Old Sep 10, 2010, 02:45 AM
rudes is offline
Find More Posts by rudes
Australia Sunshine Coast
Joined Sep 2007
No he is thinking about doing the Eurofighter
Prime 8 interesting your comment about gettin free lifting body effect with the boxed fuse. One of my small jets has a foam fuse sandwiched between two sheets of balsa and it has more lift than the identical jet without the balsa.
Mayday my slightly heavier 800mah batteries get 12min plus flight times.
Eurofighters look great
Rudolf
rudes is offline Find More Posts by rudes
Old Sep 10, 2010, 02:55 AM
Prime_8 is offline
Find More Posts by Prime_8
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
if you look at the boxed fuse for this , it is like a segment of wing chord , or crossection of wing foil .
i will have to check it out . some how .
maybe build a laminated contoured fuse & and boxed profile .
ballence en on opposite ends of a spar and spin it , and see what AA teh fuses need to be to keep them spinnig level.
that should let us see if boxed fuse is a bettre lifting body . just watching the easy inverted and still ok flight at lower speeds is what mad me think it could be ?
aw nuts, means i have to make some test rig . LOL
what i presume :
laminated full contour fuse would be faster but not have hardy any body lift .
boxed fuse , slightly slower but giving body lift in return for that drag , or a sresult of it .
hmm . i have to go read , i'm sure some one has looked at this .
Prime_8 is offline Find More Posts by Prime_8
Old Sep 10, 2010, 10:20 AM
TheTrashMan is offline
Find More Posts by TheTrashMan
TheTrashMan's Avatar
Joined Jul 2009
someone needs to make a box fuse eurofighter!!!That would be sweet.
TheTrashMan is offline Find More Posts by TheTrashMan
Old Sep 11, 2010, 03:47 AM
Kronikpilot is offline
Find More Posts by Kronikpilot
BOXFUSE KING!
Kronikpilot's Avatar
NO WIND CITY GUAM U.S.A
Joined Jan 2009
I was thinking about it! I did a box fuse RAFALE, and it flew awesome.
http://www.rcgroups.com/forums/showthread.php?t=1048725
Mayday.
Kronikpilot is offline Find More Posts by Kronikpilot
Old Sep 11, 2010, 04:05 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
cool
Old Sep 11, 2010, 07:55 AM
Joined Jul 2009
Mayday.
See now i will have to build that one too!!!But you should design a eurofighter,you would be my hero!!
Old Sep 12, 2010, 07:00 PM
rcflyer50 is offline
Find More Posts by rcflyer50
USA, Massachusetts
rcflyer50's Avatar
Joined Dec 2005
Planeflyer, check out Parkjets.com, they have Eurofighter plans.
rcflyer50 is offline Find More Posts by rcflyer50
Old Sep 12, 2010, 07:12 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
get me some good tri views and i'll draw up box & lamiante comaptible plans .. LOL
Old Sep 13, 2010, 05:52 AM
USA, Massachusetts
rcflyer50's Avatar
Joined Dec 2005
heres a 3 view
Old Sep 13, 2010, 09:09 AM
Joined Jul 2009
do it do it do it!!!!!
Old Sep 13, 2010, 06:13 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
ok i'll have a go ...
i will have to pop round the web for some good flight shots and other refs.
but that should do . LOL
Old Sep 13, 2010, 06:39 PM
Joined Jul 2009
Hurray!!!!!
Old Sep 13, 2010, 08:01 PM
USA, Massachusetts
rcflyer50's Avatar
Joined Dec 2005
sounds great!
Old Sep 13, 2010, 09:14 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
but i may try using this version .LOL
http://www.google.ca/imgres?imgurl=h...26tbs%3Disch:1
i'll figure it out . LOL som high rez ones there
but here is tomhe's plans for profile .. for now . I;ll make a new thread when i get sompin no mor hijacking this one . LOL
http://www.rcgroups.com/forums/showthread.php?t=976693
Old Sep 14, 2010, 01:51 AM
rudes is offline
Joined Sep 2007
Prime 8 thanks for your interest in the Eurofighter. I can draw and build most jets but when it comes to a Eurofighter wingspan between 16" to 20" it never looks right. I use the same running gear as Mayday 27 and a Eurofighter in the 16" to 20" wingspan should suit the running gear, motor etc.
Would you go rear prop or mid? When I go mid the prop won't fit the wing.
Rudolf
Build Log A Mini funjet - type thing ( full fuse ) Prime_8 Scratchbuilt Indoor and Micro Models 168 Nov 18, 2010 01:37 PM
Discussion Prime Cut + 20 KevinSheen Giant Scale Airplanes 1 Jul 27, 2010 07:48 AM
Discussion Yet another Funjet FPV hakuna FPV Talk 0 Jun 02, 2010 10:15 PM
Discussion Another FPV Funjet JohnyGab FPV Talk 21 Jul 30, 2009 10:17 AM
To prime...or not to prime Simon_au Slope 12 Dec 18, 2004 08:04 PM
