Old Jul 17, 2011, 06:57 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
killer twin.. I assume you will have more toqrque but what will give you speed is the rpm of the fan. will you have more now on 6s?
pavcon is offline Find More Posts by pavcon
Old Jul 17, 2011, 07:30 AM
ApexAero is online now
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Originally Posted by killer vtwin View Post
I just ordered an arc motor to install in one of my 68 mm rc lander fans .this fan was rated for 3s when i am done it will handle up to 6s .this will go in the meteor.as for my habu i installed a tacon 2860/2550 kv in the v15 fan it can now run on 6s .rain is messing me up this weekend so flight test will come next week
Take a look at this, you need power? This is a Lander Alu Housing/wemo blade/velocitymotor on 4k/65c/5s
ApexAero is online now Find More Posts by ApexAero
Old Jul 17, 2011, 02:44 PM
killer vtwin is offline
Find More Posts by killer vtwin
birmingham Al.
Joined Aug 2005
I hope
killer vtwin is offline Find More Posts by killer vtwin
Old Jul 17, 2011, 02:54 PM
birmingham Al.
Joined Aug 2005
I just hate having a useless lander unit that does not perform well so the motor upgrade well make me happy .I just cant use an edf unit that can only handle a 3s and the 4370 kv motor when I tried 4s couldny handle it so refitting a more powerful motor will give me the options I want .If it works like I hope I will do my other lander unit wich has the 3450 kv motor
Old Jul 17, 2011, 06:02 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Killer, I just built a Lander for a friend with a 1W30 that I tested to 2100 watts @ 146 amps, not that he'll run it at that but its doable, a 1W30 is rated at 4s max 1400 watts @ 120amps guaranteed
Old Jul 17, 2011, 07:00 PM
birmingham Al.
Joined Aug 2005
was that 68 mm unit you put together?if yes then wich one ,i just cooked the 3450 on 5s and it is assembled different than than the 4370 one .The can motor is threaded on the exterior and screws in to the motor mount and is held in place with grug screws.I may be s.o.l. on modding this one unless I can find a lander replacement
Old Jul 17, 2011, 07:17 PM
kremecheze is online now
Find More Posts by kremecheze
kremecheze's Avatar
United States, NY, Queens County
Joined Jun 2007
where can i pick up an airframe only version of this bird these days?
kremecheze is online now Find More Posts by kremecheze
Old Jul 17, 2011, 07:35 PM
jhaywood is offline
Find More Posts by jhaywood
jhaywood's Avatar
United States, VA, Suffolk
Joined Nov 2007
Yeah what he said.
jhaywood is offline Find More Posts by jhaywood
Old Jul 17, 2011, 10:49 PM
rorrock is offline
Find More Posts by rorrock
Global Hobby Store
rorrock's Avatar
Brisbane
Joined Jan 2007
Dynam no longer make an airframe only version...
If you really want one, I could look into getting it in using spare parts..
rob
rorrock is offline Find More Posts by rorrock
Old Jul 17, 2011, 11:17 PM
robusp is online now
Find More Posts by robusp
Takeoff=Option Landing=Must
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
Had bunch of fun today flying 3 Meteors at once.
Even tried formation flying.
Mine (in the middle is the oldest on 4s 5000mAh)
Other two are on 4s 3600mAh.
Couple other guys were asking, who know they might get in to it.
Rob
robusp is online now Find More Posts by robusp
Old Jul 18, 2011, 01:45 AM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
The grub screws are just securing the bullet over the motor, you have to remove the impeller then the mount screws behind the impeller to remove the motor. The motor should have thermal grease on the exterior to transfer heat so get a rag before you disassemble. Also grind the tip of the bullet off making a 1/2in hole for air.
Old Jul 18, 2011, 07:20 PM
birmingham Al.
Joined Aug 2005
yes I got apart once I got a closer look at it.I guess I will have to use a lander motor to replace the burnt one .the prop adapter must be loctite in cuz the shaft just came right ot of the motor with little effort,thanx for the tip on the bullet I will do that on the other unit that the arc is going in.I still would like your thoughts on a replacement motor with threaded can .Or should chunk it and and get a non treaded housing .thanx Apex
Old Jul 18, 2011, 07:45 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
I just finished this one in my custom "Military Sport Trainer" scheme.
Is it a Meteor, or is it a Habu? I'll let you decide...
Sammy70 is offline Find More Posts by Sammy70
Old Jul 19, 2011, 02:00 AM
pavcon is offline
Joined Jan 2010
clearly a habu.
grey foam and lame coolling intake
But grat paintjob. I could never do something similar my self
Old Jul 19, 2011, 03:08 AM
tommywatson is offline
Find More Posts by tommywatson
Sydney Australia
Joined Sep 2003
Tailpipe outlet size.
I flew my new Meteor today and it flew very well. I had the old HABU at the field and they were both sitting in the bench and I noticed the tailpipe size was different. The HABU is 59mm and the Meteor is 62 mm. What would be the effect of this assuming the same fan size and rpm?
Regards
Tom Watson
Sydney Australia
tommywatson is offline Find More Posts by tommywatson
Sold Larry Jolly "Meteor"-127" Kit NIB --Now $275 Shipped ldm1839 Aircraft - Sailplanes (FS/W) 5 Sep 29, 2010 05:34 PM
Discussion Meteor shower tonite, You goonna stay up for it? Bilbobaker Life, The Universe, and Politics 13 Aug 15, 2010 11:32 PM
Build Log Peter Rake's 30" General Western Meteor Prototype dz1sfb Scale Kit/Scratch Built 19 Aug 15, 2010 10:38 PM
Discussion Two Hours Outside and I only Saw One Perseid Meteor Chophop Life, The Universe, and Politics 12 Aug 12, 2010 07:28 PM
For Sale Russ Thompson Meteor fuse Bill L Aircraft - Sailplanes (FS/W) 0 Oct 15, 2009 09:18 PM
