Old Jul 06, 2012, 11:45 AM
Arcturus97 is offline
Find More Posts by Arcturus97
Retreating Blade Stall
Arcturus97's Avatar
United States, VA, Woodbridge
Joined Apr 2011
Originally Posted by kakofonixx View Post
just had an idea.......
I have two of these batteries:
http://www.hobbyking.com/hobbyking/s...idProduct=8357
of course I know these are hard case car lipos, have the for my 1:10 buggy
I connected them in parallel to act as a 4S lipo
total weight with connectors is ~490gr
Is this a heavy load for meteor to carry (on 4S) and stock setup?
You'll need to connect them in series, not parallel, to get 4S. Its a little on the heavy side but should work (IMO).
Arcturus97 is offline Find More Posts by Arcturus97
Old Jul 06, 2012, 12:07 PM
kakofonixx is offline
Find More Posts by kakofonixx
Ελλάς, Αττική, Αθήνα
Joined Jun 2009
yep in series, my mistake!
I've already done the connection and tested it, just mistyped the connection method
thanks for your answer
kakofonixx is offline Find More Posts by kakofonixx
Old Jul 06, 2012, 06:41 PM
jim12 is offline
Find More Posts by jim12
Take that runway!
jim12's Avatar
United States, AZ, Glendale
Joined May 2005
Originally Posted by TheCure View Post
I read good reviews on the HK airbrushes. Good bang for the buck I'm told. I'm sure with my pi$$ poor artistic skills the brush will out perform me.
Any idea what cost effective paints are best used airbrushing a foam plane?
I've been using this airbrush from Harbor Freight. Just down the street and low priced.
I've also had success with the "craft" paints in the small bottles at Walmart or Michaels. They go by different brand names but come in lots of colors and are about $1 each. Use windex or similar window cleaner to thin. Usually 50-50 or 1/3 - 2/3 paint to windex mix. As with most sprayed paints several light coats work best.
I'm going to try the wet paper masking technique. Good idea!
jim12 is offline Find More Posts by jim12
Old Jul 06, 2012, 08:57 PM
iflyrc1012 is offline
Find More Posts by iflyrc1012
no more glow models for me!!!!
iflyrc1012's Avatar
bklyn n.y.
not gonna be able to fly tomorrow, it's gonna be 105 degrees, and that's too much for me, so i'll wait for another day. not only is the heat bad for me.... but it aint good for the batteries,motor and e.s.c. either
iflyrc1012 is offline Find More Posts by iflyrc1012
Old Jul 06, 2012, 10:20 PM
Webmaister is offline
Find More Posts by Webmaister
I like Fast Warbirds
Webmaister's Avatar
United States, GA, Atlanta
Joined Nov 2011
Man, if you can afford it, you can get a WHOLE lot more bang for the weight (100 grams lighter) with this battery
http://www.graysonhobby.com/catalog/...ch-p-1634.html
Webmaister is offline Find More Posts by Webmaister
Old Jul 07, 2012, 02:03 AM
Joined Jun 2009
Of course this is a better solution, but I'm trying to use my existing stuff
Old Jul 12, 2012, 02:08 PM
Joined Jun 2009
after the successful maiden comes the painting!
here's my progress so far
The blue paint on the nose and canopy removed easily with white spirit
unfortunately the white spirit wouldn't work with blue paint of the tail!! so later I paint it over in white
Old Jul 12, 2012, 02:11 PM
Joined Jun 2009
and a small poll
which of the three alternatives you like the most for the wing trim?
Old Jul 12, 2012, 05:54 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
They all look great. SportJet-like.
I guess if I HAD to pick.... ummm..... NOT number one. Either 2 or 3..... ummm..... Number TWO ! LOL
PeterVRC is online now Find More Posts by PeterVRC
Old Jul 13, 2012, 03:38 AM
DeeCee 57 is offline
Find More Posts by DeeCee 57
Life's short - Enjoy!
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
very nice!
#2 is my favorite
DeeCee 57 is offline Find More Posts by DeeCee 57
Old Jul 13, 2012, 03:39 AM
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
and maybe I could send you a couple of Meteors for painting?
Old Jul 13, 2012, 04:46 AM
Joined Jun 2009
lol! you're very welcome DeeCee
Old Jul 15, 2012, 10:07 AM
Joined Jun 2009
just finished it
I'm too lazy to work more in this plane!
Old Jul 15, 2012, 05:47 PM
Joined Nov 2006
That looks great! And the bit of wing 'detailing' looks good too.
I think I would have filled out the rest of the rear top deck (green) to form around the fin base (like a sort of V of the fin base shape). The squared off ending to white looks a bit out of sync with the overall general patterns/theme.
That is one part that stands out to me right away as 'why is that there?" (white, square edged). But it isn't a fatal detraction at all.
And it looks fast too !!
Old Jul 15, 2012, 05:53 PM
Joined Nov 2006
I redid my main retracts.. their custom 'special offset pins'... as they were never quite pefectly aligned to the wheel wells I had made for the prior stock legs and wheels I had been using.
And I redid the nose gear with a 'proper' solid control arm and new oleo - because it would bend a bit every landing, and then not stter and retract quite perfectly - until you rebent it a bit
It was about time I fixed it all up to be solid and 'proper' in every aspect of the landing gear, so that it will all remain aligned and accurately operating ongoing..... unless a very bad landing or crash!
I still haven't decided what upgrade fan/motor system to use in it. I am juggling a bunch of option across two different aircraft. I was going to move to 6S but I am now thinking to remain at 5S, just with a bit more power..... but, not totally sure what to do yet.
It is pretty good as it is, so it is not something urgent to do.
Sold Larry Jolly "Meteor"-127" Kit NIB --Now $275 Shipped ldm1839 Aircraft - Sailplanes (FS/W) 5 Sep 29, 2010 05:34 PM
Discussion Meteor shower tonite, You goonna stay up for it? Bilbobaker Life, The Universe, and Politics 13 Aug 15, 2010 11:32 PM
Build Log Peter Rake's 30" General Western Meteor Prototype dz1sfb Scale Kit/Scratch Built 19 Aug 15, 2010 10:38 PM
Discussion Two Hours Outside and I only Saw One Perseid Meteor Chophop Life, The Universe, and Politics 12 Aug 12, 2010 07:28 PM
For Sale Russ Thompson Meteor fuse Bill L Aircraft - Sailplanes (FS/W) 0 Oct 15, 2009 09:18 PM
