Old Jun 10, 2011, 06:49 AM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Originally Posted by pavcon View Post
so those are KM/H
Yes KPH and not close to the 250kph he was claiming before.
http://www.rcgroups.com/forums/showp...2&postcount=34
The Don is offline Find More Posts by The Don
Old Jun 10, 2011, 06:54 AM
djtibas is offline
Find More Posts by djtibas
djtibas's Avatar
Joined May 2011
Originally Posted by FresnoJay View Post
I am not sure what measurement you were radaring the plane in. But using my rcspeedo and current temp the fastest I got was from the second video (bungee launch one). The speed was 121mph. If you can provide me with a best guess as to the temp at the time of the flights I can see about getting you a better speed reading. For some reason the bungee launch video had clearer sound on it even with the rooster crowing. I was able to get almost every pass.
Jason
Videos were recorded in Teresina, Brazil. On the day of recording the temperature
was 38 degrees Celsius. The sound is better in the second video because the camera
was fixed and less windy (in spite of the crowing rooster). The radar is not precise with small objects of more than 170kph,
as explained in the manual, so the speed was not confirmed with the pistol,
only able to confirm with the doppler. I put this radar sale to buy a better one.
In the second video Doppler got 145mph.
Please doppler based on the temperature of 38 degrees Celsius. Thanks!
djtibas is offline Find More Posts by djtibas
Old Jun 10, 2011, 11:43 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
doublepost
pavcon is offline Find More Posts by pavcon
Old Jun 10, 2011, 11:44 AM
pavcon is offline
Joined Jan 2010
i will do that as soon as i get home btw how did achieve that silver look?
Old Jun 10, 2011, 11:51 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
I did doppler at 38C. I am not sure how much more evidence you need to believe your plane is not going the speed you claim. I posted many doppler plots with the speeds from your videos then you buy a radar gun and even when your video shows 174 kph on the radar AND doppler of the same pass shows 178kph you still think you model is going ~250 kph. What will be the excuse when your new radar gun gives you the same speeds?
Don
Old Jun 10, 2011, 12:03 PM
pavcon is offline
Joined Jan 2010
just wait till i get mine. My goal is 200km/h .. And i think is achievable
Old Jun 10, 2011, 01:11 PM
djtibas is offline
djtibas's Avatar
Joined May 2011
Don
Cause you always tend to put my results lower. In the first video
4S was flying only to test the radar, just posted this video to
show the vertical takeoff. The second video posted to the doppler because
is in perfect condition for that. With results obtained in Doppler
145mph/237kph. You already posted the fastest results for a video (126.9 mph) in
topic -> http://www.rcgroups.com/forums/showthread.php?t=1447650.
"The Don" is their first spoken words referring to the video:
Here is what the 5 dopplerable passes are assuming to 100F (38C air temp)
Pass 1 at 2:01 = 126.9mph
Pass 2 = 124.6 mph at 2:18
Pass 3 = 120.4 mph at 2:45
Pass 4 = 118.9 mph at 3:07
Pass 5 = 121.1 mph at 3:35
The waveoscope passes you posted in post # 1
Old Jun 10, 2011, 01:18 PM
djtibas is offline
djtibas's Avatar
Joined May 2011
Please do the doppler only the second video, below are my results of the second video in :
On the second video in (1m 33s) 237kph/146mph
Old Jun 10, 2011, 02:18 PM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Ok after adjusting the settings for temp the fastest pass I could get from the second video was 147.2mph or 246.9kph (rounded up). Now please bare in mind this is again using rcspeedo on my droid. Same pass as quoted by djtibas iirc.
Jason
FresnoJay is offline Find More Posts by FresnoJay
Old Jun 10, 2011, 04:05 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
EDIT: See post below for speed at 1:33 of the "second video"
Old Jun 10, 2011, 04:36 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
The reason you are getting a higher speed at 1:33 is that you are including the throttle reduction as part of you speed. Here is what that pass looks like when you magnify it. As I said before, I would suggest you save your waveform at a smaller sample rate instead of 48kHz. If you save as 24kHz. Then it will magnify the waveform in waveoscope so you can see the lines clearer.
Here is the same pass in RCspeedo. You can see it shows two speeds which add up to 151mph. You can see how reducing the throttle added 26 mph to the speed. That is why you must hold throttle.
Old Jun 10, 2011, 07:43 PM
djtibas is offline
djtibas's Avatar
Joined May 2011
What is the "second video"? The only second video I see is only 1:25 long so no pass can be taken at 1:33???
This is the second video I see:
http://www.rcgroups.com/forums/showp...70&postcount=3
The second video posted in this thread. This one:
Yes Now !!!!!!!! Dynam Meteor Upgrade Setup to be the faster jet of foam in the world!!!! (4 min 25 sec)
Old Jun 10, 2011, 08:04 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
That is the video I dopplered in the post above:
http://www.rcgroups.com/forums/showp...&postcount=956
Old Jun 13, 2011, 10:37 PM
jim12 is offline
Find More Posts by jim12
Take that runway!
jim12's Avatar
United States, AZ, Glendale
Joined May 2005
Retract Woes
Getting off the speed topic for a moment, I've been frustrated with a Changesun nose gear from HK and was looking for someone who may have gone down this path. Here is what I've done after reading related posts here and in other threads.
I have a DX 7 with orange 6-channel receiver. Both main gears retract smoothly. The nose moved down once then froze down. Several hours later it retracted then extended but froze down again and there it stays. No click, no buzz.
I've varied the EPAs from 90% to 150% in ten point increments. Mains work, nose -- no. Checked the subtrims in the radio. Set to zero. Checked the receiver battery I'm using to test -- 5.6 volts on the multimeter. Fresh out of ideas. Don't think I want to mess with sending a $12 part back and am considering taking it apart to see if something is unsoldered or blackened. Before surgery does anyone have a suggestion?
I've got the mains to install yet and some company coming and a trip so the reorder process shouldn't set me back too long. I want to get this bird into the air!!
Cheers,
Jim
jim12 is offline Find More Posts by jim12
Old Jun 13, 2011, 10:44 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
The 3mm rod isn't bottoming out and jamming things up is it? I had that happen once on a new one.
I've had a few sets of these cheapy retracts now and all but one have worked well. I took the dud apart to find a broken limit switch on the circuit board.
Good luck!
Sammy70 is offline Find More Posts by Sammy70
Sold Larry Jolly "Meteor"-127" Kit NIB --Now $275 Shipped ldm1839 Aircraft - Sailplanes (FS/W) 5 Sep 29, 2010 05:34 PM
Discussion Meteor shower tonite, You goonna stay up for it? Bilbobaker Life, The Universe, and Politics 13 Aug 15, 2010 11:32 PM
Build Log Peter Rake's 30" General Western Meteor Prototype dz1sfb Scale Kit/Scratch Built 19 Aug 15, 2010 10:38 PM
Discussion Two Hours Outside and I only Saw One Perseid Meteor Chophop Life, The Universe, and Politics 12 Aug 12, 2010 07:28 PM
For Sale Russ Thompson Meteor fuse Bill L Aircraft - Sailplanes (FS/W) 0 Oct 15, 2009 09:18 PM
