Old Sep 13, 2010, 10:40 AM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
Originally Posted by EmpireHobby Tech View Post
Randall,
Every quad seems to have it's own unique personality. Believe it or not, you can add sub-trim via your radio with no detrimental effect! I would just neutralize your trims now, and add a little sub-trim until it can hold itself there for a few seconds.
Keep in mind that your "hands off" trim may change every time you plug in the quad... it just depends on how level you have the quad when you plug it in and let the gyro initialize.
Team Empire
That's what I've found out. I first got into quads with a Walkera UFO 8# and it's the same way. They all behave just a little differently. I'm sure my Gaui will handle differently once I get my apc's and my FY20A. Then I'll have to relearn the tweeks all over again.
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old Sep 13, 2010, 11:21 AM
EmpireHobby Tech is offline
Find More Posts by EmpireHobby Tech
Joined Aug 2010
Originally Posted by Tahoe Ed View Post
...I would love to go out and fly under the lights tonight but the bears have been really active this year and I really don't want to fend off a 400 pound black bear with my 330. ;-)
Yikes!!!
To fly, or not to fly... sometimes such a simple question is a tough call!!!
EmpireHobby Tech is offline Find More Posts by EmpireHobby Tech
Old Sep 13, 2010, 01:05 PM
keithdubya is offline
Find More Posts by keithdubya
Build - Fly - Crash - Repeat
Arlington, TX
Joined Sep 2007
Where o they sell the sponge tape? I hate to say it but I used all of mine.
Keith
Sounds like you guys are all learning the tips and quirks needed to troubleshoot your quads!
- Vibration: The GU-344 is very sensitive to vibration. I just saw a thread where a guy lost the sponge tape from the kit, and just double-sided taped the gyro to the frame. It did not fly well for long!!! He found the tape, re-secured the gyro and all is well.
Team Empire
keithdubya is offline Find More Posts by keithdubya
Old Sep 13, 2010, 01:13 PM
Arlington, TX
Joined Sep 2007
Yikes!!!
I am glad the worse thing I have to worry about here in Texas is mosquitoes. Have you considered mounting a 30 30 on your quad?
Keith
Old Sep 13, 2010, 01:53 PM
Joined Aug 2010
Keith
Hi Keith,
Unfortunately, the only way to get the actual Gaui sponge tape is in the gyro box itself. However, check your local hobby shop for something similar. Standard tail gyro vibration dampening tape should do the trick.
Team Empire
Old Sep 13, 2010, 03:01 PM
kyalamikid is offline
Find More Posts by kyalamikid
kyalamikid's Avatar
Kyalami, South Africa
Joined Jun 2006
I appreciate all the tips. I did two things; one, I flipped the dip switches an made sure that I was in X mode and Cru, then two, I reprogramed the ESC's for a third time. I am not sure which it was but the 330 is now flying stable and capable of hands off for 10 sec. I think that the switches may have moved slightly during transport and resetting them may have been the key, but who knows. I trimmed it out a little and reduced the D/R by 10%. I am now going to add my FY 20A and start flying on my 3S packs. If that works well, I will start to add my video equipment back on. I would love to go out and fly under the lights tonight but the bears have been really active this year and I really don't want to fend off a 400 pound black bear with my 330. ;-)
Glad to hear its finally working for ya!
kyalamikid is offline Find More Posts by kyalamikid
Old Sep 15, 2010, 03:01 PM
BobRCnut is online now
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Keith
Check this out: http://www.allerc.com/product_info.php?products_id=5054
BobRCnut is online now Find More Posts by BobRCnut
Old Sep 15, 2010, 03:08 PM
sfbbqguy is offline
Find More Posts by sfbbqguy
Bay Area, CA
Joined Aug 2010
Just starting my 330x build...is there an easy way to clean off the white residue that is created by the CA?
sfbbqguy is offline Find More Posts by sfbbqguy
Old Sep 15, 2010, 03:19 PM
RTRyder is offline
Find More Posts by RTRyder
Registered Lunatic
RTRyder's Avatar
Boston, MA
Joined Jul 2010
Keith
I have flown my 330X quite successfully with the GU344 secured by hook and loop velcro. I found in my case at least that it didn't make any difference whatsoever in the flight characteristics if I used the foam tape or the two part velcro, each one seems to give an adequate amount of vibration isolation.
This is a test flight in the backyard using the velcro'd GU344 and a GoPro strapped to my head. Note that hitting the tree branch had nothing to do with the way the GU344 was secured...
Gaui close quarters flying (2 min 41 sec)
YRMV...
RTRyder is offline Find More Posts by RTRyder
Old Sep 15, 2010, 03:55 PM
Joined Feb 2004
I would also think that some black foam tape like they use to wrap pipes in would work. I've used that quite a bit to vibe proof cameras. A little spray 3m glue works pretty well to make them into a sandwich. I've found that 2 layers are more than adequate.
Old Sep 15, 2010, 05:23 PM
KAMAX-T is offline
Find More Posts by KAMAX-T
KAMAX-T's Avatar
Powell TN
Good Idea Randall .... I have flew my 330x for atleast > 4.5 hours . I get 9.5 mins out of 1100mah 3s hyperion battery .... I have had troubles at all , and love this thing. I took the gyro out , and stuck it in another frame , somewhat larger , and with a little different gyro setting it also flew well .....
Terry
KAMAX-T is offline Find More Posts by KAMAX-T
Old Sep 15, 2010, 08:08 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Im looking to do the same thing... if Gaui doesn't make a bigger quad and beat me to the punch! lol
AceMigKiller is offline Find More Posts by AceMigKiller
Old Sep 15, 2010, 08:21 PM
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
Don't bother, you'll be re-gluing them every time you bump the blades.
vic20owner is offline Find More Posts by vic20owner
Old Sep 15, 2010, 09:06 PM
ColoradoHeliNut is offline
Find More Posts by ColoradoHeliNut
United States, CO, Lakewood
Joined Mar 2007
You can get CA disolver at your LHS.
ColoradoHeliNut is offline Find More Posts by ColoradoHeliNut
Old Sep 15, 2010, 10:48 PM
RotorCycle is online now
Find More Posts by RotorCycle
Thermals the path to elevation
RotorCycle's Avatar
United States, AZ, Chandler
Joined Jul 2004
Finger-nail polish remover or acetone will dissolve CA.
RotorCycle is online now Find More Posts by RotorCycle
For Sale RTF Gaui 330X-S QUAD FLYER KIT WITH SCORPION MOTOR AND ESC. 3DTRYER Aircraft - Electric - Helis (FS/W) 10 Oct 06, 2010 03:01 PM
For Sale RTF Gaui 330X-S QUAD FLYER KIT WITH SCORPION MOTOR AND ESC. 3DTRYER Aircraft - Electric - Helis (FS/W) 1 Sep 12, 2010 10:14 PM
Discussion Gaui 330x s ripmax Multirotor Talk 6 Aug 11, 2010 05:12 PM
Sold Gaui 330X S (Scorpion)version Quad NEW Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Jul 28, 2010 11:48 AM
