Old Jan 03, 2013, 03:07 AM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Originally Posted by Gerben View Post
That's odd, I find I can get away with about 85% travel on my Graupner transmitter and still reach 100% throttle.
Gerben
Yes but if you used auto throttle rather then fixed throttle on the ESC this may be a different story?
In ANY case, the ESC should have been fine. You should be able to run part throttle for as long as you like. Or until thermal shut down. That is, if the full throttle load is below or very near the current rating of the ESC (which it is).
What does present a significant problem is response speed 10 with throttle on the stick or no ramp on the TX. This has the potential for very fast changes in RPM where the ESC could fluff up and damage it self.
I would not call your setup an F5B setup but just an electric glider and ask them if response speed 10 could have caused a problem with 60.000 RPM on a 4 pole motor on tap. Insist on a FREE replacement and state that you where running within spec.
Try response 6 and you should be just fine.
Joe
jjmouris is offline Find More Posts by jjmouris
Old Jan 03, 2013, 06:44 PM
plainguy is offline
Find More Posts by plainguy
Take off, eh
plainguy's Avatar
USA, CA, Long Beach
Joined Jan 2009
I have been in touch with Castle and it seems the fine people there will be sending me a replacement.
I will follow up on your advise Joe.
Thank you all once again.
plainguy is offline Find More Posts by plainguy
Old Jan 03, 2013, 10:01 PM
plainguy is offline
Take off, eh
plainguy's Avatar
USA, CA, Long Beach
Joined Jan 2009
very happy to say. the ESC was already waiting for me at home. :-)
THANK YOU CASTLE!!
Old Jan 04, 2013, 08:33 PM
plainguy is offline
Take off, eh
plainguy's Avatar
USA, CA, Long Beach
Joined Jan 2009
Since i am going to adjust throttle response from 10 to 6 -are there any other settings I can adjust that will be gentler / kinder to ESC or motor?
I am interested in some fun and having system last a little longer not in competing or sacrificing equipment in order to win a competition.
thanks,
raul
Old Jan 04, 2013, 08:55 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Anyone playing with snap flaps on their speedfire?
I have them programmed, but in a year of flying it, have never used them.. Better give it a go tommorrow
jackosmeister is online now Find More Posts by jackosmeister
Old Jan 05, 2013, 01:30 AM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Yes, it is absolutely necessary, but it is very effective, I use very little and it's great!
la528it is offline Find More Posts by la528it
Old Jan 06, 2013, 05:43 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
thanks,
raul
Change brake ramp to "Fast".
Enjoy.
Old Jan 24, 2013, 02:27 PM
TimR74 is offline
Find More Posts by TimR74
United Kingdom, Wales, Monmouthshire
Joined Aug 2011
Well, after a lot of deliberating, I've just bitten the bullet and ordered a white/fluro orange/carbon Speedfire from Petr. Want to have a crack at a F5B comp or two this year. Anybody know of any other Speedfires in the UK?
Gone for the lazy+expensive option of having the servos installed. Time to start researching and thinking about how it's going to be propelled...
TimR74 is offline Find More Posts by TimR74
Old Jan 24, 2013, 04:15 PM
Highfly! is offline
Find More Posts by Highfly!
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
Go for a HV setup. You will be happy you did.
Highfly! is offline Find More Posts by Highfly!
Old Jan 25, 2013, 02:27 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Tim, please give me a call before you spend any more money.
Joe
Old Jan 25, 2013, 03:54 AM
TimR74 is offline
Joined Aug 2011
Joe, I've been through a few of the older setup threads and and know you'll probably advise against going HV. I'll be self launching all the time so want to run partial throttle for a couple of seconds at launch, and HV looks the better bet to stay pretty much within spec of the ESC. Running a 1512 2.5D or Jeti Phasor 2035/2100, I can always start on a light 6S pack intially then move up to 8S and finally 10S. Don't want to jump straight in with 5kW and 18inch prop on a switch.
Might start with a very light 2kW sport set up as I've got an Ice light 100 spare and chose a light motor+GB that will get used for a future project.
Old Jan 25, 2013, 04:43 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Tim, it is up to you as always.
I've got plenty of spare parts that can help get you started, even some HV stuff from when i first tried HV a couple of years ago. Got a Neu 1512/2.5D and a Hacker with Neu gearbox up for grabs.
I was going to offer you the use of my current budget drive, a Neu 1509/1Y and GM 18x23 V2 with a budget controller. You can use that with 4S, 5S and finally 6S. I've got an old 5S and a new 6S pack you can use as well. The controller has inbuilt ramping and comes with my personal guaranty that it won't burn no matter what you do with part throttle.
If you do go HV, that Jeti motor sounds like the way to go. I am infact very close to getting a 4100KV one to compare against my 67mm Hacker.
Old Jan 25, 2013, 06:40 AM
dickw is offline
Find More Posts by dickw
Grow old disgracefully!
dickw's Avatar
Luton, UK
Joined May 2006
Originally Posted by jjmouris View Post
If you do go HV, that Jeti motor sounds like the way to go. I am infact very close to getting a 4100KV one to compare against my 67mm Hacker........
The Jeti is a nice motor. I liked mine so much I just bought a second one.
Dick
dickw is offline Find More Posts by dickw
Old Jan 25, 2013, 12:38 PM
OTA is offline
OTA
Find More Posts by OTA
OTA
Wannabee
OTA's Avatar
Norway
Joined Aug 2008
Dick
Sounds just perfect I added a 2026/3600 motor to my order from Petr which is to close to delivery. Looking forward to get my double carbon spread tow show model soon and will fly it on somewhere between 4 and 6S with a YGE 200FAI and GM 18 x 21
OTA is offline Find More Posts by OTA
Old Feb 01, 2013, 11:14 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Somebody please FFW me about 4 months....
Arcteryxxx is offline Find More Posts by Arcteryxxx
For Sale Tiger F5B Hotliner IamLegend Aircraft - Electric - Airplanes (FS/W) 13 Oct 27, 2010 03:27 AM
For Sale lea v f5b fast models Aircraft - Electric - Airplanes (FS/W) 4 Aug 12, 2010 12:12 PM
Question USA F5B teams wrathofkhan Electric Plane Talk 4 Aug 12, 2010 04:36 AM
Question Anyone out there flying a "Weasel 2M Electric F5B"? Flyextreme Electric Sailplanes 0 Jul 31, 2010 01:24 AM
Question F5B Demeanor (LF-F5B) snakecrew Slope 6 Mar 19, 2010 12:35 AM
