Old Jan 04, 2012, 12:30 PM
lowkeylaidback is offline
Find More Posts by lowkeylaidback
Custom Crasher
lowkeylaidback's Avatar
USA, FL, Jacksonville
Joined Jan 2010
Thanks for that information!
lowkeylaidback is offline Find More Posts by lowkeylaidback
Old Jan 07, 2012, 10:37 PM
miller6196 is offline
Find More Posts by miller6196
miller6196's Avatar
United States, OH, Louisville
Joined Dec 2008
modded meteor
here are some pics of my meteor.I painted it with testers spray can (flat olive drab),added a parkflyerplastics cockpit kit and wing tank kit.just a little paint makes it look alot different.i added a yoke,heads up display and ejection rings to the kit also.
miller6196 is offline Find More Posts by miller6196
Old Jan 07, 2012, 11:40 PM
topher39 is offline
Find More Posts by topher39
Cottonwood Arizona
Joined Aug 2003
Miller, nice job! What cockpit kit did you use? I dont see one at park flyer . . .
Your input would be great.
Topher
topher39 is offline Find More Posts by topher39
Old Jan 07, 2012, 11:44 PM
Kevin Greene is online now
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Topher
Military cockpit for the Habu.... http://parkflyerplastics.com/cart/in...roducts_id=450
Kevin
Kevin Greene is online now Find More Posts by Kevin Greene
Old Jan 07, 2012, 11:47 PM
miller6196's Avatar
Joined Dec 2008
yep.habu.you will have to hak it up just to use the pilot,the canopy works perfect as is.the pilot will be attached to the detail tray that covers the entire hatch of a habu.the habu is wider so the tray will not work at all.
Old Jan 07, 2012, 11:48 PM
miller6196's Avatar
Joined Dec 2008
i also added the air hose to the mask.shrink tubing works great for that.
Old Jan 07, 2012, 11:51 PM
miller6196's Avatar
Joined Dec 2008
the yoke is a 440 ball link that i snipped with side cuts and formed it with a dremel then painted
Old Jan 07, 2012, 11:52 PM
miller6196's Avatar
Joined Dec 2008
the ejection rings are black electrical wire that i cut and bent then just glued to the seat.
Old Jan 09, 2012, 02:24 PM
Custom Crasher
Joined Jan 2010
Why?????
Why does a great out of the box flyer like this .....just go away?? No place to buy it, no place supports a full set of parts for it and at the height of its popularity it just went poof!
Old Jan 09, 2012, 03:05 PM
topher39 is offline
Cottonwood Arizona
Joined Aug 2003
Grayson Hobbies
Old Jan 10, 2012, 06:59 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
That looks great Miller !!!
Oh dear... now yet another project for me to do! Glamorise the Meteor!
I was sort of happy with it as it was, but after seeing that transformation I won't be happy with it as it is now!
What did you do to prep it? Just a rub down with fine wet&dry? Or some "chemical peel", or also? What is the Testers paint base, oil? And does it need any undercoat process?
And the final important questions.... does it take well, rock solid adhesion? And is it very tough? (can't be worse than plain foam).
I have my retracts all done, and they work great - pretty well as perfect as I would like them to be. Pull-pull cables are somewhat painful, until I figured out a nice way to set them up for easy adjustment.
So it took a fair amount of time for the nose-gear part - a lot of thinking time - whilst the mains were very easy and quick. But after solving this Meteor retract puzzle I should be able to upgrade any plane with retracts much easier now.
So I have my A-10 and F9F Panther to complete their retract jobs. Both those using the same HK bits for the job. But the next nice morning it is "Meteor with retracts fly day" !! Which incorporates the "Meteor on 5S fly day" too, so I will get to kill two birds with one stone.... or one bird with two stones? (retract or 5S failure....). Well, 4S flights first, then on to the 5S....
And if all goes well with those tests.... into the paint shop this weekend or next!
PeterVRC is online now Find More Posts by PeterVRC
Old Jan 10, 2012, 11:48 AM
miller6196's Avatar
Joined Dec 2008
no prep what so ever.any color testers will adhere perfectly.if you wipe it down with anything just use water to clean after sanding if you desire.i didny sand anything and it looks decent.the cells in the foam dont look nearly as pronounced when there painted so sanding is not necessary.if you start sanding, be prepared becuse it will take a very fine grit to get the scratches out of that foam.take it from me,leave it as is.wipe it clean with a moistened cloth of water and shoot it.will take at least 2coats of paint to cover.you can use multiple colors by using blue 3m painters tape to mask over previous colors. thanks for the compliment.
p.s. here is a pic of a little flycat that i converted to estes rocket power that launches of my kadet sr.i painted it black first,then cut out the zig zags out of the blue painters tape and stuck them on.then painted the whole plane olive drab.let it dry the peel the zig zags off.
Old Jan 11, 2012, 06:27 AM
huntingfield is online now
Find More Posts by huntingfield
Clean up! The missus is home
huntingfield's Avatar
United States, MD, Salisbury
Joined Dec 2007
I maidend my meteor yesterday and have to say it's a supurb flying plane. I screwed on some backup plates to the elevator torque rod attach points, cleand out a little bit of foam around the control horns, moved the rod to the outer hole on the elevator servo horn. All this got me 12mm up and down movement. On take off this plane requires very little up to get airborne. Throughout all of my flights I found the elevator throws fine. For landing the rate of decent can be controlled very effectively by the throttle all the way to touchdown. This is a fine plane and handles a bumpy grass field fine. I would like to know how you other meteor owners do your hand launches.
huntingfield is online now Find More Posts by huntingfield
Old Jan 11, 2012, 07:44 AM
Joined Nov 2006
Yeah, the landing gear wires and the nice wide wheels make for great ground handling over anything up to quite rough terrains. So I kept the main gear wires, and all 3 wheels, in my retracts mod. I'll have to make up a video on the whole process soon. Though I have worked out an even better nose-gear mount system - too late for me to use now - which would have made it all a lot easier, plus that new way has solid pushrod connection rather than pull-pull wires. Probably re-inventing the wheel anyway, but I wish I had known it (more) before.
Miller, that Flycat looks great too! Even in pics don't really show the details you can see in real life. So you have obviously worked out (or knew) how to paint these things well.
I am itching to paint up my Meteor, but after I get it through its few test flights. Which the terrible weather here at the moment is delaying....
And the puzzle/decision.... what colour scheme to do????
That Olive Drab you used looks good, but maybe that as a base with a contrast green for the typical 'military splotchy camo' look. Or..... all grey, with some form of contrast colour (ie tips etc in red, or orange, or stripes etc), or even a base grey with camo splotch contrast grey, or green, or blue.
It feels like it would need some "Military paraphenalia" added too, like your tip tanks, and possibly missile pods (and/or missiles too) for it to pull off the military look properly. Becoming a bigger project than just painting....
Old Jan 11, 2012, 09:20 AM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Congratulations on the maiden.
Mine was (I'm about to return it to stock for selling) a 5S HET/Wemo setup but underarm toss and away she goes.
They are a great flyer but I've got to make room for some other projects.
Goody63 is offline Find More Posts by Goody63
Sold Larry Jolly "Meteor"-127" Kit NIB --Now $275 Shipped ldm1839 Aircraft - Sailplanes (FS/W) 5 Sep 29, 2010 05:34 PM
Discussion Meteor shower tonite, You goonna stay up for it? Bilbobaker Life, The Universe, and Politics 13 Aug 15, 2010 11:32 PM
Build Log Peter Rake's 30" General Western Meteor Prototype dz1sfb Scale Kit/Scratch Built 19 Aug 15, 2010 10:38 PM
Discussion Two Hours Outside and I only Saw One Perseid Meteor Chophop Life, The Universe, and Politics 12 Aug 12, 2010 07:28 PM
For Sale Russ Thompson Meteor fuse Bill L Aircraft - Sailplanes (FS/W) 0 Oct 15, 2009 09:18 PM
