Old Sep 08, 2010, 06:02 AM
HallaBalla is offline
Find More Posts by HallaBalla
Foam shredder
HallaBalla's Avatar
The land of fjords
Joined Sep 2010
Anyone tried the BlitzRCWorks MX2 Pro 3D?
Found it on BananaHobby.com: http://www.bananahobby.com/1970.html
I'm considering graduating from my Cessna-type high wing foamies, and I wonder if this model might be worth a try.
Anyone tried it? How is the build quality, performance, ruggedness, ease of flying etc? Thanks in advance.
HallaBalla is offline Find More Posts by HallaBalla
Old Jul 01, 2011, 08:09 PM
p901P901 is offline
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
The one I received, the ESC did not work. After the first flight the elevator hinge broke and the aileron hinges where so loose that I could move them up and down 1/4" at the leading edge. I replaced the rudder and elevator hinges with Robart 1/8 hinge points and the ailerons with 3/16 robarts. On the ailerons you have to insert a block of wood into where the old hinge points where to stiffen this area up. Also if you plan on some high speed maneuvers you must stiffen the wing up with a carbon fiber rod or the wings will flex.
I replaced the ESC with a 30A Volcano Series from Hobby Partz and static amps is 35 amps at full throttle with a 13 x 4 APC prop. So far the motor is holding up and using the APC prop performs much better than the stock prop.
After all these mods the plane response is better but its not an real good 3D plane.
p901P901 is offline Find More Posts by p901P901
Old Mar 26, 2012, 08:16 AM
superredeye is offline
Find More Posts by superredeye
Joined Sep 2010
Sorry wrong place
superredeye is offline Find More Posts by superredeye
Discussion KDS Flymentor 3D has anyone tried one Flying Barry 3D Electric Heli Flying 8 Dec 26, 2011 07:09 AM
Discussion BlitzRCWorks Tornado 3D vs. Blade SR RTF Tinytacohead 3D Electric Heli Flying 15 May 19, 2011 12:35 AM
Discussion Anyone tried Mia or Zulu Canopies? shastamike Micro Helis 23 Aug 10, 2010 10:11 AM
Discussion Anyone tried 3D features of FMA Co-pilot II DominicM 3D Flying 0 Feb 12, 2010 02:09 PM
Discussion Anyone tried the BlitzRCWorks F-86 Sabre cutty01 Foamy EDFs 33 Sep 23, 2009 04:02 PM
