Old Sep 09, 2010, 12:39 PM
MiddleMarc is offline
Find More Posts by MiddleMarc
Cedar Rapids, IA
Joined Aug 2010
Flat, packable... folding wing or delta?
I'm on a quest to create a flat, packable flyer with the express purpose of carrying an 808 key fob camera for aerial photography with me when I travel. So... doesn't need to be big or carry a big payload (17 gram 808 camera). I would like to be able to fly in a range of wind speeds because you never know what you'll find when you get there. It does need to be able to fly slow and stable for nice, smooth video from the camera.
There is a nice flying wing design in the Scythe thread that has been made foldable (with stub spar and magnets) and I'm also looking at deltas like the Superfly or HyperFlea (maybe with removeable fins?).
129g 24" (total wing span) Travelling Scythe
http://www.rcgroups.com/forums/showp...&postcount=144
My plane will need to be built light to fly slow but there is also that "range of wind speeds" issue to consider.
What does "packable" mean? I think I'd like to get the size down to something that would pack flat in a suitcase that you can "carry on" a commerical flight but slightly larger would be OK too if necessary. I mostly travel by car (but not always with a lot of luggage space on family trips).
Carry on:
The maximum size carry-on bag for most airlines is 45 linear inches (the total of the height, width, and depth of the bag).
22" x 14" x 9" United, Delta, NWA
24" x 16" x 10" Southwest
22" x 16" x 8" British Airways
HyperFlea:
Wingspan: 22 inches
Length: 18.75 inches
Ideas appreciated!
MiddleMarc is offline Find More Posts by MiddleMarc
Old Sep 09, 2010, 12:55 PM
jhoyda is offline
Find More Posts by jhoyda
Joined Jul 2008
No folding needed.
jhoyda is offline Find More Posts by jhoyda
Old Sep 09, 2010, 02:15 PM
Cedar Rapids, IA
Joined Aug 2010
Yeah. I'm reading about the MS Mini Swift too. Looks like the right size...
MS Composit Mini Swift Review
http://www.rcgroups.com/forums/showthread.php?t=1156624
Old Sep 09, 2010, 06:25 PM
ssteven1 is offline
Find More Posts by ssteven1
United States, NC, Randleman
Joined Jan 2007
I found this on you tube.
Electrifly MiniSlinger Portable RC Airplane (9 min 11 sec)
It seems pretty easy.
ssteven1 is offline Find More Posts by ssteven1
Old Sep 09, 2010, 07:38 PM
DustyPockets is offline
Find More Posts by DustyPockets
A fool in a field.
United States, IL, Mahomet
Joined Dec 2006
Of course not a wing but you could look at the Multiplex Merlin. Wings and elevator are removable and an AP friendly folding prop.
DustyPockets is offline Find More Posts by DustyPockets
Old Sep 10, 2010, 12:54 AM
matyou is offline
Find More Posts by matyou
matyou's Avatar
Bay Area California
Joined Dec 2009
Before considering the plane do think about the transport of lipos because i have heard there is a restriction to the max battery size that you can transport.
matyou is offline Find More Posts by matyou
Old Sep 11, 2010, 10:24 AM
Cedar Rapids, IA
Joined Aug 2010
TSA / FAA restrictions on LiPo (Lithium) batteries
This was an excellent notion to investigate!
Here is a TSA site that discusses the issue:
Traveling safely with batteries...
http://safetravel.dot.gov/definitions.html#lithium
"8 grams of equivalent lithium content are equal to about 100 watt-hours."
"You can arrive at the number of watt-hours your battery provides if you know how many milliamp hours and volts your battery provides:
mAh/1000 x V = wh"
Since I want to fly slow I'll build light and probably use something flat like:
Rhino 460mAh 2S 7.4v 20C Lipoly Pack
http://www.hobbyking.com/hobbyking/s...idProduct=7303
Calculation: 460/1000 * 7.4v = 3.4 watt-hours
So... looks like I'd be OK (by a fair sized margin)!
Other restrictions seem to be no batteries in checked luggage and not more than 2 "spare" batteries (not installed in the device). Batteries need to be with you in the plane (not gate checked).
Discussion HELP! - Looking for 54" (or thereabouts!) delta wing hotwire template TheNiceGuy Flying Wings 5 Aug 25, 2010 10:33 PM
For Sale packable 60" DLG wing David Forbes Aircraft - Sailplanes (FS/W) 7 Jul 16, 2010 06:56 PM
Question carbon ribbon placed flat top or bottom of wing grfcon Slope 7 Feb 16, 2010 11:01 AM
Discussion anyone ever used a eflite 420 motorfor a delta or wing? epoweredrc Flying Wings 0 Dec 16, 2009 09:27 PM
First Delta Flat Wing Design Buzz_Man Foamies (Kits) 4 Sep 30, 2004 08:21 PM
