Old Sep 09, 2010, 09:35 AM
Nase is offline
Find More Posts by Nase
Deutschland, Baden-Württemberg, Stuttgart
Joined Aug 2010
Arduino Code to read PPM timings
I wrote some code that allows me to capture about 100 PPM frames in a row and outputs the timings for each channel, the sync pulse and the framelength.
Maybe someone wants to try and report some results and if these match to generate a PPM signal. I know most times PPM should be fixed frame length about 22.5 ms.. but in my case it is rather fixed sync pulse.. to track this down I wrote the code..
Should work for at least 4 channels, just change one of the first lines to try with 6 or 8 channels..
Using inverted signal should be possible to..
currently it uses the serial port with 115200 baud, also can be changed to whatever your serial speed is..
Also (/especially) if you have your PPM timings already working, I'd like to know if the timings this code reads match what you have working.
I only own a NineEagles transmitter, so please report any working transmitters + results, or any problems.
use the reply button or feel free to write an email
my result:
Code:
FrameNumber: 1 frameLength: 27032     1059   1021   524   1046   20792
FrameNumber: 2 frameLength: 27000     1061   1022   527   1052   20761
FrameNumber: 3 frameLength: 27132     1062   1021   522   1054   20903
FrameNumber: 4 frameLength: 27024     1059   1021   528   1052   20787
FrameNumber: 5 frameLength: 27000     1061   1022   521   1052   20767
FrameNumber: 6 frameLength: 27020     1063   1021   528   1054   20789
FrameNumber: 7 frameLength: 27132     1059   1021   528   1053   20902
FrameNumber: 8 frameLength: 26996     1054   1022   521   1050   20765
FrameNumber: 9 frameLength: 27020     1062   1021   529   1054   20783
FrameNumber: 10 frameLength: 27000     1059   1021   522   1052   20769
FrameNumber: 11 frameLength: 27140     1061   1021   527   1053   20899
FrameNumber: 12 frameLength: 27024     1062   1021   521   1054   20789
FrameNumber: 13 frameLength: 27000     1059   1021   527   1052   20771
FrameNumber: 14 frameLength: 27020     1061   1022   527   1052   20783
FrameNumber: 15 frameLength: 27136     1062   1021   522   1054   20903
FrameNumber: 16 frameLength: 27000     1059   1021   527   1052   20764
FrameNumber: 17 frameLength: 27024     1061   1022   521   1052   20789
FrameNumber: 18 frameLength: 27004     1062   1021   527   1054   20765
FrameNumber: 19 frameLength: 27132     1061   1022   529   1052   20902
FrameNumber: 20 frameLength: 27020     1054   1022   521   1046   20791
FrameNumber: 21 frameLength: 26996     1062   1021   527   1054   20757
FrameNumber: 22 frameLength: 27024     1061   1022   522   1052   20795
FrameNumber: 23 frameLength: 27136     1061   1021   527   1053   20899
FrameNumber: 24 frameLength: 27000     1062   1022   522   1054   20766
FrameNumber: 25 frameLength: 27024     1061   1022   528   1052   20792
FrameNumber: 26 frameLength: 26996     1061   1021   527   1053   20761
FrameNumber: 27 frameLength: 27136     1062   1021   522   1054   20903
FrameNumber: 28 frameLength: 27020     1061   1022   528   1052   20786
FrameNumber: 29 frameLength: 27000     1061   1021   521   1052   20767
FrameNumber: 30 frameLength: 27024     1063   1021   528   1054   20782
FrameNumber: 31 frameLength: 27140     1061   1023   521   1052   20909
FrameNumber: 32 frameLength: 26996     1061   1022   527   1052   20766
FrameNumber: 33 frameLength: 27020     1062   1021   527   1054   20782
FrameNumber: 34 frameLength: 26996     1061   1023   521   1052   20768
FrameNumber: 35 frameLength: 27136     1059   1021   528   1052   20902
FrameNumber: 36 frameLength: 27020     1062   1022   522   1054   20788
FrameNumber: 37 frameLength: 27000     1061   1023   528   1052   20769
FrameNumber: 38 frameLength: 27016     1059   1021   528   1053   20786
FrameNumber: 39 frameLength: 27132     1062   1021   522   1054   20903
FrameNumber: 40 frameLength: 27000     1061   1022   528   1052   20764
FrameNumber: 41 frameLength: 27020     1059   1021   522   1052   20792
FrameNumber: 42 frameLength: 26996     1063   1021   528   1054   20759
FrameNumber: 43 frameLength: 27136     1061   1023   521   1052   20906
FrameNumber: 44 frameLength: 27024     1059   1021   528   1053   20794
FrameNumber: 45 frameLength: 26992     1062   1021   527   1054   20757
FrameNumber: 46 frameLength: 27024     1061   1022   522   1052   20793
FrameNumber: 47 frameLength: 27136     1059   1021   528   1053   20902
FrameNumber: 48 frameLength: 26996     1062   1022   522   1054   20765
FrameNumber: 49 frameLength: 27020     1061   1022   528   1052   20785
FrameNumber: 50 frameLength: 27000     1059   1021   522   1053   20764
FrameNumber: 51 frameLength: 27136     1061   1021   521   1052   20903
FrameNumber: 52 frameLength: 27020     1061   1022   528   1052   20785
FrameNumber: 53 frameLength: 27000     1059   1021   522   1052   20770
FrameNumber: 54 frameLength: 27020     1061   1022   527   1052   20783
FrameNumber: 55 frameLength: 27136     1061   1023   521   1052   20907
FrameNumber: 56 frameLength: 26996     1059   1021   528   1053   20769
FrameNumber: 57 frameLength: 27024     1061   1021   527   1052   20784
FrameNumber: 58 frameLength: 26992     1061   1023   522   1052   20766
FrameNumber: 59 frameLength: 27140     1059   1021   528   1052   20902
FrameNumber: 60 frameLength: 27020     1061   1022   521   1052   20791
FrameNumber: 61 frameLength: 26996     1061   1023   528   1052   20761
FrameNumber: 62 frameLength: 27024     1059   1021   522   1052   20790
FrameNumber: 63 frameLength: 27136     1061   1021   521   1053   20904
FrameNumber: 64 frameLength: 26996     1061   1022   528   1052   20761
FrameNumber: 65 frameLength: 27024     1059   1021   522   1052   20793
FrameNumber: 66 frameLength: 26996     1061   1022   527   1052   20761
FrameNumber: 67 frameLength: 27136     1062   1021   522   1054   20903
FrameNumber: 68 frameLength: 27028     1059   1021   527   1052   20791
FrameNumber: 69 frameLength: 26996     1061   1019   527   1053   20759
FrameNumber: 70 frameLength: 27020     1062   1021   522   1054   20789
FrameNumber: 71 frameLength: 27140     1059   1021   528   1053   20902
FrameNumber: 72 frameLength: 26996     1061   1022   521   1052   20766
FrameNumber: 73 frameLength: 27020     1062   1021   527   1054   20783
FrameNumber: 74 frameLength: 27000     1059   1021   522   1052   20771
FrameNumber: 75 frameLength: 27140     1061   1021   521   1052   20905
FrameNumber: 76 frameLength: 27020     1062   1021   527   1054   20781
FrameNumber: 77 frameLength: 27000     1059   1021   522   1052   20771
FrameNumber: 78 frameLength: 27020     1061   1021   527   1052   20782
FrameNumber: 79 frameLength: 27136     1062   1022   522   1054   20905
FrameNumber: 80 frameLength: 26996     1059   1021   528   1053   20762
FrameNumber: 81 frameLength: 27024     1061   1021   523   1052   20785
FrameNumber: 82 frameLength: 26996     1062   1022   522   1054   20764
FrameNumber: 83 frameLength: 27136     1061   1022   528   1052   20902
FrameNumber: 84 frameLength: 27024     1061   1021   521   1052   20791
FrameNumber: 85 frameLength: 26996     1062   1021   529   1054   20759
FrameNumber: 86 frameLength: 27020     1060   1023   522   1052   20792
FrameNumber: 87 frameLength: 27136     1061   1021   521   1052   20905
FrameNumber: 88 frameLength: 26988     1062   1021   528   1054   20759
FrameNumber: 89 frameLength: 27024     1061   1023   522   1052   20793
FrameNumber: 90 frameLength: 27000     1061   1021   527   1052   20761
FrameNumber: 91 frameLength: 27132     1062   1021   521   1054   20903
FrameNumber: 92 frameLength: 27024     1061   1023   528   1052   20789
FrameNumber: 93 frameLength: 26996     1061   1021   521   1052   20765
FrameNumber: 94 frameLength: 27020     1062   1022   522   1054   20789
FrameNumber: 95 frameLength: 27140     1061   1022   529   1052   20902
FrameNumber: 96 frameLength: 27000     1061   1021   521   1052   20765
FrameNumber: 97 frameLength: 27024     1062   1021   527   1054   20783
FrameNumber: 98 frameLength: 27000     1060   1022   522   1052   20770
FrameNumber: 99 frameLength: 27144     1053   1021   521   1053   20909
FrameNumber: 100 frameLength: 27012     1062   1021   527   1054   20781
Code:
Code:
// Arduino Code to get PPM timings - v1.1  //
// written by Dave B.     [2010.09.09]     //
// comments, bugs, ideas to davedave1@gmx.net
// first 6 lines should be adjusted to individual setup
#define channelnumber 4     // Number of channels
#define framecount 100      // How many frames to capture?   tested with 100 frames for 4 channels on atmega328
#define minsync 3000        // Minimum syncpulselength     values above 3000 should work for normal PPM
int inputpin = 4;           // PPM input pin
int inverted = 0;           // use "inverted = 1"  for inverted signals
long serialspeed = 115200;  // tested with 115200 Baud, needs to match driver settings and serial monitor setting
long synclength[framecount];                       // syncvalues
int channel[channelnumber*framecount];             // Channel values
long framelength[framecount];                      // frame start times
int counter = 0;                                   // counter for measuring timings
int outcounter = 0;                                // counter for output measured timings
int synced = 0;                                    // used boolean after found sync, start get all frames from pattern
void setup()
  Serial.begin(serialspeed);                       // open serial connection
  pinMode(inputpin, INPUT);                        // set input pin for input
  synced = 0;
void loop()
  synclength[counter] = 0;        //
  if (synced == 0){        // if not already in sync
    if ( inverted == 0 ){        // if inverted signal selected is false
      synclength[counter] = pulseIn(inputpin, HIGH);                                               // wait for next HIGH pulse
    else{        // else inverted is selected
      synclength[counter] = pulseIn(inputpin, LOW);                                                // wait for next LOW pulse
  if ((synclength[counter] > minsync)or(synced == 1)){                                              // if syncpulse found or already synced
    synced = 1;        // set synced as "true"
    framelength[counter] = micros();        // get start time
    synclength[counter] = 0;        // reset synclength which was used to find syncpulse ( [0] should work )
      for (int channelcounter = 0; channelcounter < channelnumber; channelcounter++){               // loop for measuring all channels
        channel[(counter * channelnumber) + channelcounter]=pulseIn(inputpin, HIGH);
      synclength[counter]  = pulseIn(inputpin, HIGH);                                               // get syncpulse length
        channel[(counter * channelnumber) + channelcounter]=pulseIn(inputpin, LOW);
      synclength[counter]  = pulseIn(inputpin, LOW);                                                 // get syncpulse length
    framelength[counter] = micros() - framelength[counter] ;                                         // keep difference between start- and endtime
  if (counter >= (framecount-1)){        // if captured enough frames
    synced = 0;        // set synced to "false"
    outcounter = 0;        // start output with second (third) frame, the first (first to) get measured bad
    while (outcounter < framecount){        // loop for all captured frames
      Serial.print("FrameNumber: ");        // output measured timings
      Serial.print(outcounter+1);
      Serial.print(" ");
      Serial.print("frameLength: ");
      Serial.print(framelength[outcounter]);
      Serial.print(" ");
      Serial.print("    ");
      for (int channelcounter = 0; channelcounter < channelnumber; channelcounter++){                // output all channels and pulses
        Serial.print(channel[(outcounter * channelnumber) + channelcounter]);
        Serial.print("   ");
      Serial.print(synclength[outcounter]);                                                          // output syncpulse length
      Serial.println("");        // output NewLine()
      outcounter++;        // increase counter for output frames
    counter = 0;        // reset counter for measuring the next sequence of frames
   else{        // else (not enough frames captured)
    counter++;        // increase counter for measuring the next frame
Nase is offline Find More Posts by Nase
Old Sep 09, 2010, 09:41 AM
Nase is offline
Joined Aug 2010
I added that MIN and MAX values for the channels get captured.. so you just have to move sticks to min/max positions..
Code:
FrameNumber: 1     1045   1007   522   1067   20794 frameLength: 27020
FrameNumber: 2     1046   1003   522   1069   20927 frameLength: 27148
FrameNumber: 3     1046   991   527   1070   20791 frameLength: 27000
FrameNumber: 4     1045   1007   522   1067   20792 frameLength: 27004
FrameNumber: 5     1046   1002   528   1068   20794 frameLength: 27016
FrameNumber: 6     1046   1006   521   1070   20919 frameLength: 27132
FrameNumber: 7     1045   1007   528   1068   20786 frameLength: 27004
FrameNumber: 8     1046   1003   522   1069   20800 frameLength: 27016
FrameNumber: 9     1046   1006   522   1070   20787 frameLength: 27004
FrameNumber: 10     1048   1005   528   1067   20916 frameLength: 27136
FrameNumber: 11     1046   1003   522   1069   20799 frameLength: 27016
FrameNumber: 12     1047   1006   529   1070   20783 frameLength: 27004
FrameNumber: 13     1048   1005   522   1067   20797 frameLength: 27012
FrameNumber: 14     1039   1005   522   1062   20919 frameLength: 27140
FrameNumber: 15     1047   1007   528   1070   20783 frameLength: 27004
FrameNumber: 16     1048   1005   522   1067   20799 frameLength: 27016
FrameNumber: 17     1043   1004   528   1068   20799 frameLength: 27016
FrameNumber: 18     1047   1004   521   1069   20920 frameLength: 27124
FrameNumber: 19     1047   1005   528   1068   20793 frameLength: 27012
FrameNumber: 20     1044   1005   522   1069   20805 frameLength: 27016
FrameNumber: 21     1047   1004   521   1071   20800 frameLength: 27004
FrameNumber: 22     1044   1007   528   1068   20915 frameLength: 27132
FrameNumber: 23     1042   1006   522   1069   20793 frameLength: 27008
FrameNumber: 24     1048   1004   527   1070   20791 frameLength: 27012
FrameNumber: 25     1045   1007   522   1067   20792 frameLength: 27008
FrameNumber: 26     1046   1003   522   1062   20929 frameLength: 27148
FrameNumber: 27     1047   992   521   1069   20797 frameLength: 27000
FrameNumber: 28     1045   1007   522   1067   20792 frameLength: 27004
FrameNumber: 29     1046   1003   528   1069   20795 frameLength: 27016
FrameNumber: 30     1045   1005   521   1068   20921 frameLength: 27140
FrameNumber: 31     1045   1007   528   1067   20784 frameLength: 27000
FrameNumber: 32     1047   1003   522   1068   20801 frameLength: 27016
FrameNumber: 33     1039   1006   521   1062   20801 frameLength: 27016
FrameNumber: 34     1046   1003   527   1070   20914 frameLength: 27124
FrameNumber: 35     1046   1004   522   1069   20801 frameLength: 27016
FrameNumber: 36     1046   1006   527   1069   20784 frameLength: 27004
FrameNumber: 37     1047   1004   522   1069   20796 frameLength: 27012
FrameNumber: 38     1044   1004   528   1068   20919 frameLength: 27140
FrameNumber: 39     1045   1005   521   1068   20803 frameLength: 27016
FrameNumber: 40     1046   992   522   1070   20797 frameLength: 27004
FrameNumber: 41     1043   1004   528   1068   20799 frameLength: 27016
FrameNumber: 42     1046   1004   521   1068   20933 frameLength: 27136
FrameNumber: 43     1046   1003   527   1070   20791 frameLength: 27000
FrameNumber: 44     1042   1006   522   1069   20805 frameLength: 27020
FrameNumber: 45     1046   1004   521   1062   20799 frameLength: 27004
FrameNumber: 46     1047   1005   528   1069   20914 frameLength: 27132
FrameNumber: 47     1043   1005   522   1069   20793 frameLength: 27008
FrameNumber: 48     1047   1004   527   1068   20792 frameLength: 27012
FrameNumber: 49     1047   1006   522   1070   20790 frameLength: 27008
FrameNumber: 50     1047   1005   528   1068   20929 frameLength: 27148
FrameNumber: 51     1046   991   521   1068   20797 frameLength: 27000
FrameNumber: 52     1040   1006   522   1067   20789 frameLength: 27004
FrameNumber: 53     1047   1005   528   1068   20795 frameLength: 27016
FrameNumber: 54     1045   1005   521   1068   20921 frameLength: 27136
FrameNumber: 55     1047   1005   527   1070   20782 frameLength: 27004
FrameNumber: 56     1047   1005   522   1067   20801 frameLength: 27016
FrameNumber: 57     1046   1006   527   1069   20802 frameLength: 27016
FrameNumber: 58     1046   1003   527   1070   20913 frameLength: 27124
FrameNumber: 59     1047   1006   522   1067   20801 frameLength: 27016
FrameNumber: 60     1046   1006   527   1069   20784 frameLength: 27004
FrameNumber: 61     1047   1004   522   1070   20796 frameLength: 27012
FrameNumber: 62     1045   1007   527   1068   20919 frameLength: 27140
FrameNumber: 63     1046   1006   521   1068   20803 frameLength: 27016
FrameNumber: 64     1046   992   522   1064   20797 frameLength: 27000
FrameNumber: 65     1045   1007   528   1068   20786 frameLength: 27008
FrameNumber: 66     1046   1003   522   1069   20934 frameLength: 27148
FrameNumber: 67     1046   1003   527   1070   20792 frameLength: 27000
FrameNumber: 68     1044   1007   522   1068   20791 frameLength: 27004
FrameNumber: 69     1046   1003   528   1068   20797 frameLength: 27020
FrameNumber: 70     1047   1006   528   1070   20914 frameLength: 27132
FrameNumber: 71     1038   1007   522   1068   20791 frameLength: 27004
FrameNumber: 72     1046   1002   528   1068   20794 frameLength: 27016
FrameNumber: 73     1046   1006   522   1069   20790 frameLength: 27004
FrameNumber: 74     1048   1005   528   1068   20915 frameLength: 27140
FrameNumber: 75     1046   1003   522   1069   20798 frameLength: 27012
FrameNumber: 76     1047   1006   528   1070   20790 frameLength: 27004
FrameNumber: 77     1047   1005   528   1068   20793 frameLength: 27016
FrameNumber: 78     1044   1005   521   1068   20925 frameLength: 27136
FrameNumber: 79     1047   1006   527   1070   20781 frameLength: 27004
FrameNumber: 80     1047   1006   522   1067   20799 frameLength: 27012
FrameNumber: 81     1043   1006   528   1069   20799 frameLength: 27016
FrameNumber: 82     1047   1010   527   1070   20913 frameLength: 27124
FrameNumber: 83     1048   1005   522   1061   20799 frameLength: 27012
FrameNumber: 84     1043   1004   528   1068   20787 frameLength: 27008
FrameNumber: 85     1047   1004   521   1070   20797 frameLength: 27012
FrameNumber: 86     1045   1007   528   1068   20916 frameLength: 27136
FrameNumber: 87     1044   1005   521   1069   20807 frameLength: 27020
FrameNumber: 88     1047   992   527   1070   20797 frameLength: 27008
FrameNumber: 89     1044   1007   528   1068   20786 frameLength: 26996
FrameNumber: 90     1047   1003   521   1069   20935 frameLength: 27152
FrameNumber: 91     1047   1004   527   1070   20793 frameLength: 27004
FrameNumber: 92     1045   1007   522   1069   20790 frameLength: 27000
FrameNumber: 93     1047   1002   528   1068   20794 frameLength: 27016
FrameNumber: 94     1045   1006   522   1068   20921 frameLength: 27136
FrameNumber: 95     1045   1007   528   1068   20789 frameLength: 27004
FrameNumber: 96     1047   1003   527   1068   20794 frameLength: 27016
FrameNumber: 97     1046   1006   521   1068   20789 frameLength: 27004
FrameNumber: 98     1048   1004   528   1070   20913 frameLength: 27136
FrameNumber: 99     1047   1003   521   1068   20799 frameLength: 27016
FrameNumber: 100     1046   1006   527   1069   20797 frameLength: 27016
min/max per channel:   518/1531   507/1536   507/1541   508/1534
Code:
// Arduino Code to get PPM timings - v1.2  //
long minchannel[channelnumber];
long maxchannel[channelnumber];
void setup()
  synced = 0;
   minchannel[channelcounter] = 50000;
   maxchannel[channelcounter] = 0;
void loop()
      Serial.print(" ");
      Serial.print("    ");
        Serial.print("   ");
        if (minchannel[channelcounter] > channel[(outcounter * channelnumber) + channelcounter]){
           minchannel[channelcounter] = channel[(outcounter * channelnumber) + channelcounter];
        if (maxchannel[channelcounter] < channel[(outcounter * channelnumber) + channelcounter]){
           maxchannel[channelcounter] = channel[(outcounter * channelnumber) + channelcounter];
      Serial.print("    ");
    Serial.print("min/max per channel:   ");
      Serial.print(minchannel[channelcounter]);
      Serial.print("/");
      Serial.print(maxchannel[channelcounter]);
      Serial.print("   ");
Old Sep 10, 2010, 07:05 PM
itai n is offline
Find More Posts by itai n
Haifa, Israel
Joined Nov 2009
You should count milis between rising (falling if inverted) edges of the signal coming out of the receiver. Instead you measure the length of the pulse. Timing between pulses should be between 1000 and 2000 ms (and about 1500 ms when the stick is centered). The values that you read for ch 3 are invalid, I believe the other values are wrong too.
Assuming you are using ATMEGA328 you can have pretty accurate results using ICP1 (which is same pin as PB1), but then you will need to use interrupts.
itai n is offline Find More Posts by itai n
Old Sep 10, 2010, 09:16 PM
Nase is offline
Joined Aug 2010
what is invalid with the values of channel 3?
the fifth value is the length of the sync pulse
channel three is throttle stick on my transmitter.. it was at minimum position.. the others are centered.. min/max is about 500 to 1500, I think there is nothing wrong. of course, for every channel and the syncpulse, there is an additional pulse of about 480 us with my transmitter, this should be about 300 us with standard PPM..
I started with a version that was intended to capture everything.. because of the behaviour of pulsein this was not successfull,..
however, I will try to put together a version that uses interrupts..
Maybe I should call the signal that my transmitter uses inverted.
from http://www.arduino.cc/en/Reference/PulseIn
pulseIn()
Description
Reads a pulse (either HIGH or LOW) on a pin. For example, if value is HIGH, pulseIn() waits for the pin to go HIGH, starts timing, then waits for the pin to go LOW and stops timing. Returns the length of the pulse in microseconds. Gives up and returns 0 if no pulse starts within a specified time out.
compare:
Old Sep 11, 2010, 08:34 AM
itai n is offline
Haifa, Israel
Joined Nov 2009
I've edited your scope image and added the things that you really want to measure.
From the Image I see that your radio is four-channel and is using negative pulses (Futaba style). Channels 1,2 and 4 are centered and are indeed about 1.5 ms. Channel 3 (throttle at its low position?) is about 1 ms. The full frame is about 27 ms.
Old Sep 11, 2010, 01:36 PM
Nase is offline
Joined Aug 2010
thanks, but I still don't get why you would know better than me, what I want to measure..
if I want to generate this signal, I need to know how long the pulses are, how long the times between are, how long the syncpulse is..
how long it takes for ( a channel + it's pulse ) is not of interest in the first place.. I could take this time minus the channel high time, or just measure the low times, too..
Maybe the length of the low pulses is irrelevant, but as I am quite sure that my transmitter uses no standard PPM, I want to know exactly what the code is reading. The framelength is not constant 27ms .. the syncpulse is fixed 20ms..
I think the code I posted reads exactly the timings that I want to know.
Just to understand, what should I do with the times that you marked?
take them.. minus pulse length and have the same times that my code reads, that I need to generate the correct high and low times for the signal?
I posted the code here, hoping someone, who has a PPM signal generator working, would post results of a a known working PPM signal. so I would know how (in)accurate they are..
Please explain why / if you still think I don't know what I want to measure.
Just add the fixed length of the pulse to my timings and you have what *you* want to know.. since pulses are commonly not varying I thought I could just leave them out. First code that I tried measured all those times, but arduino measured framelengths of 80ms.. so it only got about every fourth frame..
Thanks!
Old Sep 11, 2010, 11:10 PM
Nase is offline
Joined Aug 2010
got some code that gives results like this
Code:
492 1040 488 1028 484 532 484 1076 484 21040
492 1044 484 1028 488 528 484 1076 488 20924
488 1048 484 1028 484 528 488 1076 484 20900
488 1044 488 1028 484 528 488 1072 488 20924
488 1044 488 1028 484 528 488 1076 488 21036
488 1048 484 1028 484 528 488 1076 488 20896
488 1044 488 1028 488 524 488 1072 488 20924
488 1044 488 1028 484 528 488 1076 488 20896
492 1044 484 1028 488 528 484 1080 484 21036
492 1044 484 1028 488 528 488 1072 488 20896
492 1044 484 1028 488 528 484 1080 484 20920
492 1044 484 1032 484 528 484 1076 488 21036
496 1040 484 1028 488 528 488 1072 488 20896
492 1044 484 1032 484 528 484 1076 488 20900
492 1040 488 1028 484 528 488 1072 488 21040
488 1048 484 1028 484 528 488 1076 488 20916
492 1040 488 1028 484 528 488 1076 484 20924
492 1044 484 1028 484 532 484 1076 488 21036
488 1044 488 1028 484 528 488 1076 484 20900
492 1044 484 1032 484 528 488 1076 484 20896
488 1044 488 1028 484 532 484 1076 484 21040
492 1040 488 1028 484 528 488 1076 484 20928
488 1044 488 1028 484 528 488 1076 484 20896
492 1044 484 1032 484 528 488 1072 488 20920
492 1044 484 1028 488 528 484 1076 488 21040
just need to clean it up, add some things..
then I' post it here..
Old Sep 12, 2010, 01:15 AM
Nase is offline
Joined Aug 2010
should work for 4-8 channels and also normal and inverted signals.
use PIN 2, needed for the external Interrupt.
capturing should work even if channel number doesn't match,
however, just change 2 lines for channelnumber and serial speed..
results look like this
Code:
492 1044 484 1020 488 528 484 1076 488 20908     Frame Length: 27012
492 1044 484 1020 488 528 484 1076 488 21044     Frame Length: 27148
492 1044 484 1020 488 528 484 1080 484 20928     Frame Length: 27032
492 1040 488 1020 484 528 488 1076 484 20912     Frame Length: 27012
488 1044 488 1020 484 528 488 1076 488 20928     Frame Length: 27032
488 1048 484 1020 484 528 488 1076 488 21044     Frame Length: 27148
492 1040 488 1020 484 532 484 1076 484 20908     Frame Length: 27008
492 1044 484 1020 488 528 488 1072 488 20932     Frame Length: 27036
488 1048 484 1020 484 532 484 1076 488 20900     Frame Length: 27004
492 1044 484 1024 484 528 488 1072 488 21048     Frame Length: 27152
492 1044 484 1020 488 528 488 1076 484 20904     Frame Length: 27008
492 1044 484 1024 484 528 488 1072 488 20932     Frame Length: 27036
488 1044 488 1020 484 532 484 1076 488 21044     Frame Length: 27148
488 1048 484 1020 484 532 484 1076 488 20904     Frame Length: 27008
492 1040 488 1020 484 532 484 1076 484 20932     Frame Length: 27032
492 1044 484 1020 488 528 488 1072 488 20908     Frame Length: 27012
492 1044 484 1020 484 532 484 1076 488 21044     Frame Length: 27148
492 1044 484 1024 484 528 484 1076 488 20908     Frame Length: 27012
492 1040 488 1020 484 528 488 1076 484 21048     Frame Length: 27148
488 1044 488 1020 484 528 488 1076 484 20908     Frame Length: 27008
492 1044 484 1020 488 528 484 1076 488 20932     Frame Length: 27036
492 1040 488 1020 484 528 488 1076 484 20936     Frame Length: 27036
488 1048 484 1020 484 528 488 1076 488 20900     Frame Length: 27004
492 1044 484 1024 484 528 484 1076 488 21044     Frame Length: 27148
492 1044 484 1020 488 528 484 1080 484 20904     Frame Length: 27008
492 1044 484 1024 484 528 488 1072 488 20928     Frame Length: 27032
492 1044 484 1020 488 528 484 1076 488 21048     Frame Length: 27152
488 1048 484 1020 484 528 488 1076 488 20904     Frame Length: 27008
488 1044 488 1020 484 532 484 1076 484 20932     Frame Length: 27032
492 1040 488 1020 484 532 484 1076 484 20912     Frame Length: 27012
488 1044 488 1020 484 532 484 1076 488 21040     Frame Length: 27144
code
Code:
// Arduino Code to get PPM timings -     v1.5 //
// comments, bugs, ideas to davedave1@gmx.net //
// * use PIN 2 for PPM signal                 //
// change the first line if you have more or  //
// less channels..                            //
// Leave the valueCount as it is, arduino     //
// might run out of memory!                   //
#define channelCount 4             // set channel count
#define serialSpeed 115200         // set serialSpeed here
// don't change anything below
#define valueCount 200
long counter = 0;                  // counter
long values[valueCount];           // array for values
int frameFound = 0;                // used as boolean
long minSync = 3000;               // standard PPM
void pinChanged(){                 // Function called by Interrupt
  values[counter] = micros();      // store timestamp
  counter++;                       // count value
  if (counter >= valueCount-1){    // if got enough values
   frameFound = 0;                 //   reset
   Serial.println("");             //   send NewLine
   output();                       //   start output function
void output(){                               // output function
  for (int i=1; i < valueCount; i++){        // loop over all stored values
    if (frameFound == 1){                    //   if next value is full frame
      Serial.print(values[i]-values[i-1]);   //     output value
      Serial.print(" ");
      if ((values[i] -values[i-1])> minSync){   //     if current value is sync
        Serial.print("\tFrame Length: ");       //       output Frame Length
        Serial.print(values[i]-values[i-((channelCount+1)*2)]);
        if ((i+((channelCount+1)*2)) >= valueCount-1){// if no more full frame possible
            break;                              //         stop output
    else {                                  // else if still not found sync
      if ((values[i] - values[i-1])> minSync){  //   if sync found now
      frameFound=1;                         //     set frameFound "true"
void setup(){
  Serial.begin(serialSpeed);               // set serial speed
  pinMode(2, INPUT);                       // set PIN 2 as input
  attachInterrupt(0, pinChanged, CHANGE);  // setup Interrupt
void loop(){      // loop() not used
Old Sep 12, 2010, 04:17 AM
itai n is offline
Haifa, Israel
Joined Nov 2009
Sorry, I assumed that the main thing that you wanted was to interpret the PPM signal and use it in some system (eg., to contol a robot). In that case you really don't care about separate timing of the pulse and the gap that follows the pulse.
Now if you are after much more accurate results, you can use the Input Capture register (assuming your arduino uses ATMEGA328P there's only one on PB0, that's PIN8 of the Arduino. The value of the 16 bit hardware timer is copied to ICR1 immadiately when the event that you want to time happens, so the recorded values do not depend on the time it takes to respond to the interrupt.
Attaching AVR code (I'm using avr-gcc, not Arduino) that's reading PPM input. I think that can be used with Arduino as well.
AFAIK the 1/64 prescaler is the default in Arduino. You can change it to 1/8 and get even more accurate timing, but then you will not be able to use arduino functions that depend on it (like millis()).
Old Sep 12, 2010, 12:01 PM
Nase is offline
Joined Aug 2010
alright!
hm.. thanks for your code, having exactly the time when the interrupt occurs seems to be better, although I still don't know how (in)accurate my code is.. I'd really like to know this before I go over and over again..
Anyways, I will try to adapt your code to my needs.
True, Arduino code only is the first step, I'm pretty sure it can be improved by direct usage of ATmegas possibilities.. I just don't feel like reading the whole ATmega328 reference at the moment.
Old Sep 27, 2010, 06:47 AM
scottyvisco is offline
Find More Posts by scottyvisco
This helicopter smells funny
scottyvisco's Avatar
Berwick,Victoria,Australia
Joined Dec 2008
my result:
Code:
Code:
Code:
void setup()
  synced = 0;
void loop()
      Serial.print(" ");
      Serial.print(" ");
      Serial.print("    ");
        Serial.print("   ");
I am interested where you are getting the ppm signal from is it feeding from the mcu into the 2.4gig module cheers scott
scottyvisco is offline Find More Posts by scottyvisco
Old Oct 06, 2010, 12:55 PM
Nase is offline
Joined Aug 2010
I was reading from the trainer port.. output lines
Old Jan 24, 2011, 09:18 AM
Billimont is offline
Find More Posts by Billimont
San Juan
Joined Sep 2005
Hello:
I wrote a servo program that moves a servo to certain positions with arduino. Now I need to read form a receiver channel to start the servo program when I hit a button at the transmiter. I suppose that using some part of your program I can do this?
Billimont is offline Find More Posts by Billimont
Old Jan 24, 2011, 11:48 AM
Nase is offline
Joined Aug 2010
Originally Posted by Billimont View Post
Hello:
maybe you could..
not sure what exactly you want to do.. just start the program or pass through some signal. receiver should give you a pwm-signal that you could pass to the servo
Old Jan 25, 2011, 07:38 AM
San Juan
Joined Sep 2005
Im just trying to connect the servo to the arduino pin (as output) and channel 5 of the receiver to another arduino pin (as input) so when I click the channel button on the transmmiter, the servo will travel to specified positions, with a delay time between the positions and then return to the original position. The purpose of this is to trigger a camera button, with the servo, using prefocus first (much better pictures). Cannot connect to the channel 1-4 because they are in use. I found a program that moves the servo to the desired positions independly. I just need to access the channel from the receiver to give the order to run the program that I already have, when I hit the switch on the transmmiter . I dont know much about programing Arduino. (I am form the BASIC generation)
Question PPM to TX problem with arduino generated PPM Nase DIY Electronics 65 Jul 22, 2016 06:42 PM
Discussion Arduino code for BMP085 pressure sensor? 13brv3 DIY Electronics 23 Oct 24, 2011 11:07 AM
Discussion Need help flashing besc with Quax ppm code rjwims DIY Electronics 2 Aug 30, 2010 09:04 PM
Discussion help me !!!18f4455 ppm c18 code gta18 DIY Electronics 1 Apr 13, 2008 06:43 PM
PIC 'C' code + circuit to decode PPM JoeB99 DIY Electronics 24 Mar 08, 2005 02:47 AM
