Old Sep 09, 2010, 12:22 AM
Joined Aug 2010
Static noise from the microphone + video noise when motor is working
Hi to all
Here is my setup :
900 Mhz 1500mw RX\TX system from hobby king setup on a maxi swift with a Black stork II osd.
RX\TX :
http://www.hobbycity.com/hobbyking/s...CD_Camera_NTSC
OSD :
url]http://www.nghobbies.com/cart/index.php?main_page=product_info&products_id=173[/url]
Mic :
http://www.nghobbies.com/cart/index....roducts_id=156
After setting up and hooking up all the system I have 2 problems:
1. Microphone is working and transferring sound but it also transfers a constant static sound.
2. The picture I am getting from the camera is very good, the moment I start the motor I see "Noise" on the output of the video , a lot of diagonal lines ??
I tried taking the video TX as far as 50 cm from the rest of the electronic part - didn't help
Any solution will be much appreciated.
Here are some pictures (not final places of the equipment)
gpsnow is offline Find More Posts by gpsnow
Old Sep 11, 2010, 05:27 PM
Joined Aug 2010
any thoughts ?
Old Sep 11, 2010, 05:33 PM
Alcyon13's Avatar
France
Joined May 2010
About your video noise from your motor :
How your video tx is wired ?
You should take the power from the balance plug, or use ferrit rings (search for more info) or use a separate battery for the vtx
Alcyon13 is offline Find More Posts by Alcyon13
Old Sep 11, 2010, 05:38 PM
Joined Aug 2010
hi and thanx
Forgot to mention that the video problem was fixed as soon as I used a separate battery for the vtx.
Only problem now is the Static noise from the Microphone...
Old Sep 11, 2010, 05:41 PM
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
OK without the mic? Turn gain down on mic if u can.
badlands is offline Find More Posts by badlands
Old Sep 11, 2010, 08:26 PM
chancesAU's Avatar
Australia
Joined Apr 2008
If you can - move you ESC to the back - its VERY noisy - also the cables from your motor to ESC look CRAZY long! The shorter the better - less noise and stuff
1500mw is crazy too, more problems than anything else, 500mw can get you 5km... how far do u wanna try fly away?
chancesAU is offline Find More Posts by chancesAU
Old Sep 12, 2010, 12:11 AM
Joined Aug 2010
Tried to change the gain to minimum and maximum - didn't change anything.
ESC lines to motor are long , it's an extension cable just made for checking best distance from other parts, I'll try to check the system with out the extension cable.
about the 500mw I will go as far as 3-5 km no more.
Old Sep 12, 2010, 12:26 AM
chancesAU's Avatar
Australia
Joined Apr 2008
Dunno, just thinkin 1.5watts is maybe too much? maybe not, ive never tried...
Have you got another setup you can try the mic with? or another mic to try on that setup, would be good to start canceling out things.
Id try move the ESC a few inches from the motor mount and solder them wires nice and short, then wrap the ESC's RX plug lead around a ferrite ring a few times.
Mmm hope you get it sorted
Old Sep 12, 2010, 07:11 AM
SW England
Joined Aug 2009
'Static noise from the microphone' - are you sure it's not wind noise (from flight or the propellor)?
If so, try some foam over the mic!
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Sep 13, 2010, 12:56 AM
Joined Aug 2010
All tests done in house not in flight.
Esc has a ferite ring allready.
I'll try to check with another mic today.
Also got some new ferite rings so I'll try to put one on the mic leads.
Old Sep 15, 2010, 12:20 AM
Joined Aug 2010
okay seems that the TX is the problem
While cheking with another microphone I saw that even if the Microphone is disconected what comes out of the reciever is with Static noise ???
that means that the TX is transimiting that noise on the audio line.
Does any body else has a 1.5W TX from hobbyking that works good with a microphone ?
Old Sep 15, 2010, 12:29 AM
chancesAU's Avatar
Australia
Joined Apr 2008
opps wrong thread lol
Hope you get it sorted tho... id just get a 200mw from there, its gonna be heaps hey, ive gone over 1km on the same freq & power and still clear as.
Old Nov 18, 2010, 12:22 PM
Joined Dec 2008
Did you solve the issue with the noise?
I have the same hobbyking system (1500mW) and my main problem is tx is affecting the servos.
gusgole is offline Find More Posts by gusgole
Old Nov 18, 2010, 06:06 PM
Joined Aug 2010
gusgole
try taking the video's Tx antenna as far away as you can from the servos.
I did it with an extension cable from the video Tx to the actual antenna and took it about 40 cm farther on the plane.
You can see changes immediately just by rotating the antenna 90 degrees
Still have noise but no servo jitter..
hope this helps
Discussion Audio / video noise when OSD is ON metalfred Eagle Tree Systems 10 Sep 02, 2010 10:26 AM
Question HXT900 making buzzing noise when no load given daewon774 Radios 3 Aug 26, 2010 04:26 PM
Question Static sound from included Microphone? DPCAV Vid Tx rclab1 Video Piloting (FPV/RPV) 3 Jul 29, 2010 08:23 AM
Discussion Weird motor noise when low throttle applied Jtupnsmoke Power Systems 7 May 31, 2010 10:59 AM
Discussion Microphone fades to static Daemon Video Piloting (FPV/RPV) 10 Jan 07, 2010 04:18 AM
