Old Sep 11, 2010, 02:35 AM
Chris Jenkins is offline
Find More Posts by Chris Jenkins
Chris Jenkins's Avatar
United Kingdom, Wales
Joined Feb 2005
Tomboy 48"
I'm just starting a Tomboy 48" build, and as it will be electric powered (outrunner & LiPo's) would be very interested in any experience/thoughts on motor/prop/Lipo sizing.
The original as designed by old Boddo used a Mills 1.3
Regards
Chris
Chris Jenkins is offline Find More Posts by Chris Jenkins
Old Sep 11, 2010, 02:40 AM
orange&white is offline
Find More Posts by orange&white
Scott R/C Time Pilot
orange&white's Avatar
NorthBend/Coos Bay,Oregon USA
Joined Dec 2009
A speed 400 size outrunner and a 2s or 3s 1000mah to 1500mah lipo and 10-6 prop
Scott
orange&white is offline Find More Posts by orange&white
Old Sep 11, 2010, 02:43 AM
Joined Dec 2009
Is this going to be a long wing stock version or is the whole plane going to be bigger?
Old Sep 11, 2010, 04:41 AM
Joined Feb 2005
Hi Scott...the whole airframe is bigger...36 inch version scaled up by 1.3
(Anyone electrified a 48" ?)
Old Sep 12, 2010, 01:06 PM
phil_g is offline
Find More Posts by phil_g
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
I'm just fitting mine out, I was planning on a plain Blue Wonder 1300 on 2S and a 10x4 slowfly, or 3S and a 8x4SF... but that was before I realised how heavy it is!
The Tomboy is standard upscaled to 48" and when fully fitted out, will be getting on for 22oz - much more than I expected. The BW runs 75w comfortably, so at 50w/pound and as I'm looking for graceful flight not verticals I'm hoping it will be ok. The BW does look tiny in the engine bay...
Meanwhile I'm watching the thread to see what others think...
Cheers
Phil
phil_g is offline Find More Posts by phil_g
Old Sep 12, 2010, 11:06 PM
Joined Feb 2005
Interesting, Phil. Thanks.
I was thinking about an AXI 2212/26 with a 10x5, and a Jetti 18A BEC on 3s.
Chris
Old Sep 13, 2010, 01:26 AM
Joined Dec 2009
This would be perfect
http://www.hobbyking.com/hobbyking/s...idProduct=8622
Ax 2210-1000 42-gram 13T Delta Stock (26g)
Kv = 1019 Io = 0.85 Rm = 0.138
GWS 10-6 *D prop
Rhino 750mah 3S battery
7862 rpm @ 10.85volts/13.39 amps
Badcock: 790 grams 27.9 oz thrust
Drive Calc: 891 grams 31.4 oz thrust and 78 Efficient
I have one on a 21oz plane, it rules.
Scott
Old Sep 13, 2010, 02:19 AM
Joined Feb 2005
Thanks Scott.
Phil, with this weight (22 oz) did you build as per plan using 1/4" sq...or were you temped to lighten ?
(I'll be covering with tissue over 0.5 micron mylar)
Cheers
Chris
Old Sep 13, 2010, 02:24 AM
Joined Dec 2009
Hi Chris, My Tomboy is done, maiden tomorrow.
Old Sep 13, 2010, 06:28 AM
Joined Feb 2005
Great....I'd recommend a hand launch.
Good luck !
Chris
Old Sep 13, 2010, 06:34 AM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Cheers
Phil
Hey Phil,
I'm a great believer in the BW, I use one in a 17oz Cessna to good effect. Enough power with an 800mah 2s, enough for tricks with a 3s, both with an 8x6 prop from memory. 22oz is going to be stretching it a tad, but, I never cease to be amazed what the BW can do so maybe it will be fine for 'scale' flying.
sparks
sparks59 is offline Find More Posts by sparks59
Old Sep 13, 2010, 07:17 AM
phil_g is offline
phil_g's Avatar
Joined Jul 2007
Well, I confess I didnt build it - I built some radio equipment for a pal, who in return built me theTomboy. And a lovely job he did too!
I do like the BW's, I have a few in regular use, but this will be the largest/heaviest... we shall see. My single channel gear gives full or zero throttle so I dont want it overpowered. Time will tell...
Cheers
Phil
Old Sep 13, 2010, 03:20 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
looking forward to reading the flight report, and seeing the video if you can arrange it Phil
sparks
Old Sep 13, 2010, 04:11 PM
phil_g is offline
phil_g's Avatar
Joined Jul 2007
Yep I'll get my lad to video it, it will be my first S/C bang-bang model since the 60's I'll put a photo in the Tomboy photo thread.
Cheers
Phil
Old Dec 26, 2010, 11:29 AM
Jiffy is offline
Find More Posts by Jiffy
Jiffy's Avatar
Joined Nov 2005
Hi guys, I've building a Tomboy 36" and a senior 48" I want them both to be lecky, can anybody help me choose a cheap motor on ebay for both please?
I have lipos and esc, just need to order some motors.
Chris
Jiffy is offline Find More Posts by Jiffy
Build Log Vic Smeed Tomboy r/c electric orange&white Vintage & Old-Timer Designs 84 Oct 04, 2014 08:20 PM
Discussion Tomboy Pictures Teals1 Vintage & Old-Timer Designs 44 Nov 02, 2010 06:05 AM
Video Electric tomboy Chris Jenkins Electric Plane Talk 2 Aug 16, 2010 12:40 AM
Gallery Electric tomboy movies Chris Jenkins Vintage & Old-Timer Designs 0 Feb 07, 2010 05:16 AM
