Old Sep 12, 2010, 08:32 AM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Vintage Engines being run video
Anybody make any old vintage engine videos of their engine being run, flown or something?
I just made this video of me bench running my old Fox blue head, dual plug, BB RC .60 engine. it was manufactured back around 1966 or so. It actually has a steel needle bearing rod, with needle bearings on both ends. it needs new rings, but I am sure Frank Bowman the ringmaster46@msn.com can take care of that no problem.
I used a 13x6 prop to keep the RPMs down, as I didn't want to over-rev it too much. I used 5% nitro glow fuel with castor oil in it. I got the engine to turn the 13x6 prop at a little under 9,000 rpms, which is probably a little low. I think it would be better with new rings. After it had run a while its idle speed was down near 2,400. But in the video it was doing 3,400 or so. I discovered the throttle arm was hitting the engine test stand mount and stopping it from idling lower. This engine uses one of Duke Fox's early three needle carbs, where you have a low, mid and high needle adjustments as well as a idle stop or speed screw. The exhaust baffle does wonders for letting the engine idle real slow.
The last time I flew this engine was in 1977 on a Astro Hog or Smog Hog plane, using a old MRC 27mhz proportional radio system. The radio had huge servos and a huge receiver. The servo electronics was inside with the receiver, and they ran 6 or 7 wires to each servo. Anyway it cleaned up well and ran pretty good for being as old as it is.
One thought is most people cannot imagine how loud a .60 engine is without a muffler on it. The carbs back then were designed to provide good fuel draw without muffler pressure. No one ever thought about using a muffler nor did they think about having mufflers on the engines.
Fox 60 dual plug engine test bench run made (circa 1966) (3 min 7 sec)
A while back I test ran this old circa 1976 vintage Fox 15 bushing engine. I couldn't put the muffler on as the test stand bolt was in the way. But I was surprised as to how well it idled without a muffler.
I have the engine on a little Sportster 15 size clone plane. It was a bright sunny windy day and the light flashing through the leaves from the trees played havoc with the tachometer.
Fox 15 Bushing engine test run (2 min 1 sec)
Oh yeah, here is a video clip of me running a little OS FS26S engine a while back. If I remember these were made around 1990 or thereabouts. I really like the small four cycle engines, they are so cool being small and made with something like clockwork precision. Plus they are amazingly quiet. I really need to do something with it soon. I have two of them, maybe a twin engine plane would be neat.
OS FS26 SGlow engine RC (0 min 54 sec)
earlwb is online now Find More Posts by earlwb
Old Sep 12, 2010, 02:54 PM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
This is pretty vinatge. My D model Brown Jr on gasoline and oil. A couple flips and she's purring.
Brown Jr. Model D .60 (0 min 37 sec)
Leadchucker is offline Find More Posts by Leadchucker
Old Sep 12, 2010, 03:25 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Cool! Luv it! More videos of engines please!
Saito 40 from late 70's:
Saito FA-40 Mk I (2 min 5 sec)
CoMo 40 from late 70's:
CoMo 40 (8 min 32 sec)
Enya 40 from 70's I think:
Enya 40-4C (6 min 25 sec)
O.S. FS-20 from 80's I think:
OS FS-20 (3 min 33 sec)
Russian MAC 60 from 80's I think:
Russian MAC (MDS) 10cc FIRE, 3rd Run (4 min 8 sec)
Wen-Mac 049 from the 60's:
Wen Mac Lotus Engine Test (8 min 17 sec)
Kmot is offline Find More Posts by Kmot
Old Sep 12, 2010, 03:45 PM
Glue Gun is offline
Find More Posts by Glue Gun
registered user
Annapolis, MD
Joined Sep 2009
Cool engines! I could watch these videos all day. Anyone have any vids of vintage diesels running?
Leadchucker, what kind of coil do you use with the ignition engines?
Glue Gun is offline Find More Posts by Glue Gun
Old Sep 12, 2010, 03:59 PM
AMA7224 LSF1832
Joined Sep 2008
Larry Davidson's model engine coil and high tension leads with 10K resistor. For flying with R/C on 2.4 ghz I use a solid state ignition module by Marv Stern that elimnates the condensor. The module is controlled by plugging it directly into the throttle port of you RX. It makes the points work as a switch so there is less ignition noise and further isloates noise by using an optical switching device for off and on. The entire ignition setup with coil, module and a 3.4 volt 3 cell NimH 1600 maH battery weighs in at 3.7 ounces.
Not a glitch or twitch and is super reliable.
Old Sep 12, 2010, 04:53 PM
Glue Gun is offline
registered user
Annapolis, MD
Joined Sep 2009
Thanks for the info. I appreciate it. Those old spakies sure are neat.
Maybe I'll try to get a vid of my old diesel uploaded.
Old Sep 12, 2010, 09:19 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Nice videos guys, please keep them coming.
LeadChucker, what prop did you use and what RPMs were you getting with that engine?
Old Sep 13, 2010, 08:44 AM
Patxipt is online now
Find More Posts by Patxipt
engine-a-holic
Portugal, Lisbon
Joined Jun 2007
My FS-60, probably as old as I am.
OS FS60 (1 min 7 sec)
Saito FA-45 MK-II
Saito FA-45 MKII first run (7 min 24 sec)
PAW 09 MK-II, 1.5cc
P.A.W. 09 BR MKII (1 min 31 sec)
DC Spitfire, 1cc
DC Spitfire (1 min 30 sec)
Patxipt is online now Find More Posts by Patxipt
Old Sep 13, 2010, 09:03 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I'll add this. ETA .15 MKIII diesel.
ETA .15 MKIII 1965 CL Team Race Diesel Engine (2 min 36 sec)
Greg
gkamysz is offline Find More Posts by gkamysz
Old Sep 13, 2010, 06:05 PM
Glue Gun is offline
registered user
Annapolis, MD
Joined Sep 2009
Here is a link to my vid. I can't upload vids I made with my digital camera here on the engine forum. Its my first video ever. I don't think it turned out too bad.
http://www.rcgroups.com/forums/showt...1#post16040170
I joined You Tube.
MK-17 Diesel Engine (3 min 1 sec)
Old Sep 13, 2010, 06:16 PM
Glue Gun is offline
registered user
Annapolis, MD
Joined Sep 2009
If you guys want, I could try making vid of it flying with a hat cam or something.
Wow Greg, that diesel really screams! Those are some nice diesels.
Old Sep 13, 2010, 07:45 PM
pathfinder is offline
Find More Posts by pathfinder
Mach 1
pathfinder's Avatar
walterboro s.c.u.s.a
Joined Jun 2004
I love that little Como 40.My dad had many engines in his day.But I can clearly remember everytime he would crank a Como he would look at me and grin, and comment how remarkably well they ran.
And just one more thing ,keep the vids coming.Lets keep this a no lipo zone.j/k
pathfinder is offline Find More Posts by pathfinder
Old Sep 13, 2010, 09:04 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
great video clips guys.
Patxipt, yeah I have one of those old OS 60 four cycle engines too. I haven't run it since I semi-retired my old Sig Senior Kadet airplane (needs new monokote, but it uses a bunch of that stuff). I need to get it out, and oil it up some and run it again too.
Thanks for reminding me.
Old Sep 13, 2010, 09:29 PM
AMA7224 LSF1832
Joined Sep 2008
13 x6 and she turns at 6600 rpm on gas and oil. She'll make 7000 on methanol and castor with same prop.
Old Sep 14, 2010, 09:40 AM
gluemaster is offline
Find More Posts by gluemaster
Cub-O-Holic
gluemaster's Avatar
Deltona, FL
Joined Dec 2006
Here's my Saito open rocker 30 that I bought off of eBay for $90.00. It came with all of the original paperwork, tools and stickers, muffler and also came in the original box with the foam still intact. I had been run at one time or another and then put away. When I got it it was seized up. A little methanol and some carb cleaner, along with some air tool oil and she was good to go.
Saito Fa30 open rocker (1 min 34 sec)
gluemaster is offline Find More Posts by gluemaster
Discussion The greatest 'hit and run' video you'll see today. BE77 Pilot Life, The Universe, and Politics 4 Aug 18, 2010 07:40 PM
For Sale Vintage Enya .15 lll TV Never Run lanilll Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 26, 2010 05:38 PM
Alert Some vintage KNK stuff being offered for sale... Kmot Scale Boats 0 Jun 28, 2010 04:24 PM
Discussion Cool video of smoke being pulled through a propellor larryjmoore Modeling Science 8 Apr 09, 2010 01:05 AM
Discussion Cool video of smoke being pulled through a propellor larryjmoore Power Systems 0 Apr 06, 2010 10:39 PM
