Old Sep 09, 2010, 01:24 AM
TurboFanElectric is offline
Find More Posts by TurboFanElectric
www.turbofanelectrics.com
TurboFanElectric's Avatar
Tampa, FL
Joined Apr 2002
Mini-Review
HET ME-163 Prop Jet By TurboFanElectrics.com
Hello All,
We will be building the newest release from HET, ME-163 prop jet. The jet is constructed with a fiberglass fuselage and foam core wing that is fully sheeted with balsa and then covered; typical HET construction. The finish on the Fuselage is flawless. We will be equipping ours with a Typhoon 2w-23 with a 5x5 propeller on a 4s 2500mah lipo. Here are a few quick teaser pics. I will start the build on friday afternoon....stay tuned.
HET ME-163 Prop Jet: http://www.shop.turbofanelectrics.co...&categoryId=35
best regards,
William
2nd flight of this beautiful HET ME-163 Prop Jet
HET ME-163 Prop Jet available at www.TurboFanElectrics.com (2 min 4 sec)
TurboFanElectric is offline Find More Posts by TurboFanElectric
Old Sep 09, 2010, 08:24 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Very nice, I have mine also at home now,,, it will be interesting to see how she flyes..
One thing Ive noticed in the manual, the elevons should be 5-6 mm up, isnt that much ?
If you film this one, please include the handthrow, I want to see how it flyes out of the hand... Im having hard time to find a real grip ..
sebbe is offline Find More Posts by sebbe
Old Sep 09, 2010, 11:36 PM
jhaywood is online now
Find More Posts by jhaywood
jhaywood's Avatar
United States, VA, Suffolk
Joined Nov 2007
Would a JS 1400 work in this plane? A 5x5 on a Funjet runs about 165 mph. The reason I ask, I have one sitting around doing nothing and I have the go ahead to order the 163 for my birthday!
jhaywood is online now Find More Posts by jhaywood
Old Sep 10, 2010, 04:26 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
WHy not, this plane is as strong as the funjet, and I think even faster..
Just go for it..
Old Sep 11, 2010, 10:34 AM
Tampa, FL
Joined Apr 2002
jhaywood the js1400 should work fine.
sebbe we will definately video the handlaunch as well.
Old Sep 11, 2010, 10:51 AM
Tampa, FL
Joined Apr 2002
I would like to start the build off with the installation of the servos. One thing we noticed was the LS-02 rc lander metal geared servos we're using weren't tall enough when layed on there side so we had to add a piece of 1/8 balsa under each servo. This brought the rear end of the servo flush with the bottom of the wing.
Old Sep 11, 2010, 10:58 AM
Tampa, FL
Joined Apr 2002
Next we can move onto the control rod installation. The control rods consist of a threaded rod that may need to be trimmed depending on your servo orientation. On either side you have clevises. The manual calls for 5mm-6mm of up elevon for the neutral position. From my flying wing experience that's a little on the high side but we will start with 5mm and see how it goes.
Old Sep 11, 2010, 04:26 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
NIce building pics
Old Sep 12, 2010, 10:49 AM
Tampa, FL
Joined Apr 2002
Thanks Sebbe.
Old Sep 12, 2010, 03:08 PM
Tampa, FL
Joined Apr 2002
Next part of the build consist of the canopy build. Many people find the canopy's on the HET aircraft the hardest part of the build. They are a bit tricky but with some patience you will complete a beautiful canopy.
Old Sep 12, 2010, 03:53 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Very nice.....
I hope the magnets will hold down the canopy at high speeds
Old Sep 12, 2010, 04:05 PM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
mmm looks like a 36mm motor will fit with a firewall relocation
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Discussion New HET ME-163 prop jet ozzi supercub Pusher Prop Jet Models 685 Jan 03, 2015 10:03 AM
Build Log Rclander PC (plastic covered) Mig 17 W/ 10S by TurboFanElectrics.com ****VIDEO ADDED TurboFanElectric Foamy EDFs 25 Feb 07, 2011 09:55 AM
Mini-Review HET Super Tucano with Retracts, typhoon 2w-23, 4s BY TURBOFANELECTRICS.COM TurboFanElectric High Performance 81 Oct 18, 2010 04:59 PM
Mini-Review E-domodel 1/5 scale Yak54 by TURBOFANELECTRICS.COM TurboFanElectric 3D Flying 12 Sep 08, 2010 01:27 AM
For Sale Me-163 kit by Big Art's Models Thomas B Aircraft - Electric - Airplanes (FS/W) 2 Dec 17, 2006 11:40 AM
