Old Sep 12, 2010, 06:05 AM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Richard, not seen a plastic one but sounds like a good idea.
I hear yesterday a Speedfire in Bad B Eurotour had a prop failure. I wonder who it was and what the prop was.
Andre, the RW2B wing is still good. Why don't you make a better fuselage for it?
jjmouris is offline Find More Posts by jjmouris
Old Sep 12, 2010, 04:24 PM
silva916 is offline
Find More Posts by silva916
Germany, 300 meters from the Netherlands
Joined Sep 2010
Joe,
The Prop was a RFM, the Speedfire makes ( still ) a lot off noise pffffffffffffff.
But I think is was because of the big fuselage.
The develper told me that he would make a new fuselage ( smaller )
Greetings Frank
silva916 is offline Find More Posts by silva916
Old Sep 12, 2010, 04:29 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Frank,
I am holding my breath then.
Looks to be a good plane (with new fuselage) at a much more affordable price.
Joe
Old Sep 12, 2010, 05:30 PM
decones is offline
Find More Posts by decones
making my own planes...
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
Joe,
I think I'm the only one that likes this square lipo fuse, it's roooooomyyyy!!!
no split batteries needed, no hard job to fit a 6S 3300
decones is offline Find More Posts by decones
Old Sep 12, 2010, 07:10 PM
GJVO is offline
Find More Posts by GJVO
GJVO's Avatar
The Netherlands, NH, Amsterdam
Joined Jan 2007
The plane flew OK, like Frank says, a lot of noise, so a loss of energy.
The fuse is huge, i think you can put in 5S 2P.
The wing has a lot of dihedral.
In the turns it looks like it is breaking, so much dihedral, and that are not my words..
The plane will be about 550 euro without servo's and a delivery time of 1,5 month.
I have looked at it very carefully, maybe it was a prototype but compared with an RFM Surprise of Avionik i think the Avioniks an Surprises are better build.
But.. maybe it was a prototype, that was the plane with the exploded prop, without a nose.
GJVO is offline Find More Posts by GJVO
Old Sep 14, 2010, 09:48 AM
SkorpionCZ is offline
Find More Posts by SkorpionCZ
Czech republic
Joined Nov 2006
It is very funny to read any "clever" comments Primary from people which don't see my plane.
Clearance on my plane are good. I don't have any problem with this. Go One fly with similar system and world can be wonder, it works ! ! !
Spinner - immortal question Next my plane will have 36mm spinner. I thing 32 or 33mm bring nothings. Georgi make spinner 36 and 38mm and all propeller can be used for this diameters. Who from my costumer want fly with sergey props ? One or two?
2 or 1 servo. I thing next plane will be really with one servo. I say why... less work for me. Other advantage ? Nothing. Same weight for one or two servos system and and and ....
Avioniks and Surprises are better build - I was on the contest in Bad Brückenau too. Don't see any Avionik and Surprises which has better building quality. Maybe i need glasses
Petr Janků
www.f5b.cz
SkorpionCZ is offline Find More Posts by SkorpionCZ
Old Sep 14, 2010, 12:18 PM
Gerben is offline
Find More Posts by Gerben
Joined Dec 2004
Hi Petr,
It was a pleasure to meet you in Bad Bruckenau and see you fly!
Hope you had a good trip home.
Regards,
Gerben
(The Dutch Pilot)
Gerben is offline Find More Posts by Gerben
Old Sep 14, 2010, 02:46 PM
GeorgiMirov is offline
Find More Posts by GeorgiMirov
The props of tomorrow
Varna , Bulgaria
Joined Feb 2007
Hello ,
Today was the maiden flight !
Plane is flying great.Not loosing altitude like the Enigma in the turns.
I flew it with let's say 40% CG the "factory settings" are for 33%. This was with my "soft" 1512 1D setup. The thermal is a piece of a cake. At low speeds (at big altitude) with this CG there was some airflow detachments(stalls) but not such problems at real legs speed.I really like it. The true test will be on the bases after one month or sooner.
I will then upgrade to my 6kW+ setup and will practice more to get used to the plane.
Regards
GeorgiMirov is offline Find More Posts by GeorgiMirov
Old Sep 14, 2010, 03:20 PM
grobbins666 is offline
Find More Posts by grobbins666
grobbins666's Avatar
Huntington Beach So. Cal
Joined Jul 2008
Petr Janků
www.f5b.cz
I can get a good look at a T-bone by sticking my head up a bull's ass, but I'd rather take a butcher's word for it
grobbins666 is offline Find More Posts by grobbins666
Old Sep 14, 2010, 09:20 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Ok Petr, how about I make my own 32mm nose fuselage?
Will the wing change at all for your new fuselage or will it stay the same?
Joe
Old Sep 14, 2010, 09:47 PM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Build quality: if it is anything like the backfire, is better than straair, and that says a lot. Is it an avionik? It felt the same to me, but you cannot judge before seeing how much the plane will endure.
Noise: I have a hard time finding fault with thte airfoil. This is not a kid in his basement carving wings out of foam. Dirk Pflug is responsible for the airfoil, and I have enough faith in his work to trust it. When I watched the protype fly, I can say that it thermals almost as well as the 2.4m backfire. Loss of speed in turns was better than surprise 14. I cannot judge against avionik, because that day the motor setup was only 3k, so there was not as great an entry speed as I am accustomed to watching on the b08. Yes this also means speed loss in turns observed was what I am used to seeing in the b08's at the third leg.
I am ordering mine as soon as I decide on colors.... (could take a while)
la528it is offline Find More Posts by la528it
Old Sep 14, 2010, 11:35 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Rich,
Asside from mentioning that Dirk Plug knows his stuff your post is purely subjective and non scientific. No measured data.
Sorry but I don't class you as an expert either so....
If Wolf on the other hand comments on noise and or bending wings I take notice.
Still I prefer measured data. Failing that, results!
Old Sep 15, 2010, 12:05 AM
la528it is offline
la528it's Avatar
Joined Dec 2007
Rich,
I did not see any wing flex on a 3kw setup. And unless "Iron" Remo is always at the controls, I personally believe that course results are more subjective structural observations. Then again, I'm sold, if you are on the fence, then best to await more real world numbers; if I was competitive I know I would!
Cheers
Old Sep 15, 2010, 06:17 AM
v-willy is offline
Find More Posts by v-willy
Joined Jan 2006
I have seen the speedfire in Bad Bruckenau and it looks good.
About the noise people where asking why my avionic makes a different noise then the others. I believe it is because of i made 2 cooling holes in the nose.
For the speedfire i believe when there will placed a small tape on the hinges the noice will be totaly different. Maybe Petr can test it by himself and let us know.
Willy
v-willy is offline Find More Posts by v-willy
Old Sep 15, 2010, 09:33 AM
Varna , Bulgaria
Joined Feb 2007
Tape on the hinges ? on the ailerons ? or I'm not understanding what you mean ?
I can also test it.
For Sale Tiger F5B Hotliner IamLegend Aircraft - Electric - Airplanes (FS/W) 13 Oct 27, 2010 04:27 AM
For Sale lea v f5b fast models Aircraft - Electric - Airplanes (FS/W) 4 Aug 12, 2010 01:12 PM
Question USA F5B teams wrathofkhan Electric Plane Talk 4 Aug 12, 2010 05:36 AM
Question Anyone out there flying a "Weasel 2M Electric F5B"? Flyextreme Electric Sailplanes 0 Jul 31, 2010 02:24 AM
Question F5B Demeanor (LF-F5B) snakecrew Slope 6 Mar 19, 2010 01:35 AM
