Old Sep 09, 2010, 04:20 PM
jmgm is offline
Find More Posts by jmgm
Joined Sep 2010
stick 40 plus kit. (balsa usa)
hola saludos me presento soy nuevo en el foro y quisiera saber una configuracion electrica motor, baterias, variador para el stick 40 plus de BALSA USA. muchas gracias y saludos a todos los pilotos desde Espaņa
jmgm is offline Find More Posts by jmgm
Old Sep 11, 2010, 02:54 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Translated to English by Babelfish:
hello greetings I appear I am new in the forum and I would want to know electrical a configuration, batteries, variador for stick 40 motor extra of BALSA USA. thank you very much and greetings to all the pilots from Spain
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Sep 11, 2010, 02:56 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
I believe this is the plane you are talking about.
BALSA USA
Stick 40 Plus
The Stick 40 Plus was designed with ailerons and is the deluxe version of the Stick 40. Simple to build, tough, and great flying characteristics make the Stick 40 Plus one of the best "Fun Flyers" you can own. The instruction book contains over 80 photos to guide you through every step of the construction. The 4-channel Stick 40 Plus may be perfect for your first R/C model.
Weight
5 to 5-1/2 lbs. Wing Span
58" Wing Area
600 Sq. In. Engine
.30-.40 2-stroke
.40-.60 4-stroke Length
43" 4 Channel
Kit No.434
Old Sep 11, 2010, 03:16 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Based on the above, here is one possible configuration. Notice that I selected an inrunner motor with a gear box. I did this because I think it will be easier to mount one of these to the plane with a clamshell mount than it would be to mount an outrunner.
The following is a quick run through Motocalc.
MotOpinion - Untitled
800ft above Sea Level, 29.92inHg, 56°F
Motor: Hacker B50 10S; 3640rpm/V; 2.7A no-load; 0.009 Ohms.
Battery: Zippy Flight Max 4000 (20C) (20C); 4 cells; 4000mAh @ 3.7V; 0.008 Ohms/cell.
Speed Control: Castle Creations Phoenix 45; 0.0026 Ohms; High rate.
Drive System: APC 13x8 Electric; 13x8 (Pconst=1.08; Tconst=1) geared 6.7:1 (Eff=95%).
Airframe: BALSA USA Stick 40 Plus; 600sq.in; 82.9oz RTF; 19.9oz/sq.ft; Cd=0.055; Cl=0.32; Clopt=0.62; Clmax=1.11.
Stats: 83 W/lb in; 70 W/lb out; 22mph stall; 29mph opt @ 67% (37:32, 82°F); 41mph level @ 90% (21:08, 91°F); 1260ft/min @ 29.3°; -313ft/min @ -7°.
Possible Power System Problems:
The full-throttle motor current at the best lift-to-drag ratio airspeed (28.5A) is lower than the motor's maximum efficiency current (64.4A). A higher current level would improve system efficiency.Current can be increased by using more cells, a larger diameter or higher pitched propeller, a lower gear ratio, or some combination of these methods.
Power System Notes:
The voltage (13.7V) exceeds 12V. Be sure the speed control is rated for at least the number of cells specified above.
Aerodynamic Notes:
The static pitch speed (55mph) is within the range of approximately 2.5 to 3 times the model's stall speed (22mph), which is considered ideal for good performance.
With a wing loading of 19.9oz/sq.ft, a model of this size will have trainer-like flying characteristics. It would make an ideal trainer, for use in calm to light wind conditions.
The static thrust (72.9oz) to weight (82.9oz) ratio is 0.88:1, which will result in very short take-off runs, no difficulty taking off from grass surfaces (assuming sufficiently large wheels), and steep climb-outs. At the best lift-to-drag ratio airspeed, the excess-thrust (40.6oz) to weight (82.9oz) ratio is 0.49:1, which will give steep climbs and excellent acceleration. This model should be able to do consecutive loops, and has sufficient in-flight thrust for almost any aerobatic maneuver.
I hope this helps.
Cheers,
Wiz
Old Sep 11, 2010, 06:04 PM
jmgm is offline
Joined Sep 2010
thank you very much by the wonderful information forum good flights
Old Sep 16, 2010, 10:00 AM
jmgm is offline
Joined Sep 2010
that type of large stone bench makes lack to put the electrical motor to him to stick 40 of raft it uses you can send photo to me of the large stone bench
Old Sep 16, 2010, 02:07 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
I'm having difficulty understanding exactly what you wrote. I think something didn't work well in the translation.
I hope these pictures are good enough to describe the method for mounting the motor that I think you will need to use with the Balsa USA Stick 40.
Old Sep 16, 2010, 05:15 PM
jmgm is offline
Joined Sep 2010
oh yes very good thank you regards
Old Sep 17, 2010, 05:45 AM
jim e is offline
Find More Posts by jim e
Closed Account
Joined Sep 2005
stick 40
lightened the airframe a little and added wood up front to attach x-mount to fuselage via threaded inserts.
jim e is offline Find More Posts by jim e
Old Sep 17, 2010, 10:02 AM
jmgm is offline
Joined Sep 2010
if I am going to him thank you very much to put the motor to the airplane like this in the photo lightening structure and mounting motor X wonderful forum greetings from Spain
Sold TWO Balsa USA Stick 40 Wing Kits wfortney99 Aircraft - Fuel - Airplanes (FS/W) 3 Aug 06, 2010 08:03 PM
For Sale Balsa USA Stick 40 Plus plans kg4min Aircraft - Fuel - Airplanes (FS/W) 0 Oct 21, 2008 06:37 PM
For Sale Vintage Balsa USA Stick 40 kit NOS bob95065 Aircraft - Fuel - Airplanes (FS/W) 0 Nov 27, 2007 03:18 PM
Sold Balsa USA Stick 40 Plus kit, new in box..PLUS a spare wing kit. Thomas B Aircraft - Fuel - Airplanes (FS/W) 4 May 04, 2007 06:31 PM
For Sale Balsa USA Stick 40 kit steveo64 Aircraft - Fuel - Airplanes (FS/W) 6 Oct 01, 2006 11:27 AM
