Old Sep 12, 2010, 03:35 AM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Can this cam be used for FPV ?
I have had this cam for pretty long time now, but don't know much about it.
But will I be able to use it for FPV or does anyone know if it is a good one for FPV ?
SpookiePower is offline Find More Posts by SpookiePower
Old Sep 12, 2010, 04:01 AM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
I dont see why not, looks like a pinhole (90 degree) lens.
If you know the operating voltage wire it up & see if you can fly with that kind of image.
badlands is offline Find More Posts by badlands
Old Sep 12, 2010, 04:38 AM
Joined Jun 2009
It says 9.6v - 14.4v DC / Max 1.1w - BAS 1vpp/75ohm
Old Sep 12, 2010, 04:42 AM
Rangarid is offline
Find More Posts by Rangarid
Joined Aug 2010
3s should work well
Rangarid is offline Find More Posts by Rangarid
Old Sep 12, 2010, 05:00 AM
Talajouy is offline
Find More Posts by Talajouy
Australia, QLD, Gold Coast
Joined Aug 2007
You can buy a 2.5~2.8mm lens and change it with that pinhole lens to get a wider image.
Talajouy is offline Find More Posts by Talajouy
Old Sep 12, 2010, 06:00 AM
Joined Jun 2009
Do you know what size lens it use right now ?
Old Sep 12, 2010, 06:29 AM
LKJ is offline
LKJ
Find More Posts by LKJ
LKJ
Lars k Jensen
Denmark, Central Denmark Region, Tostrup
Joined Apr 2006
On the picture of the box there is written PIN 3,7 i think it is a bit narrow 75 degrees.
Just try it.
Cheers
Lars
LKJ is offline Find More Posts by LKJ
Old Sep 12, 2010, 06:50 AM
chancesAU is offline
Find More Posts by chancesAU
chancesAU's Avatar
Australia
Joined Apr 2008
Only one way to find out how good it is
Most lens's are standard size, should be easy to find one to swap it with.
chancesAU is offline Find More Posts by chancesAU
Old Sep 12, 2010, 07:12 AM
Talajouy is offline
Joined Aug 2007
http://www.bevrc.com/bev28mm-board-lens-p-100.html
Question this aiptek cam..anygood for fpv recorder barok FPV Talk 11 Aug 15, 2010 03:19 AM
Discussion Can helicopter motors be used for airplanes ?help!! , help ?? jerryantczak Power Systems 8 Aug 06, 2010 05:20 PM
Discussion Some advice for HD cams which can be used for FPV AnnihilaT FPV Talk 18 Aug 02, 2010 02:43 PM
can the "E-bay hong kong video cam" be used eran_k Aerial Photography 19 Aug 01, 2005 09:43 AM
tx for 1.2 Ghz cam can be used with a Nikon afineman Aerial Photography 7 Jul 12, 2005 06:07 PM
