I have a 300C that seemed a bit down on power and was getting more gitches. I've recently been flying my Beav with a faster, heavier wing and a 10X8 prop so asking for way more amps. Last night I switched back to the stock wing and the 10X47. It flew just fine. Brushes may be almost done I think. It has around 1100 minutes (18 hours) on it.
WEST KY
Joined Mar 2003
IPS DUAL 4.8D
I run several IPS dual D drives on 2c E-tec 1200 lithium with a 12x6 prop. I had 16 hours loged when it started to need more power than usual to hover my sulkayln (lookalike). I poped the rear motor housing off and the brushes were wore out to the metal holder. The 2nd motor still had some brushes left.
I have about 15 hours on another on and it is still O.K. At 22.00 a piece I say 15 hours is good enough for me. I pull about 4 amps in a hover, don't run very much over that 1/2 stick mark. I also run heat sinks but can't say they have helped. Brandon |
| Thread Tools | |
| Discussion How do you know when your main motor is going on a HBFP? | mdavenport | Micro Helis | 8 | Mar 19, 2007 06:10 AM |
| Dumb question: How do you know when your batteries have had it for the day? | steve crewdog | Radios | 4 | Sep 04, 2005 05:55 AM |
| How do you know when a motor is bad?? | jacksonjrs | Power Systems | 9 | Feb 20, 2004 05:09 PM |
| how do you tell when your motor's going bad | waagbuck | Parkflyers | 10 | Sep 23, 2002 09:21 PM |
| How do you know when a battery is low? | Phoenix-IT | Electric Heli Talk | 8 | Jan 26, 2002 12:24 PM |
