironman1 is offline Find More Posts by ironman1
Old Sep 13, 2010, 03:12 PM
ken_nj is offline
GSMB Member
ken_nj's Avatar
Joined Mar 2008
Building the box is simple. Cutting, assembly and gluing should take about 1-2 hours. The plywood frame has glued rabbit joints. The cross braces float in the 2 sides and the 4 dowels float in the cross braces. My MDF top (platen) and bottom right now have a tight fit into the rabbit joints so there is minimal air leakage. The top or bottom can be glued\siliconed or you can use masking tape to seal the joints. I suggest gluing\silicone the bottom and leave the top removable. This will allow you to have platens with different hole patterns.
If you can get the woven metal window screen, you really do not need all of those little holes. Just drill one large hole, maybe 1 to 1.5 inches in the center. When you place the screen over this large hole, the screen will allow the vacuum to distribute evenly under your pattern. Two layers of screen might be better.
If anyone needs any other info, just ask away.
For the window screen frames, some hardware stores might have metal corner braces, you might have to miter the corners. They would be better as the plastic, after repetitive use will deform due to the heat. You can do as Foo says, dent the frame to hold. Or build some sort of wood frame.
When you sandwich the frame with the plastic in the oven. Elevate the frame with two pieces of wood as the plastic will sag and you do not want it touching anything as it warms up.
Old Sep 14, 2010, 12:54 AM
desron48 is offline
Find More Posts by desron48
ADM. 48TH FLEET
oxnard ca.
Joined Jul 2007
thanks ken........gunna start constructing mine this weekend.....joe
desron48 is offline Find More Posts by desron48
Old Sep 14, 2010, 01:11 PM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
I pulled instructions for a vacform box similar to yours from the internet a few years ago, but never built one.
Yours appears to be simpler to build, and may be a better design.
Now where did I put that---.
der kapitan is offline Find More Posts by der kapitan
Question Vacuum forming hole plane out of plastic. What plastic should I use? Quentin Visser The Builders Workshop 16 Sep 12, 2010 01:43 PM
Question vacuum forming hole plane with plastic sheet? Quentin Visser The Builders Workshop 0 Aug 24, 2010 04:37 PM
Build Log My Vacuum Forming device Dias The Builders Workshop 5 Aug 13, 2008 05:36 PM
Cool my freshly built 12x20 vacuum forming box dougmontgomery Composites Fabrication 20 Feb 06, 2008 08:58 PM
