Old Jan 19, 2011, 04:10 PM
FresnoJay is online now
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Stock this plane has been dopplered close to 90 mph or well at least mine has. Even with gear hanging down. I use 30C 2200's in mine at present and when I go 5S will be getting 3300 30C's as I would like more flight time to go with my speed boost. At present with my 2200's I fly for 3 minutes but stretch to 3:30 in emergencies. Best bang for the buck in this size plane. Dunno about hand launching as I dont plan on trying it .
Jason
FresnoJay is online now Find More Posts by FresnoJay
Old Jan 19, 2011, 04:46 PM
bigmoebbq is offline
Find More Posts by bigmoebbq
bigmoebbq's Avatar
United States, GA, Atlanta
Joined Mar 2008
That motor does not seem like it is that much better then stock.
http://edfhobbies.com/index.php?rout...&product_id=91
only 300 kv more. its it really a good upgrade ? It also says it may blow up on 5s?
Anyone tried these?
http://www.extremerc.com.au/estore/i...roducts_id=704
bigmoebbq is offline Find More Posts by bigmoebbq
Old Jan 20, 2011, 11:54 AM
Mizchief is offline
Find More Posts by Mizchief
Joined Dec 2010
Jason
Is that with the trust tube? (Saw from earlier post) When you put in the poster board did you make it the same thickness from motor to tail or did you taper it?
Mizchief is offline Find More Posts by Mizchief
Old Jan 20, 2011, 11:56 AM
Mizchief is offline
Joined Dec 2010
Has anyone had problems with the horzontial stab flexing or folding during flight? It looks really flimsy. I'm thinking about adding some carbon tape, anyone else mod this to be stronger?
Old Jan 20, 2011, 11:58 AM
bigmoebbq's Avatar
Joined Mar 2008
I have not modded mine at all. Only problem I saw was some flexing of the Wings at high speed.
Old Jan 20, 2011, 01:45 PM
Lambfries is offline
Find More Posts by Lambfries
Joined Nov 2010
Fresno,
Does the Meteor have a low voltage cut off? If so, will it allow you to restart the engine and maintain flight control so that you can bring it down safely? Also, would love to get this plane but have flight times more around 8-10 minutes with throttle management. Any suggestions on an appropriate battery? Thanks for all the posts. I am on the fence with the meteor or waiting for a Habu to come up on Hobb-e-mart for around 250.00.
Lambfries is offline Find More Posts by Lambfries
Old Jan 20, 2011, 01:59 PM
bigmoebbq's Avatar
Joined Mar 2008
Not sure about LVC. I run 4s 2650 packs with Throttle management I can get about 7+min. However it does make me real nervous and Throttle MGMT is just not as much fun
Old Jan 20, 2011, 02:26 PM
Joined Nov 2010
Thanks bigmoe,
Also, I have a Spektrum 5e tx and was looking at dropping a spektrum rx in. Does it require a 6 channel or can I get away with 5 ch? Also, if down the road I want to add retracts, how many channels do I need? Sure that will answer my question of how many channels to go with? Sorry for the newb questions.
Thanks!
Old Jan 20, 2011, 02:34 PM
bigmoebbq's Avatar
Joined Mar 2008
Stock you will need 4 channels I believe. when you add retracts it will depend on if you are going to use a Y-harness or something similar. but I would think that would add at least 2 more channels. 1 for wings 1 for Nose. Get a better radio then spring for retracts. A better radio will last you a lot longer.
You can pick up some nice used dx7's these days pretty cheap. Then you will have more channels and mixing options to play use.
you can probably get it to work with a dx5 but I think that model only allows for 1 plane to bind at a time. Huge hassle to setup more planes.
Old Jan 20, 2011, 03:50 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
As to the thrust tube yes my speed dopplered was with thrust tube. It is tapered from the fan to the 80% FSA exit. I have a foam donut at the exit to help hold and stabalize the tube.
As far as a 4S pack I would say the stock size of 2650mah or there abouts is the right size for a good 5 min flight. You could go up to 3000mah but any bigger and I feel it would be deminishing returns.
LVC on the ESC will allow you to maintain control and re-arm the motor. But the ESC default LVC is WAY to low IMHO. You can reprogram it to the higher LVC using any Turnigy Plush/HobbyWing Pentium programming card or stick programming instructions. This is what I did and my LVC is currently set to 3.1 or 3.2v per cell which is the highest these ESC's come with. But at that voltage give you enough to get it back easily. I have done it a few times being to generous during my flights.
Jason
Old Jan 20, 2011, 04:17 PM
Helgeo is offline
Find More Posts by Helgeo
Norway
Joined Dec 2004
Originally Posted by Lambfries View Post
Thanks bigmoe,
Thanks!
5 channels is enough with retracts. Use two Y-harnesses for the retracts.
These are the channels:
- Throttle
- Elevator
- Ailerons (2 servos using Y-harness to single channel)
- Rudder (2 servos using Y-harness to single channel)
- Retracts (3 units tied together using two Y-harnesses)
I have a Hobby City 6ch Orange Spektrum compatible RX in mine, works great. Im using a separate channel for my thrust vectoring so all 6 channels will be occupied when I add retracts. I hope the stock ESC will supply enough power to all this equipment on a 5S pack?
Helgeo is offline Find More Posts by Helgeo
Old Jan 20, 2011, 05:41 PM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
can you all tell me what size ESC this plane comes with? it does not state on the nitroplanes website and of course their live chat person couldnt figure it out either.
nevermind, I found it on Graysonhobby website, 60A.
nickelbn1 is offline Find More Posts by nickelbn1
Old Jan 20, 2011, 06:16 PM
smasher41 is offline
Find More Posts by smasher41
United States, GA, Snellville
Joined Nov 2005
I added carbon fiber strips under the elevators as it did seem to flex under high stress.
between that and adding the RTV down the wing/fuse joint it seems to have made a huge difference in stability for me.
smasher41 is offline Find More Posts by smasher41
Old Jan 21, 2011, 02:35 AM
CSI is offline
CSI
Find More Posts by CSI
CSI
I promise, just ONE more order
CSI's Avatar
Del Rio Intl, Texas, United States
Joined Feb 2004
The big brown truck rolled up this evening and it was time to get excited! Wow, huge box containing my Meteor EDF. I've been pacing all week to get this for my weekend project. The box looks perfect, so I open it up, remove the kit box, then start opening up the Dynam boxes containing the airframe parts.
Hummm, funny that Dynam just tosses the parts in the boxes without any padding...not even newspaper? My A-10 came that way too???
Out comes the wing, darn, a couple of gouges and some area of scratches. Out comes the fuselage, oh wait, it's snagged on something. I see it, it's the EDF unit dangling by the wires to the esc. It appears the EDF unit has had a field day banging into the fuselage all the way from China. The canopy is completely smashed in, the sides of the fuselage look like the were bashed in all over by a sledgehammer. Deep gouges all down the top and sides.
Nice job Dynam. Like I said, no packing material at all, yet the shipping box was in perfect shape. This sure put a damper on my weekend. I know this foam is extra durable and all, but geeze, it's not steel!
The email to Nitro has been sent, waiting on reply with RMA number. Now the hassle of reboxing, shipping, etc.
Has everyone else's arrived in great shape, even without packing?
I'm sad.............
Ken
CSI is offline Find More Posts by CSI
Old Jan 21, 2011, 06:22 AM
Mizchief is offline
Joined Dec 2010
The packaging is terrible. There is nothing inside to prevent crushing during shipping. My canopy was crushed, but luckily was able to pop it back into place.
Sold Larry Jolly "Meteor"-127" Kit NIB --Now $275 Shipped ldm1839 Aircraft - Sailplanes (FS/W) 5 Sep 29, 2010 05:34 PM
Discussion Meteor shower tonite, You goonna stay up for it? Bilbobaker Life, The Universe, and Politics 13 Aug 15, 2010 11:32 PM
Build Log Peter Rake's 30" General Western Meteor Prototype dz1sfb Scale Kit/Scratch Built 19 Aug 15, 2010 10:38 PM
Discussion Two Hours Outside and I only Saw One Perseid Meteor Chophop Life, The Universe, and Politics 12 Aug 12, 2010 07:28 PM
For Sale Russ Thompson Meteor fuse Bill L Aircraft - Sailplanes (FS/W) 0 Oct 15, 2009 09:18 PM
