Joined May 2010
Here's that Rc super powers guy "UNDER HAND LAUNCH VIDEO" DEMO FOR HAND LAUNCH IS 1:00 INTO VIDEO.....seems very easy for him..jet just goes nice an steady...
Joined May 2010
[QUOTE=iflyrc1012;22436820]we were talking about STOCK models, as they come out of the box. i'm sure any dog of a plane can be hand launched if you throw a $300 fan,e.s.c. and battery in it....[/QU
Checkout the video i just posted... His Meteor is all stock EDF with 4s pack under hand toss... It is shown at 1:00 mark ...I am sure his experience with rc edf's helps him make it look very easy
Joined May 2010
Australia, VIC, Melbourne
Joined Nov 2006
Yes, that Meteor hand-launch did look easy on even 4S !!
I just went and flew my Vampire at lunch-time.. hand-launch (70mm CS10 5S). It dropped the left wing as it left, and planes don't have anywhere near as much lift if at an angle(!!) so it dropped height fast.... so from a shoulder height launch, down to 30cm from the ground and I JUST got it level fast enough to reduce the drop rate and get it gain some more flight speed!! A definite co-ordination and 'calm under fire' test!! A tiny bit scarey.... it is the first time that happened to the Vampire. Which means it becomes assigned as a 'less than 100% assured easy launcher' now. LOL. There was a little bit of wind and I think I probably did not launch it exactly dead-on into the wind.... but a bit off leftwards. It more means: 1) Make more effort to get the wind head-on! 2) Give it a bit more 'push' so it has that little bit more instant flight speed. |
Joined May 2010
It has been around three week since i place order for vampire from HK..still waiting..i also have a 640 mm skyangel f9f coming i ordered from usa warehouse..which should be here by now...but i will fly the $65 f9f before the vampire... Know big deal for me i enjoy building these planes and looking at them nice...When i feel i'm ready i will maiden each and everyone of them..I may even use the stock wheels and take my vampire the old fashion way on a runway...My newphew spoted a bunch of guys flying around 15 mins from where i live again... this saterday i will get my butt out there early and hopefully make some friends that can help me maiden a plane or two...This hobby is okay on my own ,but it would be nice to fly with other people and learn as well....Can u tell me if meteor is harder to maiden then a vampire..? either hand lauching or using wheels...i know meters top speed is almost double the vampires,but maybe i could fly meteor slow untill i got used to it...The hobbyking has a plane almost identical to meteor its the 70mm green/white sport jet...PNP is $89...I was considering that one..it has excellent reviews and same flying characteristics as meteor...The meteor might have a slightly better power system,but not by much...could always drop a bigger esc in it if need be..i have plenty of them...thanks |
Joined Nov 2006
The Meteor off wheels is simple enough. A very well behaved, docile, "linear" flying plane. No surprises from it. The way it is put together you pretty well can't have a plane that is 'askew' (mis-aligned) for a 'veering off maiden' anyway. Thus success is highly likely!
I most often fly it off a cricket pitch (thus 22metres max) and I don't rush to WOT.... I build up, and probably only get to WOT in the last 5 metres, and it just flies off on its own - no up elevator really, or very little. That to get a realistic jet type take-off - not a 'sudden leap'. Even in original 4S setup it was totally fine to be airborne by the end of the 22m pitch. |
United States, TX, Whitesboro
Joined Jun 2011
every time i've handed launched mine, it always went wrong.. broke an elevator and cracked a aileron hinge.. but i havent tried a 5s yet, i should get her airborne way easy like that. Not sure if i should obove hand launch or go below yet, though some of this stuff yall are talking about is true im just so nervous about it. and i need to answer to this question about a motor im wanting to put in my meteor? Has anyone put a HET 1w-40 in there fan unit or any fan? would like to be using 5 or 6 cell batterys now and want to know more info about that motor
Joined Nov 2006
OMG!! LOL
http://en.wikipedia.org/wiki/Cricket_pitch They didn't include "Often used as a semi-scale runway for model aircraft" - somewhat like as if it was an aircraft carrier, or a bit smaller, relative to the model plane. So try LANDING on that!!!" |
Joined Nov 2006
That prior video and holding it from above, but launching upwards some angle, would be the best way to do it.
I find that over-hand (higher up) is worse because you just don't get the nicest view of it - it seems more useful to see the plane from above-rear as it flies off, for co-ordination purposes. Even though the initial height is lower. Plus it is harder to inject 'push' or 'throw' energy up higher. eg The Vampire has to be done with it held underneath (over-hand), and the extra height that you would think is a benefit, is actually lost in the way that you can't inject much motion into it in that manner. You can throw a ball (eg tennis etc) overhand better, but as objects get heavier, and larger, then there is a crossover point where underhand is the better result. Plus that co-ordination aspect. |
Joined May 2010
Pete,Thanks fo the info..i just recieved my first EDF from HK..Its skyangel F9F 50mm...620 mm wing span.. built and bench tested it last night...seems to have slight vibration ,but not sure since this is my first EDFand have nothing to compare it to... the fan housing was glued so i did not remove it..This little bugger screams..has lots of thrust takes small 1000 mah 3s...I should be getting vampire any day now...
| Thread Tools | |
| Sold Larry Jolly "Meteor"-127" Kit NIB --Now $275 Shipped | ldm1839 | Aircraft - Sailplanes (FS/W) | 5 | Sep 29, 2010 05:34 PM |
| Discussion Meteor shower tonite, You goonna stay up for it? | Bilbobaker | Life, The Universe, and Politics | 13 | Aug 15, 2010 11:32 PM |
| Build Log Peter Rake's 30" General Western Meteor Prototype | dz1sfb | Scale Electric Planes | 19 | Aug 15, 2010 10:38 PM |
| Discussion Two Hours Outside and I only Saw One Perseid Meteor | Chophop | Life, The Universe, and Politics | 12 | Aug 12, 2010 07:28 PM |
| For Sale Russ Thompson Meteor fuse | Bill L | Aircraft - Sailplanes (FS/W) | 0 | Oct 15, 2009 09:18 PM |
