Australia, NSW, Bungendore
Joined Jan 2005
Craig - the wing is certainly complicated - esp. as I'd like to make the slats work..........but that is wa.....ay down the track!
Why do I like the Lysander? It has a certain appeal - great gawky undercarriage, impossibly shaped wing (it tapers in EVERY direction from the strut attachment point) that bulbous nose and carrot body, plus for me, the great visibility of almost everything inside the crew spaces! That visibility deters a lot of modellers as it is not alwyas easy to simply whack on a moulded canopy, The Mizer model has sliding side, top and rear glazing and most importantly, the highly visible centre pylon is of scale structure albeit of wood not duralumin but more of that later. The pilot sits several feet above the fuselage bottom and there is no floor so every strut, brace, longeron and stringer can be seen below his feet! Lovely ![]() This means of couse, that all this framing detail stuff has to be added before any external sheeting, stringers or covering. It really appealed to me. I have long been looking to build a model that was 1) a little different 2) a challenge in contruction 3) plenty of detail info available 4) could be built like the real aircraft 5) not too large in scale. This Lizzie at around 1:7 (similar to Peter Rakes Brisfit) was ideal. I'd collected many books on the type and have spent countless hours coming to grips with it's internals - I had a good plan, plenty of references and a fascination with the type. Selecting a specific prototype was harder. The Special Duties (SD) model has been done to death, The Canadian Target Towing (TT) version flew recently and although the stripes intrigued me, was a bit too 'In your face' for me and I rather like the battered camouflaged WW2 look. Then I found a mixture! The MKIII TT Lysanders were used as target tugs for gunnery training in Britain during WW2. They had black and yellow stripes underneath, Earth and green camo on top, some still retained the auxilliary winglets and bomb racks plus they were operated by US forces in Britain, the RAN, as well as the RAF! Done deal More waffle later... Pat |
Latest blog entry: A Big Move.....
Joined Jan 2005
Hugh - I've heard that comment from a few who've built the Nijhuis version. Maybe the ic model is a bit heavy. Best tip I've heard is to fly a Lysander like a bomber - not a screaming warbird! And not to try flying it too slowly without power. The real machine had automatic flaps and slats (they were actuated by airspeed and AOA - not even a flap lever in the cockpit. Also a variable incidence tailplane to help. None of this is easy on a model. The flight manual states that any aerobatics are illegal! - sounds like my sort of competition flyer - no rolls, loops, stall turns, spins etc.
![]() Off to the dreaded hospital.... Pat |
I see that Pat takes breaks from modelling like I do. The mind just never stops churning, does it? A bloke in my club is currently building a Lizzie, but it will be of the overweight smelly glow variety. Trumps - Tim Hooper did a Wendover a few years back. How to make the ugly uglier!
Joined Jan 2005
Frank - I'm not currently modelling but am posting some pictures and thoughts in slow time - just to keep 'on the radar'
![]() Craig, That Canadian Lysander - Chris Rebidoux from Canada spent a great time climbing all over that machine and sent me a CD with a hundred or mor pictures on it! Very helpful. Here's one showing some controls on the left side of the cockpit - the flap lever slot is there but I've never seen a Lysander with a lever! Maybe a MKI had manual flaps. Pat |
| Thread Tools | |
| Discussion Westland Lysander - small semiscale foamie (98cm/38.6") | McElk | Foamies (Scratchbuilt) | 10 | Nov 29, 2010 11:10 PM |
| Discussion Westland Lysander | denbourg | Scale Fuel Planes | 3 | Jun 19, 2010 07:26 PM |
| Build Log Kit/Plan Fun Build Contest - Easybuilt Westland Lysander | jofrost | Scale Electric Planes | 173 | Jun 04, 2008 06:32 AM |
| Metasequoia Westland Lysander | Looooeeee! | Parkflyers | 14 | Oct 28, 2002 09:54 AM |
| Westland Lysander | Charles | Scale Electric Planes | 6 | Apr 26, 2002 08:46 AM |
