Old Sep 10, 2010, 09:49 PM
pitviper51 is offline
Find More Posts by pitviper51
Foamy Season is here! MX2#1
pitviper51's Avatar
Elizabethtown, Kentucky
Joined Nov 2005
Question
rowing?
I have tryed searching here and nothing.. can anyone explain the programing used in this video.
Radio Control (RC) rowing boat powered by servos (0 min 34 sec)
Look like a fun thing to try, perhaps a kayak since im a kayaker..
Thanks.
pitviper51 is offline Find More Posts by pitviper51
Old Sep 10, 2010, 09:55 PM
ZZ56 is offline
Find More Posts by ZZ56
Nickel Belter
ZZ56's Avatar
Canada, MB, Winnipeg
Joined Jun 2009
No programming... two servos on each side, y-linked together. Probably 'rowed' by moving the control sticks back and forth.
ZZ56 is offline Find More Posts by ZZ56
Old Sep 10, 2010, 10:12 PM
pitviper51's Avatar
Joined Nov 2005
if you click on the link, it discribes a throttle to servo mix. I was thinking just hooking it up and making a rowing action on both sticks... I will need a extra radio so not to hammer sticks to much.. I would try this on a foam floating board before investing huge time in building a wood row boat.
Old Sep 10, 2010, 10:16 PM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
Is it two or four channel total? I know there are four servos, but can you get the oval action of the oar with only two? It's not very clear, but it looks like the lift and pull servos are not always moving in sync with each other.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Sep 11, 2010, 04:03 AM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
There was some discussion on this last month...
http://www.rcgroups.com/forums/showthread.php?t=1284665
There does seem to be a mixer board involved in this particular boat.
That is how it is able to turn, then resyncronize the oar strokes...
Maybe that Arduino board is involved again...
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Sep 11, 2010, 04:22 PM
pitviper51's Avatar
Joined Nov 2005
nice.! the reason I like this set uo so much is its very realistic paddle movment, I was hoping to find more video of this set up, is the artical on this boat online?
Old Sep 11, 2010, 06:13 PM
bgnome is offline
Find More Posts by bgnome
made of fire and pop rocks
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
yep, that was my thread
theres a google translated link in there with more information.. but suffice to say, it can be done by circulating the sticks. but it's done with a programmable IC. controlling the actual rowing movement hook the chip up to RX and the program takes over from there.
I have the mechanics of it all worked out, I know how the chip works, its just a really tiny PLC and that's music I can dance to. just need to get a hold of a chip and experiment at this point.. a raw Adriano can be had for around $30 and under. full development boards run around between $60 and $120, and there are all types of sensors and toys that can be added to them. radio shack sells a development/experiment kit for around $100 complete with a big ole thick book, a few sensors, and a servo or two.
apparently there is a "guy in Germany" who sells the preprogrammed chip set control boards for something like $100, but I have yet to find him in my travels on the internets.
so... yes.. I am working on developing a control board for this for this stuff, and when the time comes I hope to be some "guy in Virginia" making them available
like I said.. the big hurdle now is figuring out the programing.. the program will have the row function as a mapped function. two channel control will have a centered throttle stick. forward past center makes it go forward, pulling it back reverses the direction ( obviously ), rudder control slow or speeds up the left right bank of servos in that direction.
like I said.. its all programming at this point.
bgnome is offline Find More Posts by bgnome
Old Sep 11, 2010, 07:09 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
There are two other boards that I have seen people use...
One is the Dorkboard,... http://dorkbotpdx.org/
The other I keep wanting to call a Pico board, but I know that's not right...
Old Sep 11, 2010, 07:32 PM
steamboatmodel is offline
Find More Posts by steamboatmodel
steamboatmodel's Avatar
Toronto, Canada
Joined Nov 2004
I think your thinking of PIC as in Pic Microchips.
I have the Pic Kit 2 starter kit, but haven't got around to learning enough about programing it to do rowing. I am still working with "Hello World"
Regards,
Gerald.
steamboatmodel is offline Find More Posts by steamboatmodel
Old Sep 11, 2010, 07:42 PM
bgnome is offline
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
PICO is also valid as Programable Intigrated COntroller for the chip class.
Old Sep 11, 2010, 10:42 PM
pitviper51's Avatar
Joined Nov 2005
ill have to talk to my programer friends, I dont mind the moving the sticks around though,
Old Sep 13, 2010, 05:15 AM
fatboy999 is offline
Find More Posts by fatboy999
fatboy999's Avatar
Canada, ON, Tillsonburg
Joined Feb 2005
Pitviper, check out this item and PM the builder for more info: http://www.hullmodelboatgroup.co.uk/...is_rowing_boat
fatboy999 is offline Find More Posts by fatboy999
Old Sep 13, 2010, 11:05 PM
pitviper51's Avatar
Joined Nov 2005
thanks
For Sale Rowing SP-22 Merlin! airlush1 Aircraft - Sailplanes (FS/W) 1 Jul 06, 2011 07:27 PM
Wanted canopy for 4m Rowing LS4 balsabozo Aircraft - Sailplanes (FS/W) 1 Jun 04, 2010 02:03 PM
Discussion Rowing LS series - canopy balsabozo Scale Sailplanes 2 Jun 03, 2010 03:18 PM
FS: RoWing Merlin 3.3-meter Fully Molded Sled Driver Aircraft - Sailplanes (FS/W) 2 Aug 25, 2004 08:09 PM
Rowing from New Zealand to South Africa ChrisP Life, The Universe, and Politics 8 Nov 10, 2003 05:46 AM
