Old Sep 17, 2010, 08:22 PM
SNice is offline
Find More Posts by SNice
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
Yup -- exactly what I was thinking.... kind of like an F-18 went to the chop shop! Think I'm gonna try it...man - the full fuse version looks great!!! but i need this to be quick!
SNice is offline Find More Posts by SNice
Old Sep 17, 2010, 08:25 PM
Prime_8 is offline
Find More Posts by Prime_8
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
yeah Mayday27 's boxed version is a fast & fast LOL
Prime_8 is offline Find More Posts by Prime_8
Old Sep 19, 2010, 05:12 AM
aerophilia is offline
Find More Posts by aerophilia
building building building!
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Maiden today, went well. Got a friend to throw it for me and it tracked straight right from the start. All went well until I hit lvc and was too low and being silly. Broke the nose off. Took about 5 minutes to fix, and is ready to go again.
In the air it felt rock solid. Couldn't ask for a nicer flying piece of foam. Thanks for the plans, this one is a keeper. My auw is right on 250 grams, I can see this going very quick with the right power system and some re-inforcing of a few areas
aerophilia is offline Find More Posts by aerophilia
Old Sep 19, 2010, 10:19 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
yeah i coudl see running CF down from wing spar to nose tip .
may stop all the nose jobs we have .
Old Sep 19, 2010, 07:05 PM
Kronikpilot is offline
Find More Posts by Kronikpilot
BOXFUSE KING!
Kronikpilot's Avatar
NO WIND CITY GUAM U.S.A
Joined Jan 2009
AWESOME! CONGRATS ON YOUR MAIDEN If you want a more rigid structure for speed, lengthen the cf spar on your wing and then spot glue balsa triangle stips along the FUSE. I'm building a slightly bigger span for 3s lipo.
Mayday.
Kronikpilot is offline Find More Posts by Kronikpilot
Old Sep 19, 2010, 07:29 PM
blueretro is offline
Find More Posts by blueretro
blueretro's Avatar
Nolanville TX
Joined Mar 2009
Hey mayday, whats the bigger span you're working on?
I'm building(very slowly ) about a 30" version with a kfm1 step on the bottom
aerophilia, thats a nice looking jet and congrats on the maiden
blueretro is offline Find More Posts by blueretro
Old Sep 19, 2010, 11:42 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
nice. can't wait to see it.
Old Sep 20, 2010, 06:06 AM
rcflyer50 is offline
Find More Posts by rcflyer50
USA, Massachusetts
rcflyer50's Avatar
Joined Dec 2005
Ive started my 36" span funjet the other day. I hope it comes out like all yours did.
rcflyer50 is offline Find More Posts by rcflyer50
Old Sep 20, 2010, 09:25 AM
BOXFUSE KING!
Joined Jan 2009
I haven't measure it yet but it was 250% from Prime8's original drawings. You can see the size difference on the pic. Im planning to use Grayson V3 motor on this one its going to be fast!
Old Sep 20, 2010, 09:28 AM
BOXFUSE KING!
Joined Jan 2009
Cool man, I want to see it! It will fly super stable at that wingspan.
Old Sep 20, 2010, 12:35 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
ha! that will be very cool .
and insanely fast too i bet . with a V3 system should haul round teh sky .
are you doing standard hood ? or the optional larger hood ?
- i contemplating the f18 style. for a fall build .
Old Sep 20, 2010, 03:00 PM
Jefte is offline
Find More Posts by Jefte
Fly Low Fly Fast
Jefte's Avatar
United States, FL, Melbourne
Joined Sep 2010
Originally Posted by Prime_8 View Post
cannards are just due to teh toy grade AH brick and motors use dfor this size .
Does this mean you used the air hogs switchblade receiver brick in this mini jet?
I took mine apart to salvage the Rx and motors and have been trying to find a use for them. I assumed the Rx/Tx were programmed for a differential thrust setup only.
Jefte is offline Find More Posts by Jefte
Old Sep 20, 2010, 04:29 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
actual a smaller f18 RX i used teh jet set ..
the original plans i did are for a 10 in WS and jetset guts.
but i have to kee mas to 23g or less .. LOL for good flight .
i will have to convert to use parkzone lipo .. it's smaller and more mah .
but switch blades and be used like this :
my switchblade is in my bronco 2. video of bronco ..
Bronco 2 , night / dusk flight awsome (3 min 4 sec)
it's build logs
http://www.rcgroups.com/forums/showthread.php?t=1276785
mayday took my plans and has been up sizing them ever since with awsoem results .
Old Sep 20, 2010, 04:30 PM
Griffindor is offline
Find More Posts by Griffindor
Crash it first, Then fly it
Griffindor's Avatar
The Big Apple
Joined Jul 2008
when I first saw this just now, I thought, wow this is so simple!!!
cool plane. i love the paint job
Griffindor is offline Find More Posts by Griffindor
Old Sep 21, 2010, 10:37 AM
SNice is offline
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
...finally got mine done -- took me a little longer than I anticipated! Very happy with how it turned out! Great plans and great design! I made a few simple mods:
- Added f18 style strakes
- Extended control surfaces (closer to fuse)
- Modified vert. fins to allow for control surface extension
- installed servos recessed into lower fuse
I approximated the new CG by chucking the bare airframe at a low altitude onto the ground. The new CG is about 1/4" -1" ahead of the original. After getting her in the air, I will determine the proper CG.
My maiden attempt prior to painting was a failure. Don't know what I was thinking -- haven't launched a pusher in a while (EDF's!) -- I was a bit concerned about tearing up my hand with the prop. I tried an underhand launch . Thrust was there, but not speed -- she torque rolled, stalled, and landed on her top, breaking off rudders and motor mount. Minor damage, but I was not able to do a quick field repair at the time.
Got her back together and decided to paint b/c it became too windy to fly. Hopefully I will be able to re-maiden early one morning. This time I will be sure to give her a good overhand toss!
motor:emax 2805 2800KV
batt: 1000mah 3S 20C lipo
ESC: 30A
prop: APC 5.1x4.5
AUW: 8.8oz (250g)
As far as performance goes, this motor should be more than enough. On a fully charged pack, I was getting 150W @ 14A. I held her above the scale and got 12.5oz. of thrust at max throttle. She will hover at 1/2 throttle. Can't wait to get her in the air!!! Thanks again, guys!
Build Log A Mini funjet - type thing ( full fuse ) Prime_8 Scratchbuilt Indoor and Micro Models 168 Nov 18, 2010 01:37 PM
Discussion Prime Cut + 20 KevinSheen Giant Scale Airplanes 1 Jul 27, 2010 07:48 AM
Discussion Yet another Funjet FPV hakuna FPV Talk 0 Jun 02, 2010 10:15 PM
Discussion Another FPV Funjet JohnyGab FPV Talk 21 Jul 30, 2009 10:17 AM
To prime...or not to prime Simon_au Slope 12 Dec 18, 2004 08:04 PM
