Old Oct 08, 2010, 01:03 AM
Prime_8 is offline
Find More Posts by Prime_8
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
the CG seems to be very important . teh canards will help with slower speed.
you may want to ...
extend the vert stabs under the wing as i did with the forward swept version .
or put wing fences on .
Prime_8 is offline Find More Posts by Prime_8
Old Oct 08, 2010, 10:02 AM
tsudduth is offline
Find More Posts by tsudduth
Rather be flying
tsudduth's Avatar
United States, TX, Midland
Joined Feb 2009
Auw?
Does anybody have an AUW for this bird at the 20" ws? I want to know what weight I should target?
tsudduth is offline Find More Posts by tsudduth
Old Oct 08, 2010, 10:42 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
the micro c ~10 inch can be built to be 8.5g , with strength
if you double it expect mass of air frame to almost tripple, so 25 - 30 g
and tha fits with mine , now , i'm 16 inches using heavier park flier gear and have 51g before power plant , but if i took out guts , she woudl be 31g ( Now that is a the forwards sweep , butthey are very close )
so at 20 inches shoot for 30 to 35g , withough gear in . subtract mass of your gear if it is allready installed.( ~ 20g for non power plant gear is good )
and of course you gear should be light as you have on hand.
in all you will want to keep AUW ~ in teh 100g to 150g , depending on your power plant .
Old Oct 08, 2010, 05:18 PM
boardman is offline
Find More Posts by boardman
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
My 20 incher is 164g (5.8oz) with a 3 cell 500 mah using the same motor as Mayday in the first post and 5g servos. I originally had it at 5 oz with a 2 cell 460 mah, but it needed more nose weight. I could have left it at that weight by moving the servos forward as my 500 mah is not mounted all the way forward.
I hot glued my servos to the bottom of the wing, but next time I might bury them in the fuse and extend the ailerons right to the fuse. The linkage has to be protected when landing in grass which means more bits of depron and therefore more turbulence created. I guess one could use torque rods and hide the linkage completely. A lot more work though.
boardman is offline Find More Posts by boardman
Old Oct 08, 2010, 07:38 PM
Kronikpilot is offline
Find More Posts by Kronikpilot
BOXFUSE KING!
Kronikpilot's Avatar
NO WIND CITY GUAM U.S.A
Joined Jan 2009
Torque rods are awesome idea! I don't mind setting them up, and also saves you a servo on models with elevator. I might do this on my mid-jets series projects.
mayday.
Kronikpilot is offline Find More Posts by Kronikpilot
Old Oct 08, 2010, 09:56 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
i love hidden linkage . .. less you see teh more teh isllusion is kept .
Old Oct 09, 2010, 12:54 AM
boardman is offline
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
Yeah, it makes a cleaner build and cleaner airflow and out of harms way when doing belly landings.
So here's the canards, set at 1.75 degrees ready for testing tomorrow am. We have a long weekend with Monday off but they are calling for rain so fingers crossed.
Old Oct 09, 2010, 12:59 AM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Good luck with the canards maiden "boardman". If you can get a short video, that would be great.
All the best
Andy
Aero Andy is offline Find More Posts by Aero Andy
Old Oct 09, 2010, 12:18 PM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
Beautifull! Clean project!
Luis_Claudio is offline Find More Posts by Luis_Claudio
Old Oct 09, 2010, 03:40 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
1.75 , perfect i do 1.5 you 1.75 and mayday 2.0
i'm sure it just has to be some positive incidence .
now i rounded teh front of mine , coverd teh LE of canards with clear tape .
i did not feather sand the TE of them like i do teh verts .
if you don't round teh le of teh verts , and feather teh TE of verts you get drag that pulls up on nose.
if you featherd your verts you get speed but no upwards pull ..
canards fix that ... or just fly fast . LOL
looks great !
Old Oct 10, 2010, 03:29 AM
boardman is offline
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
Andy - just uploaded some video - waiting for processing and will post shortly
Luis - thank you
Prime 8 - I will do the rounding and feathering next - thanks. The 1.75 was to intentionally be between yours and Maydays suggestion Actually I have no idea what it is. My incedentometer has been misplaced, so I just drew a line off the wing with a ruler, added bead of hot glue, twisted a bit up, and hold to set.
It's much better now at slow flight with the canards.
Old Oct 10, 2010, 03:36 AM
Eastcoast78 is online now
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
cool ..cant wait to see the video!!
Eastcoast78 is online now Find More Posts by Eastcoast78
Old Oct 10, 2010, 03:58 AM
boardman is offline
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
sorry - didn't upload properly on utube so I have put on vimeo but have to wait 1/2 hour for processing so will post in the morning
Old Oct 10, 2010, 07:03 AM
BOXFUSE KING!
Joined Jan 2009
Luis - thank you
congrats Russ! good job. Can't wait to see the video.
Old Oct 10, 2010, 10:53 AM
boardman is offline
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
Here we go. Has the maiden (fail), then flight with and without canards.
mini funjet depron scratchbuild rc groups (2 min 59 sec)
Build Log A Mini funjet - type thing ( full fuse ) Prime_8 Scratchbuilt Indoor and Micro Models 168 Nov 18, 2010 02:37 PM
Discussion Prime Cut + 20 KevinSheen Giant Scale Airplanes 1 Jul 27, 2010 08:48 AM
Discussion Yet another Funjet FPV hakuna FPV Talk 0 Jun 02, 2010 11:15 PM
Discussion Another FPV Funjet JohnyGab FPV Talk 21 Jul 30, 2009 11:17 AM
To prime...or not to prime Simon_au Slope 12 Dec 18, 2004 09:04 PM
