Old Sep 07, 2010, 03:20 PM
Doug
WinginIt's Avatar
Crappy Weather, Ohio
Joined Apr 2005
Canister mufflers from China
I am seeing a number of listings on ebay and elsewhere for canisters w/flex headers for DA and DL engines. looks like they would be around $115 or so per can so you could fit a DA-100 for $230 plus mounts.
Does anyone know anything about them?
Here is one ad:
http://cgi.ebay.com/Canister-Silence...item3a5b272674
WinginIt is offline Find More Posts by WinginIt
Old Sep 10, 2010, 09:37 AM
GmanBill's Avatar
United States, CA, SYLMAR
Joined Nov 2007
Yes I do know a little about them, they work great on the canister end and were patterned after a KS canister. The only but is the flex on the header, they require a lot of work once you get it in the shape and position you want if you do not want it to come apart or leak, you need to solder (silver with a torch) and then wrap in Teflon. It is time consuming but once you have it done it works well. It is almost worth ordering the setup then also ordering a pair of headers alone from DA and tossing the headers that they send in the back of the toolbox for a later project, it would save you a bunch of money and you would have the headers for a couple 50cc projects, that is about all ones with that much flex are good for.
GmanBill is offline Find More Posts by GmanBill
Old Sep 12, 2010, 01:25 PM
Doug
WinginIt's Avatar
Joined Apr 2005
Thanks for the info. I really appreciate it.
Old Oct 02, 2010, 05:01 PM
boolat's Avatar
Turkey
Joined Oct 2005
This is the version to smoke?
Canister Silencer Header for RC Model Plane 42cc - 65cc
thx
boolat is offline Find More Posts by boolat
Old Oct 07, 2010, 02:08 PM
vwchad's Avatar
Washington
Joined Apr 2010
Curious about this procedure. I have one and the flex part of the header (most of the header) is one solid piece. The flex part is like an accordian, the only way it would leak is if it broke. Think of a flexible water line for a hot water heater. That is probably the closest thing I can think of to relate it to. I see no need to solder and wrap this style of header.
vwchad is offline Find More Posts by vwchad
Old Nov 01, 2010, 02:53 PM
Doug
WinginIt's Avatar
Joined Apr 2005
Most of the headers, Chinese or not, seem to leak at the flex joints after a while. That's why most people wrap them.
Discussion Buying discount merchandise from china? sea20 Batteries and Chargers 26 Aug 13, 2010 10:07 AM
Discussion Advice: Shipping from China Dan203 Micro Helis 2 Jul 25, 2010 02:58 AM
New Product Xaircraft X500-D $300 ARF brushless quad from China SebastianJ Multirotor Talk 1097 May 31, 2010 10:06 AM
Wanted Canister mufflers for 3W 103 Ib Jensen Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jul 24, 2007 03:59 PM
