Old Jun 03, 2011, 09:41 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Originally Posted by rcplanes1234 View Post
The only time this activity is happening to me is when i run out of battery in flight.
If you are running out of battery in flight then you experience this issue then you are are experiencing low voltage cutoff. The default for the Turnigy style clone ESCs is "soft" cutoff, so that is what it is doing, soft cutoff throttles back the ESC to try to keep the voltage from getting too low. If you were to set it to "hard" cutoff then the throttle would cutoff instead.
Don
The Don is offline Find More Posts by The Don
Old Jun 03, 2011, 11:55 PM
rcplanes1234's Avatar
United States, IA, West Des Moines
Joined Jan 2010
My questions has still not been answered. What kind of throw like in mm or in are you using for control surfaces? Thanks
rcplanes1234 is offline Find More Posts by rcplanes1234
Old Jun 05, 2011, 11:00 AM
Joined Jan 2010
Whats anyone's thought about putting this battery in the meteor. Could a 60 amp pro esc from eflite handle this?
http://www.hobbypartz.com/77p-sl3000-5s1p-30c-5555.html
Old Jun 05, 2011, 11:06 AM
Professional Toothpick maker
nalby's Avatar
USA, NY, New Hampton
Joined Jan 2005
That's what I use with the stock setup I get 4 min with a lot of high speed passes
For rates I use the habu setup and it works great
High Rate--------- -------- Low Rate
Aileron: 3/4-inch (19mm)----- 1/2-inch (13mm)
Elevator: 5/8-inch (16mm)----- 1/2-inch (13mm)
Rudder: 1-inch (25mm)----- 3/4-inch (19mm
nalby is offline Find More Posts by nalby
Old Jun 05, 2011, 11:42 AM
Joined Jan 2010
So you use the stock esc?
Old Jun 05, 2011, 11:48 AM
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
so .. anybody with a pdf file with the thrust tube
I know we ve discussed this before I just wonder if anybody finally did it.
pavcon is offline Find More Posts by pavcon
Old Jun 05, 2011, 12:20 PM
nalby's Avatar
Joined Jan 2005
Yes full stock drivetrain
batt & esc are barely warm
Old Jun 05, 2011, 12:53 PM
CSI
my wife's gonna kill me..
CSI's Avatar
Del Rio Intl, Texas, United States
Joined Feb 2004
I agree..full stock motor, esc, fan...
I have plenty of EDFs, but this is by far the most efficient setup I have had in an EDF...period. I am amazed. I run using a Value Hobbies 4s 3300mAh 30C pack and regularly get 6 minute flights. I land, taxi back...all in this 90-100* TX heat, and the lipo is still at normal temps! No elevated temp at all. It's a freak of physics I tell you!?! ALL my other EDFs come down with medium to hot lipos. I am not just floating around during the flight either.
This is one of my all time favorite planes to take to the field with me. IT just flies great.
Ken
CSI is offline Find More Posts by CSI
Old Jun 05, 2011, 04:40 PM
Joined Jan 2010
how many amps does the thing pull with a 5s and how much faster is it with a 5s?
Old Jun 05, 2011, 05:14 PM
Joined Jan 2010
instead of spending money on a 5s why don' tyou spend them on a 2w-20 HEt motor and a HET6904 and have the same results or even better on 4s ?
P.S. : Man I should have been a financial advisor :P
Old Jun 05, 2011, 07:20 PM
..it goes 100 miles per hour..
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
5S on the stock Metoer setup pulls between 55-59A as stated by several users. I also believe the stock setup on 5S would be decently faster than a 2W-20 on 4S and be more efficient to boot .
Jason
FresnoJay is offline Find More Posts by FresnoJay
Latest blog entry: My new addiction.
Old Jun 05, 2011, 09:54 PM
Joined Jan 2010
Jason
Thanks for the info. Would the cg be messed up with the extra weight in the nose. I have my 3000mah 4 cell all the way foward stopped by teh foam.
Old Jun 06, 2011, 01:59 AM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
RCplanes, I dont believe so. There should be more than enough room to move the pack around as needed. I have my 4S 4000 30C set about mid bay so there should be no issue. I would think the 5S may need to be towards the back of the bay but still easily doable.
Jason
P.S. One of my flying buddies threw the gauntlet down on my previous statement about the stock meteor being faster on 5S than a 2W-20 in a 6904 on 4S. So keep your eyes out as there is a race to follow .
Old Jun 06, 2011, 04:56 AM
Joined Jan 2010
Jason
sorry I never saw that. I personally doubt it ofcourse since the stock fan is said to be way off balance but.. I would still have to wait and see
on another argument if you got many 4s packs what does it cost more? buy 3 5s packs or buy the new powersystem which can go in otherplanes too.
if you already have 5S packs then get the 2w-23 with the het fan and see if you can beat that
Old Jun 06, 2011, 05:53 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Pavcon, We shall see what she can do against a 2W-20 . Me personally I am mid battery replacement cycle so picking up a few cheap 5S packs makes no difference. As far as balancing I balanced mine so its rather smooth. It has 1 rough spot as many have stated after balancing. If the fan blows she will get a Wemo or HET as a replacement. I work with what I have and adjust accordingly. Who knows there might be 5S birds might be in my future.
Jason
Sold Larry Jolly "Meteor"-127" Kit NIB --Now $275 Shipped ldm1839 Aircraft - Sailplanes (FS/W) 5 Sep 29, 2010 05:34 PM
Discussion Meteor shower tonite, You goonna stay up for it? Bilbobaker Life, The Universe, and Politics 13 Aug 15, 2010 11:32 PM
Build Log Peter Rake's 30" General Western Meteor Prototype dz1sfb Scale Electric Planes 19 Aug 15, 2010 10:38 PM
Discussion Two Hours Outside and I only Saw One Perseid Meteor Chophop Life, The Universe, and Politics 12 Aug 12, 2010 07:28 PM
For Sale Russ Thompson Meteor fuse Bill L Aircraft - Sailplanes (FS/W) 0 Oct 15, 2009 09:18 PM
