Old Aug 15, 2012, 05:40 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
I have a few of those "Mini's". They are great fun.
The P-51, F-35, Mig-15, T-45
You will generally get a zone, or two, of vibration and 'out of balance noise' with EDF's as you move up through the RPM range - if they are not balanced very well.... and most PNF's are not!
For these ones, the fans are hot glued in - or something like that - and you can just pull them out with 'careful' force. A suggestion I heard the other day was heat them with a hair-dryer first - to loosen the glue first. I have not tried that, but its sounds like it would help/work at least some amount at worst.
When I put them back in, if the cover clamps it well enough, then that is enough. Otherwise use a dab of hot glue, or silicone (eg glass or gutter stuff), or even a dab of CA. The foam is moulded to 'hold' them, sort of, and the cover clamps them some amount too, so that does the main holding work.
Because it is a "weeny 50mm", on those you can just rotate the fan on the shaft, rather than pull it all apart (you could do it properly if you wanted to) - it is a threaded shaft so you can do it up a bit "tighter" and it will then be in a different position compared to the motor. And this can get you to a nicer balance point - less vibration/noise.
This is because the motor itself will likely be a bit out of balance, and thus when you rotate the fan around a bit, you can 'improve' the opposing balances and end up in a nicer total balance position.
My T-45 was atrocious. The other three were all acceptable. But once I still did the rotation on them all they were all really good then - bar the T-45 which became acceptable, but still not rght. Though it flies fine... it just sounds terrible! LOL
If you have decent ground to take-off from then use the landing gear at first. Once you get used to it you will really want the landing gear off, as it looks far better, and the LG is not that great for landing anyway. (If that one even has it?).
They all seem to fly very well - very easy - bar the F-35 which has such a short winspan that is it very unstable in roll - in all directions really! LOL. But yours should be easy. Even easy to handlaunch - just underarm 'push' it out with a good pace, at some lowish angle (25deg?) and they fly away fine.... according to your control surface setup, and your own TX control or 'panic', LOL.
PeterVRC is offline Find More Posts by PeterVRC
Old Aug 15, 2012, 09:45 PM
hate2crash is online now
Find More Posts by hate2crash
Joined May 2010
Yes, mine does not come with LG...I will probably fly it as is first... my concern is set screws for control surfaces vibrating loose....I will use red lock tight before i maiden...I have blue angels sceme very cool looking bird and will put a couple of coats of polyurethane on plane...thanks Pete! Happy flying
hate2crash is online now Find More Posts by hate2crash
Old Aug 15, 2012, 09:52 PM
PeterVRC is offline
Joined Nov 2006
Use blue loctite, or at most the green. Red is very strong and almost permanent.
Also check the control horns are well stuck to the foam. I often run a bit of epoxy onto their edges.
Old Aug 16, 2012, 12:49 AM
Joined May 2010
I removed paint where horn goes and all surfaces that are glued..used locktite 5 min epoxy..i used expoxy for everything on this plane..it seems to be very solid bond...thanks
Old Aug 16, 2012, 10:17 PM
thndr1mj is offline
Find More Posts by thndr1mj
Yeah, I can CRA$H that!
thndr1mj's Avatar
United States, GA, Dallas
Joined Dec 2010
Dynam Meteor flight IFR conditions
Dynam Meteor Flight IFR conditions (3 min 52 sec)
thndr1mj is offline Find More Posts by thndr1mj
Old Aug 21, 2012, 09:23 AM
STANG KILLA SS is offline
Find More Posts by STANG KILLA SS
STANG KILLA SS's Avatar
Killeen TX
Joined Dec 2006
is the airframe only still available anywhere?
STANG KILLA SS is offline Find More Posts by STANG KILLA SS
Old Aug 21, 2012, 11:20 AM
kakofonixx is offline
Find More Posts by kakofonixx
Ελλάς, Αττική, Αθήνα
Joined Jun 2009
I don't think so... I was searching for a bare meteor or habu frame couple of months ago but was out of stock everywhere I looked
kakofonixx is offline Find More Posts by kakofonixx
Old Aug 21, 2012, 04:28 PM
iflyrc1012 is offline
Find More Posts by iflyrc1012
no more glow models for me!!!!
iflyrc1012's Avatar
bklyn n.y.
i you find it, post the link here a lot of us could use a new airframe
iflyrc1012 is offline Find More Posts by iflyrc1012
Old Sep 16, 2012, 05:06 PM
thndr1mj is offline
thndr1mj's Avatar
Joined Dec 2010
Dynam Meteor Crash
Dynam Meteor Crash (5 min 7 sec)
Old Sep 16, 2012, 06:30 PM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Well after many years of hard service my stock motor/fan unit died at Fresno Jets jet rally today. Luckily I was coming in for a speed run for altitude when I noticed it was a bit quiet. Had enough time to drop the gear and set her down safely. So now its time to find a suitable hop-up replacement.
jason
FresnoJay is offline Find More Posts by FresnoJay
Old Sep 17, 2012, 05:16 PM
iflyrc1012's Avatar
bklyn n.y.
well fresno jay,
it seems like you have a dilemma, do you want more speed? or the same speed with that sweet turbine whoosh? or do you want to go ballistic? let us know what set up you choose and why....and post some pics and video if possible. i just picked up a stock Habu at the NEAT fair last weekend for $75 so i'll be watching. i think for me, 4cells and a 10 blade Change Sun fan may be the way i'll go.... i figure 90 mph top end but it won't have that annoying e.d.f. whine, it will have that sweet turbine whoosh!
Old Sep 17, 2012, 10:01 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
iflyrc,
I just so happen to have a CS10 sitting in my hobby room along with the stock Meteor rotor that was undamaged. I have numerous orphaned housings and rotors as well. Have been looking at various motors as i do want to continue to use the 5S packs I already have on hand and have been using in the plane. I also would like to continue using the stock ESC as it has done well considering how it has been abused.
For the CS10 I am looking at 2500Kv motors to run on 5S. But its a matter of whether the esc will be big enough for the task. I think I have a 80A about the same size laying around somewhere so if needed shouldn't be too big a deal to swap it.
But then again I have also been looking at 2800-3000Kv options to use the stock rotor on to also continue using 5S.
Lots going on behind the scenes, trust me. Once a choice is made and flights flown there will be info and video posted .
Jason
Old Sep 18, 2012, 12:25 AM
PeterVRC is offline
Joined Nov 2006
5S CS10 2300kv is a bit down on stock 5S result. Above approx 2300kv you would not use the stock ESC (60A).
I would expect 2400kv would match stock 5S thrust, and 2500kv would exceed it. The CyclonePower 2550kv hits very high 60's.
If you want just 'good speed' the L2855-2300kv means just $13 and copes long term fine.
'Better speed'... Cyclone Power 2550KV ($45).... but need the ESC done too. So you are heading to $70+ for that.
I would like this Tacon better than CyclonePower..... need a heatsink too then. $5, so still $45 total
http://www.hobbypartz.com/96m821-2860-2550kv.html
At 2550kv CS10 5S you could use a throttle limit to cut off a bit of top end. (Or switch mix it to re-add it as a 'boost' mode).
Then for 'very good power' you would head to 6S and 2200kv .... HET2W30.... Amps into 60's and 1200W regions. ($75 motor $5 HS and bigger ESC...... $100+ total). And .. batteries....
Old Sep 18, 2012, 03:30 AM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
jason
Hey Jay
Call or email me concerning how much you want to hop it up. If your looking for killer speed the HET 1W-40 at 3300 kv should be a rocket on 6s. I'm sure you can get 6s in there, as a local guy flies his foamy Habu 1 (close enough) on 6s 4000 and 6s 5000 packs. of course you'll need a good 100+A ESC
We have milder 4s and 5s setups as well. a 3600-3700kv motor on 4s will pull about 65-70A
The HET and Wemo fans are the best for high power at a resonable cost.
The CS rotor will blow at 46k rpm (or about 1400w)
Buy a cheap motor, and you'll be buying another one soon.
I suppose it's whether you want it sound like a jet, or fly like one.
Hope to see ya at The Ace in the Hole event (Vegas) in Oct.
We are hoping to debut the new all composite 70mm F-20 there. It should do about 120-130.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Sep 18, 2012, 07:17 AM
Joined Jun 2009
just ordered a CS10 fan for my Meteor
everything else is stock... anyone know how much Amp draw to expect on 4S?
Sold Larry Jolly "Meteor"-127" Kit NIB --Now $275 Shipped ldm1839 Aircraft - Sailplanes (FS/W) 5 Sep 29, 2010 05:34 PM
Discussion Meteor shower tonite, You goonna stay up for it? Bilbobaker Life, The Universe, and Politics 13 Aug 15, 2010 11:32 PM
Build Log Peter Rake's 30" General Western Meteor Prototype dz1sfb Scale Kit/Scratch Built 19 Aug 15, 2010 10:38 PM
Discussion Two Hours Outside and I only Saw One Perseid Meteor Chophop Life, The Universe, and Politics 12 Aug 12, 2010 07:28 PM
For Sale Russ Thompson Meteor fuse Bill L Aircraft - Sailplanes (FS/W) 0 Oct 15, 2009 09:18 PM
