Old Sep 09, 2010, 08:57 AM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Originally Posted by GeorgiMirov View Post
It's not RDS. It's just servos with very small arms and also small arm in the ail/flaps.
I'm now finishing the wiring. Will post pictures this evening.
Georgi,
Make sure you post the flaps at full deflection. Thanks!!!
Jay
soholingo is offline Find More Posts by soholingo
Old Sep 09, 2010, 12:07 PM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
This plane flies awesome, at least the prototypes did. If you go to the bottom of this page:
tinyurl.com/praha24
you can see some upclose pics and some of the plane in flight
la528it is offline Find More Posts by la528it
Old Sep 10, 2010, 06:53 AM
GeorgiMirov is offline
Find More Posts by GeorgiMirov
The props of tomorrow
Varna , Bulgaria
Joined Feb 2007
Hello ,
Plane is ready to fly now. All settings adjusted as advised by Petr.
With my 4S setup 1512 1D CC 125 and NeuEnergy 4100mAh the weight is 1608gr.
With my 6S setup 1512 1,5D (blue monster) CC 125 and 6S 3250mAh - 1730gr. - but motor and cells too heavy.
It takes about 2-3 hours to get it done.
Flap deflection for butterfly can be even more but my radio can't do it, however it's good enough.
Some pictures attached.
Maiden will be delayed due to bad weather conditions.
GeorgiMirov is offline Find More Posts by GeorgiMirov
Old Sep 10, 2010, 12:10 PM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Looks good.
But..... the linkages are as i thought they would be. This means very short moment arm on the controll surface horn. This means not all travel on servo is used. This means probably a lot of slop. Even if servo has very short arm also, all these short arms will see a lot of force so slop will develop.
Fuselage is huge, tailboom also huge. In comparison B08 is 8mm wide and 12mm high (from memor), the B06 and B1L tailboom fit inside the B08 so are even thinner.
Also a shame the nose diameter is not the standard 32mm.
Sorry for negative writing, it is a nice plane ofcourse.
jjmouris is offline Find More Posts by jjmouris
Old Sep 10, 2010, 02:12 PM
Varna , Bulgaria
Joined Feb 2007
Joe is always there as usual ... but .
Joe the linkage is great.No slop, great controlling and no problems at all. One thing I don't like in the Avionik is that the ail/flaps are cut downside.Also that the linkage is donwside.
Then this wing is about 10gr lighter.
About the fuse, fuse have some weak spot in design but , it's very light and strong. Then the big outside diameter is because of the 2 rods passing from the servos to the V-tail , no way to be thinner. Also you can fit inside whatever Lipo you want.
About the "standard" 32mm... who said it's a standard ? Also there is no difference at all if it's 33, 36 or 38mm ... at all.
Fuse don't create such drag as the wing.
Example : are the fuses of the big gliders like needles ? This is not important.
However I'm not saying it's better than Avionik - I can't say this. It's a cheaper ship.
The idea is to brake the walls with cheaper ship.
Old Sep 10, 2010, 03:23 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Georgi, i really would like to hold that wing in my hand after 50 flights and feel the controll surfaces. Maybe it will be fine, i don't know. Yes i am very critical. Hope it works as it would be really nice and clean.
Why have 2 rods in the fuselage boom? For F5B flying 1 Servo and 1 rod is enough.
Nose diameter, as discussed with Petr himself. I think it is better to provide a 32mm nose. If people really want 36-38mm they can cut it back them selves. Sergey only makes 32mm props and now i can not use them with this plane. Do it for RFM props? Well those are only good for distroying planes these days and RFM do also make 32mm spinners.
Petr can build nice planes i have seen.
Old Sep 10, 2010, 04:11 PM
Varna , Bulgaria
Joined Feb 2007
Joe please measure the Avionik Fuse .... is it 32mm ? I'm making such spinners since 2 years for Avioniks and I can assure you they are 33mm so where is the standard ?
I wanna see a picture of a caliper on your planted B08 fuse and also on some bananas you have.
I'm getting mad about all these bull#hit$...
Old Sep 10, 2010, 05:04 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Georgi, who cares if it is 32mm or 33mm. The point is a Sergey prop will not fit on a 38 or even 36mm nose!!!
I don't wonna buy a plane only to have to extend the nose somehow. If i where in the reverse possition, cutting some off would be easy!
Joe
P.s. Avionik fuselage is 33mm but the props are 32mm.
Old Sep 10, 2010, 05:18 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Now, could you measure what the distance is between the center of wing bolts?
For reference, RW2 wing has 51mm and Avionik B08 has 48mm.
Also how big a battery can you fit in her? Any pictures of battery packs fitted?
Many thanks!
Old Sep 11, 2010, 03:45 AM
Varna , Bulgaria
Joined Feb 2007
Hi Joe ,
Can you please measure for me the weight of your setups ( I mean motor+esc ).
Mine are :
1512 1D (long GB) + CC 125 - 442gr.
Blue 1512 1,5D (long GB) + CC 125 - 464gr. (but I will rework the case to save some grams)
What was the weight of your blue motor before and after the rework ?
I was having a 1510 1Y for couple of seconds but will have to ship it to USA. It's was a little bit lighter but same case length as 1512 ... why I don't know.
Unilog + 400A sensor is 23 gr.
Radiator I put on ESC is 9gr.
Bolt distance of Speedfire is 55mm same as the Enigma.
Pictures of the fuse and lipos I have , Dualsky lipos are 44x45mm.
Old Sep 11, 2010, 10:46 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Georgi,
Thank you. That is pritty big!!! Guess you could even fit the Turnigy 5000mah cells in there!!!
What happened to your 1510/1Y ?! Magnets cam off?
Weight of the Dualsky 6S 3250mah ?
For you then;
Neu 1512/2.5D/6.7 (long gearbox) shaved blue motor 352 grams
Neu 1511/1Y/6.7 331 grams
I measure the spacer at 14 grams on precise scales.
Turnigy 6S 3000mah 40C 512gr
TP 6S 3300mah 30C 517gr
TP 6S 3250mah 45C 521gr
B1T fuselage RTF including Neu 1512/1.5D/6.7 (long gearbox) / P180 is 789gr
B1L wing RTF 424gr
So my total flying weight is around 1730 grams average. Way to heavy!!!
I blame my fuselage (T-tail) and the motor. Need to get below 1600 grams.
Joe
Old Sep 11, 2010, 02:11 PM
Varna , Bulgaria
Joined Feb 2007
Good Joe thanks ,
I've made my model ready to fly with all little details ( I mean switch for the Rx + velcro for Rx , Rx Lipo and unilog) Full weight with 1512 1D and 4S 4100 is 1640 gr.
We decided to build a full competition fuse for this wing(but not right now, maybe a 2011 project).The fuse with the 2 rods and 2 servos is about 30 gr. heavier than the avionik b08 fuse.
Also my Rx pack is 55gr. ( 740mAh +4 6A diodes) I can make it 30 with a 350mAh lipo.
On the way to me are 2 packs :
Turnigy 2650 6S 40C
Turnigy 3000 6S 40C
So time will show...
Dualsky is 535gr but don't deliver more than 4.8kW so I'm complaining because they say 6000W. So waiting a reply from the producer.
1510 1Y throw a magnet. There was only 4 rolls of carbon ( after I've open it after the collapse ) Stupid myself that I didn't reinforced it before use it , or stupid I trusted the factory quality ? Still don't know who is stupid.
Old Sep 11, 2010, 02:38 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Georgi, when you say "we" who do you mean?
I asked Petr to do a competition fuselage with thinner tailboom, 1 servo setup and ofcourse the 32mm nose. I think perhaps now also shave some off the bottom of fuselage so 6S 3300mah only just fits, not with room to spare.
Can't complain about Turnigy, i also have a 6S 3000mah 30C pack that is still going strong. You do need to open them up, resolder some bits and reverse the wires to make it more compact. The best are still Thunder Power in terms of quality, use them out of the box. All are more or less the same size and weight.
Regarding Neu motor. If it was over 60.000 i guess it is your fault. If below then it is their fault.
Joe
Old Sep 11, 2010, 04:21 PM
la528it is offline
la528it's Avatar
Joined Dec 2007
Joe i have seen two verism of the spacer. The metal one was heavier than the plastic. If your is metal you can save a title weight with the plastic one.
Hope this helps. The tail is fantastic for thermal duration turns, at least in my opinion. I was flying the pig today (enigma) and missed the rudder in thermal mode.
Old Sep 11, 2010, 09:08 PM
decones is offline
Find More Posts by decones
making my own planes...
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
Georgi,
did you fly it?
comments?
such a nice plane
decones is offline Find More Posts by decones
For Sale Tiger F5B Hotliner IamLegend Aircraft - Electric - Airplanes (FS/W) 13 Oct 27, 2010 03:27 AM
For Sale lea v f5b fast models Aircraft - Electric - Airplanes (FS/W) 4 Aug 12, 2010 12:12 PM
Question USA F5B teams wrathofkhan Electric Plane Talk 4 Aug 12, 2010 04:36 AM
Question Anyone out there flying a "Weasel 2M Electric F5B"? Flyextreme Electric Sailplanes 0 Jul 31, 2010 01:24 AM
Question F5B Demeanor (LF-F5B) snakecrew Slope 6 Mar 19, 2010 12:35 AM
