This thread is privately moderated by bighead93, who may elect to delete unwanted replies.
Old Mar 14, 2011, 08:38 PM
snivilous is offline
Find More Posts by snivilous
High Altitude Specialist
snivilous's Avatar
Joined Jan 2010
Originally Posted by biggy boy View Post
I have been eye balling the Jetiger.
Nitroplanes sells them and so does Hobby King.
I'm wondering if they would be a good next step after some flying experience with a Stryker "C"
http://hobbyking.com/hobbyking/store...dProduct=10358
Glen
Looks cool, not hip on the how the rudders connect, fast hook up but more drag and stuff. I would think you would be able to fly it fine if you can fly the Stryker. It should fly almost identical since the Stryker doesn't have blown surfaces either, there both deltas, no blown surfaces, non-moving rudder, and twin rudders, if you wanted to go with a different style of EDF you could I would think.
snivilous is offline Find More Posts by snivilous
Old Mar 14, 2011, 08:57 PM
biggy boy is offline
Find More Posts by biggy boy
prop wash
biggy boy's Avatar
North of Toronto in Ontario
Joined Dec 2002
Thanks snivilous
I kind of figured it may be a good next step.
I'll wait to see what others say about it.
Glen
biggy boy is offline Find More Posts by biggy boy
Old Mar 14, 2011, 09:10 PM
snivilous's Avatar
Joined Jan 2010
Thanks snivilous
Glen
Honestly, as I said, I am 99% sure you will have no trouble with it. I will never say a plane gets boring to fly, but I think it will feel...redundant to your Stryker (assuming that's still alive). Kinda like what's the point of having two of the same airplane (more or less).
Old Mar 14, 2011, 09:37 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
Ya it's still alive LOL, but did get away on me today and I did have a forced landing.
But that was my fault for not checking the trim slider setting for the elevator before chucking it into the air.
OK ya I could see how it may be redundant.... in looks and flight characteristics.
Any other suggested jets?
Glen
Old Mar 15, 2011, 10:18 AM
snivilous's Avatar
Joined Jan 2010
Everyone says the foam Habu works really well, I have personally never seen or flown it but it's reported to be a good first jet. Hobby-Lobby has a lot of good, cheap, foam EDFs. Honestly, from what I've seen of the Stryker, and as I said, since it doesn't have blown surfaces (like an EDF), I think you could choose any EDF and do well with it. Mainly I would recommend something without thrust vectoring (though I'm sure you would be fine with it) and something with wheels, since it seems EDFs have a harder time accelerating than standard aircraft for hand launching (just to be safe I'd go with wheels, either way).
If you want something cheap that IS a hand launch the JPower 50mm EDFs are good and can be really sooped up (Toysonics, NitroPlanes, BananaHobby distribute them).
Then there's always the Phase 3 F-16 and Squall (one of my favorite EDFs), both are hand launch (though nice big intake to throw from, really easy), both have lots of power stock, both can be upgraded a lot also, etc.
Overall, I would suggest the Phase 3 F-16 (distributed by HobbyPeople.net), they come as ARFs with motor, fan, and esc, so you would need servos, rx, and battery.
Hope this helps.
Old Mar 15, 2011, 11:33 AM
prop wash
biggy boy's Avatar
Joined Dec 2002
Thanks very much for the info snivilous!
The Phase 3 F-16 does seem nice, watched a bunch of YouTube videos....
Glen
Old Mar 15, 2011, 11:44 AM
restlessswind is offline
Find More Posts by restlessswind
restlessswind's Avatar
United States, CA, Sacramento
Joined Jan 2010
+1 on J-power 50mm. The T-45 is a really easy flying and visually orientation jet (compared to most others) It comes with quick-release landing gear (non-steerable). It's only $60 right now at Banana. Just need a RX.
I have the Habu. It's a lot of $$ to get started with 70mm jets. Batteries and repairs get costly. Need a ton of landing and approach space.
I don't doubt the Phase 3 EF-16 as a good choice either. I never got it because of the complaints of the elevators tearing off on less than perfect landings.
restlessswind is offline Find More Posts by restlessswind
Old Mar 15, 2011, 12:06 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
This one?
http://www.bananahobby.com/2078.html
It's not $60.00
Glen
Old Mar 17, 2011, 12:38 AM
Joined Jan 2010
My bad. The L-39 and AMX is $60.
Anyway, the Airframe only kits are the better way to go (and only $30) if you don't mind a little solder and glue. You can remove the paint on the glue surfaces to adhere much better.
Get a 30A Volcano ESC (Pentium rebrand) for $13, a couple of SG-90 servos for $3 ea, & a couple Skylipo 1000 3s 40c f $8 ea rom Hobbypartz (all free shipping).
It's really not that hard. You need to shorten the motor wires and lengthen the battery wires on the ESC, use smaller battery connectors and change to 3.5mm bullet connectors to stock motor (Yes, it really comes with a motor even though the description says it doesn't.) I'm getting about 240-250W with this setup. (motors vary slightly from one another)
Old Mar 17, 2011, 02:34 AM
sonny1 is offline
Find More Posts by sonny1
Kool Kats Fly RC!! AMA 30462
sonny1's Avatar
United States, CA, Baywood-Los Osos
Joined Feb 2009
Checked out BH after reading your posts, and I've heard both good and bad about them, however those "airframe only" kits seem like a great deal. They do mention "50mm edf included", and the videos of the F-86 and F-16 are convincing of the plane's flyability, (the videos are on the page with the rxr versions of the planes which cost $69.90). An issue for me though is that the shipping seems a bit high, cheapest is $13.68, (which includes a "handling" fee. I just got a Phase 3 EF-16 "airframe only" from Hobby People for $40 + $5 to ship). That brings the ultimate price of a $30 "sale" item to nearly $50 w/ sales tax; hmmmm, that "great deal" dwindles a bit........still a temptation, and so many to choose from.
Sonny
sonny1 is offline Find More Posts by sonny1
Old Mar 17, 2011, 07:09 AM
prop wash
biggy boy's Avatar
Joined Dec 2002
Thanks, that looks like the way to go, just get the kit.
Glen
Old Mar 17, 2011, 07:38 PM
Joined Jan 2010
If you buy 2 or more, shipping is much more reasonable. Can always get an extra.
There is a very big thread on here about these jets. http://www.rcgroups.com/forums/showthread.php?t=1158665
RCG member, The Don of Don'sRC.com even sells hot-rod motors and fans to push these little guys over 100mph.
Old Mar 17, 2011, 11:21 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Thanks for that tip on the shipping, and the fact that "The Don" makes upgrades for them lends credibility to them. The combined shipping makes it a little more attractive, but I still think the "flat rate" shipping costs, especially when compared to other retailers is a bit high.
Sonny
Old Mar 18, 2011, 12:02 AM
Joined Jan 2010
Sonny
I agree that the shipping cost is too high... But I also realized that they are cheaper than the competition.
They have some of these at :
http://www.toysonics.com/edf-jet/
http://shop.hobbyshopwarehouse.com/5...F-JETS_c18.htm
http://www.venom-group.com/storeitem...ion=Air#gpJets
http://www.nitroplanes.com/69a05-50-...o-battery.html
http://www.okhobby.com/product.php?id_product=1564
http://www.hobbyking.com/hobbyking/s...dProduct=13427
http://www.aliexpress.com/product-gs...olesalers.html
And I noticed someone sells them for crazy prices on Amazon.com LOL
http://www.amazon.com/Inexpensive-Bl.../dp/B003H2798Y
Old Mar 18, 2011, 12:35 AM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Yes, I see that; thanks for the links. I admit it's still a decent deal, but when I see the word "handling" in any shipping quote, it sets my radar off; "handling" charges are deceptive marketing in my opinion. I notice also that they only offer UPS shipping to the CONUS, and only ship USPS to Hawaii, Puerto Rico and Canada; a major reason for their higher shipping rates IMHO, (plus the "handling" charge which goes straight into their pockets).
Sonny
Help! Check List before Flight aoliveiraneto Beginner Training Area (Fuel) 12 Nov 05, 2015 01:21 PM
Discussion Do you check for loose pieces of paper in your surroundings before you fly? Samay Micro Helis 7 Oct 20, 2014 04:47 PM
Question Reality check before I buy please xcr600 Power Systems 7 Jan 05, 2010 09:32 AM
Alert ALWAYS check here before you buy on line! CactusJackSlade Aerial Photography 7 Nov 21, 2007 11:53 AM
