Old Sep 09, 2010, 03:02 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Video compression question
Hi,
So i'm working on converting a video so it can be edited. Its saved on my recorder as .mpg and I'm trying out different compressions to see what's best vs file size. Well the original is about 500mb, and I've tried a .DV, .mpeg-4 and they all come out to be about 6-8 GIGS!!! How is that even possible and none are quite as good quality as the original. The 8 gig file is close, but its 16 times the size!
ideas?
ashdec87 is offline Find More Posts by ashdec87
Old Sep 09, 2010, 03:28 PM
bignose13 is offline
Find More Posts by bignose13
Yeah Baby
bignose13's Avatar
Joined Apr 2006
what software are you using
bignose13 is offline Find More Posts by bignose13
Old Sep 09, 2010, 03:40 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
If it starts at 500Mb and ends at 8Gigs, then there's something wrong with
your process, and it's effectively not getting compressed at all.
Also, 500Mb may be perfectly reasonable if you're talking 15-20 minutes of video.
How long is the actual video clip you're working with?
ian
Daemon is online now Find More Posts by Daemon
Old Sep 09, 2010, 03:53 PM
WEREE is offline
Find More Posts by WEREE
WEREE's Avatar
United States, CA, Fremont
Joined Dec 2008
You will have to check the bitrate that your output video is using. The final size of the file is easily calculated by taking the video bitrate (bits/sec) and then multiply by the number of seconds of video -- this is irregardless of the codec in use.
A high bitrate will give best quality and you can dial it down to happy medium trading off file size versus quality. Every codec will have its own level of degredation of video for a given bitrate level. The NTSC/PAL videos we use aren't too good quality to begin with so you won't need much to maintain quality especially with a good new codec like h264.
WEREE is offline Find More Posts by WEREE
Old Sep 09, 2010, 04:01 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
oh sorry I'm using MPEG streamclip to do the compressing.
I'm using the MPEG-4 setting on highest quality. My video is 15 minutes. Looks like the final video ended up being 9.something gigs.. yeesh..
Granted the quality is identical to the original, but the increase in file size is too much..
Old Sep 10, 2010, 07:44 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
what's a decent bit rate I should set it at?
Old Sep 10, 2010, 08:45 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Depends on the resolution, the detail, level of motion, quality of the original (ironically,
the lower the quality of the original, the higher the bitrate you'll have to choose to
maintain quality) and what codec you're using. H.264 codec generally offers the highest
quality for the lowest bitrate, but sometimes struggles with high motion, and is almost always
quite slow to compress, compared to DiVX or XviD which need about 30% higher bitrate
but can be 2-3x faster.
I'm guessing, given the tool you're using that you're on a Mac, in which case I can
offer only general advice. If you're on Windows, then try WinFF and create a profile
using XviD at about 3-4Mbit/s for SD resolution (640x480@30fps).
ian
Old Sep 10, 2010, 08:54 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
ok so some where in the 3-4mbs range? I just need a ballpark, then I can play with it from there..
Old Sep 13, 2010, 06:44 AM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
try http://www.virtualdub.org/download.html it can edit, recode & many other features, Best of all its free
You can play for hours with your video, looking at the trade off between size and quality.
empeabee is offline Find More Posts by empeabee
Old Sep 13, 2010, 07:02 AM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
try 3mb. virtualdub is superb but almost certain it doesn't work on a mac.
NDw is offline Find More Posts by NDw
Old Sep 13, 2010, 07:47 AM
empeabee is offline
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
using a WINE type windoze emulator?
Old Sep 13, 2010, 08:38 AM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
I'll give that a try thanks!
Help! Video compression ... hhheeeelllppp giluriel FPV Talk 10 Oct 25, 2009 04:43 AM
Discussion video compression software mrleenagle FPV Talk 7 Sep 03, 2009 06:25 PM
Discussion Video and Compression Question MikeSSS Aerial Photography 1 May 07, 2006 01:25 PM
video clip compression inedesca Life, The Universe, and Politics 3 Dec 13, 2004 02:03 AM
