Canada, BC, Burnaby
Joined Oct 2010
battery on Habu 3300mah 40c 5s
battery on meteor 3000 20c 5s 2:10 over head inverted pass
habu vs cameraman
Luke flying hes meteor
Norway
Joined Dec 2004
Any pictures of your pushrod setup PeterVRC? I have a retract kit waiting to be installed.
I have also ordered a new fan and motor for mine: http://www.hobbyking.com/hobbyking/s...Fan_Unit_.html Getting the recommended 2300 kV motor, it should work well on 5S even if it is rated for 4S only. Not sure if it will be more powerful than stock, but it is supposed to sound really good
I'd love to see and hear the results of your powerplant change. I was thinking to eventually do the same. |
Australia, VIC, Melbourne
Joined Nov 2006
80 Amps! For 4S, and on the stock motor?
I would be thinking more like 40A - 50A area or so, for the stock fan. And maybe a bit more off a better fan. Then maybe a bit more if 5S. Would probably need 6S for 80A. If it is 80A, it would want to be ballistic speed! LOL I can't remember what I measured 4S at (all stock), I will have to test 4S and 5S again... |
Sydney Australia
Joined Sep 2003
For my second meteor I have the same motor but only 2500 KV. I have not flow it yet as I am fitting retracts and still need to finish the steering. |
Joined Nov 2006
Retract pics:
I have two plywood plates because the original retract mod had the retract mounted at its 'outer aircraft' portion, so that mount was a different height to the servo mount. But doing it like these pics means one plate could be made to do both jobs. The wheel retracts in almost totally flush to the body. To get it fully flush (or more) just bend the leg 'backwards' a few degrees, soon after it clears the retract motor body. Or use a smaller wheel. Or mount the retract deeper down into the fuselage. The front retract is a HKD-312 22g retract. The rears are HK-5094 18g units. That rears were smaller so that the retract 'height' can fit within the wing thickness, and the 18g are fine anyway - more so because there stresses are sideways to them, not along the worm drive mechanism, and they are stronger in that sideways direction. Both retract types have 3mm leg holes, but they can clamp 2.3mm legs (original rears) fine anyway. The HKD-312 uses 3mm grub screws to clamp the leg inserted, and the HK-5094 use 2mm grub screws for that. (I use 2, 1 for each trunion bush side). Grind flats onto the legs so the wheels can't rotate away from their correct direction. Using the original rear landing gear legs is not really great - it is ok for hard runways, but too soft for grass and they will bend backwards a bit, and then the wheels can't retract into the cutout anymore. It is easy enough to make up some 3mm legs instead, with coils (2 or 3) if you want some shock absorption (I have been too slack so far!). Nicer would be to use 3mm mini legs, made just long enough to feed into oleo legs with suspension. And the front could use a suspension oleo too. I will check that out soon, as I have quite a few types of roughly suitable size alloy leg/wheel assemblies around. |
Joined Nov 2006
Oleo options:
The trailing arms types are generally better to absorb bumps in a more useful fashion, so they are good on all surfaces. The cheaper set, though made well, are telescopic so they are far better suited to hard runways. |
Norway
Joined Dec 2004
Fantastic pictures PeterVRC, thanks a lot
Does it retract OK if you have some rudder input or do you use a separate channel for the front steering with a mix that centers the front servo when retracting? As for the 10 blade fan, it must have a lower kV motor, I assume this fan has higher pitch on the blades than the stock fan does. I'm hoping that the 2300 kV motor will be a good match for it on 5S. |
| Thread Tools | |
| Sold Larry Jolly "Meteor"-127" Kit NIB --Now $275 Shipped | ldm1839 | Aircraft - Sailplanes (FS/W) | 5 | Sep 29, 2010 05:34 PM |
| Discussion Meteor shower tonite, You goonna stay up for it? | Bilbobaker | Life, The Universe, and Politics | 13 | Aug 15, 2010 11:32 PM |
| Build Log Peter Rake's 30" General Western Meteor Prototype | dz1sfb | Scale Electric Planes | 19 | Aug 15, 2010 10:38 PM |
| Discussion Two Hours Outside and I only Saw One Perseid Meteor | Chophop | Life, The Universe, and Politics | 12 | Aug 12, 2010 07:28 PM |
| For Sale Russ Thompson Meteor fuse | Bill L | Aircraft - Sailplanes (FS/W) | 0 | Oct 15, 2009 09:18 PM |
