Old Oct 03, 2010, 06:18 PM
Prime_8 is offline
Find More Posts by Prime_8
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
awesome .
can;t wait .. get your foam n' build man ! LOL
( i just need some gear/guts . LOL )
Prime_8 is offline Find More Posts by Prime_8
Old Oct 04, 2010, 12:30 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
more done on FSW version
got more done (pics in my build log )
she's ready fro controlled glide tomprrow . ( i don't have esc lipo or motor suitable rite now )
Old Oct 04, 2010, 07:15 AM
anatoly is online now
Find More Posts by anatoly
RC Addict
anatoly's Avatar
Falls Church, VA
Joined Jul 2006
@Prime 8: Are you going to get enough elevon throw with the control rod almost 45 degrees to the plane of servo movement? I would have thought you would need to angle the servos out a bit.
I must admit I'm a bit curious as to how the FSW version will fly, because I've been thinking about building something like this ever since I saw the SB-28 a few years ago.
anatoly is online now Find More Posts by anatoly
Old Oct 04, 2010, 08:53 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
it glides well , dead still air out .. ( may take p51 up to field in a bit )
i added some to the ailerons , i took some video of the controls working.
I was thinking i should rotate the servos for more thow as the drag will not be much more , like you said.
i will add a new set of holes on horns closer in for more throws but don;t think it's needed.
with power it will be awsome . I was thinking i woudl add a mix E out to AUX ch , and have pure E input drive a 3rd servo to canards if i build a bigger version .
also figure if vert stabs where 45 deg they could be co-linked to elevons .
& acting more like an F22 air break when spoiler on.
but i can tell she need spedd at her current wing loading she needs 10mph i figure below tha you had best have spoilers on or your gonna' spiral in hard .
- so um yeah, if your like me, one may want some mixing for this version . but good pilots proly not a worry. but i'm not that good . LOL i use my mixes.
Old Oct 04, 2010, 09:52 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
here's the video of it working for those interrested..
forward swep wing Mini Fun Jet (2 min 52 sec)
Old Oct 04, 2010, 12:43 PM
boardman is offline
Find More Posts by boardman
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
Mayday - very nice Hawk. I assume thats the 3000 kv blue wonder. What prop did you find works best on it? I have one on order as they were out of stock on the AXN's. My buddy is on his second one, having burnt up the first one. They get hot on 3 cells.
Had a couple more flights on the FJ and it's getting dialed in better each flight. I should have put Velcro on the wingtip pieces as they snap off like wafer cookies when landing in grass.
Prime 8 - looking good. I was wondering about those servo angles too but they seem to be ok in the vid. Just needs an evil paint scheme to complete the look.
boardman is offline Find More Posts by boardman
Old Oct 04, 2010, 01:30 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
LOL canopy is blue now ... LOL
45 deg on control rod = built in rate like responce . LOL sorta .
Old Oct 04, 2010, 05:31 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
forward sweep wing FJ glide tests with power to RX (4 min 30 sec)
now al i need is a motor / power plant .
was thinking a edf(s) would be a cool way as well .
Old Oct 04, 2010, 07:50 PM
matk is offline
Find More Posts by matk
I like EPP
matk's Avatar
Victoria BC Canada
Joined Sep 2005
Originally Posted by boardman View Post
Matk - it's the Duke of Depron (he is the Earl of EPP). And yes I have a kit cut out for you and was going to give it to you yesterday but you were a no show bro.
Thank you Russ. I have too many repairing job to do, did not even have time to for any building at all, too many thing to build and so little time ( just take on another repair for Denis) see you on the weekend.
cheer,
Matk
matk is offline Find More Posts by matk
Old Oct 04, 2010, 10:36 PM
RC Addict
anatoly's Avatar
Falls Church, VA
Joined Jul 2006
@Prime 8, I think the elevon extensions helped, you should have enough throw to maiden it and see how it performs. Where is the CG right now?
Old Oct 04, 2010, 11:43 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
CG is 3mm agead of last marked empty fuse CG .
i have a 10g HK motor and a 6a plush , gws 5x3 prop, and 460mah rhino 2s , comming for my wee one .
opossibly smaller HK servos in i need lower mass.
( i will mod these ones of i have to )
i wish i had the orange box RX , or a AR6400L kicking round .LOL
using my AR6200 without it's lil' buddy RX .. LOL .
Old Oct 05, 2010, 06:57 AM
Kronikpilot is offline
Find More Posts by Kronikpilot
BOXFUSE KING!
Kronikpilot's Avatar
NO WIND CITY GUAM U.S.A
Joined Jan 2009
Great job Scott. Can't wait to see her take the sky. My foam is not here yet, and I do not have enough scrap to build the version 2.
mayday.
Kronikpilot is offline Find More Posts by Kronikpilot
Old Oct 05, 2010, 07:02 AM
BOXFUSE KING!
Joined Jan 2009
Hey Russ I'm glad your FJ is getting better. As far as the wingtips I use RARE EARTH MAGNETS to make them detachable. P.S the hawk is an awesome performer with the 3000kv bw motor and 2s 1050mah lipo spining APC 6x4 prop..
mayday.
Old Oct 05, 2010, 11:07 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
hoping i canmake it move with
http://www.hobbyking.com/hobbyking/s...idProduct=5358
6a plush ESC
& 5x3 gws prop
and 460mah 20C+ rhino 2s.
budget & mass control this .
there was a red motor @ 9g but it was a few $ more and i was trying to hit a specific $ point. LOL
should get ~100+g of thrust .
i'm hoping AUW will be about 100G .LOL or better.
thanks.
:: looks like no problems .
AUW 52g + flight RX micro pack 21g for 73g as a glider!
now i will go check mass of my power system on order.
( 21g rx nimh pack only for testing & setup only )
52g ~
12.3g motor & mount + leads
6g esc
28.5g rhino 460mah lipo
98.8g projected AUW +-~3g
"GWS 5030 / 127 gr / 3.21 A" from HK post below prod.
averag is 110g thrust with a 5x3gws
should have better than 1:1
Old Oct 05, 2010, 03:36 PM
tsudduth is offline
Find More Posts by tsudduth
Rather be flying
tsudduth's Avatar
United States, TX, Midland
Joined Feb 2009
Where's the CG???????
Did a quick flight this morning and it flew pretty good. I have a couple of things to improve. I am a bit nose heavy and not near enough throws. Rolls are not very axial but that may be c of g. May add a canard later if the nose still wants to drop.
Everybody keeps talking about the CG for the FJ but nobody has come out and said where it is. Also do you think that canards with 2 degrees up incidence would be a good idea for slower flight and how would they effect highspeed flight?
tsudduth is offline Find More Posts by tsudduth
Build Log A Mini funjet - type thing ( full fuse ) Prime_8 Scratchbuilt Indoor and Micro Models 168 Nov 18, 2010 02:37 PM
Discussion Prime Cut + 20 KevinSheen Giant Scale Airplanes 1 Jul 27, 2010 08:48 AM
Discussion Yet another Funjet FPV hakuna FPV Talk 0 Jun 02, 2010 11:15 PM
Discussion Another FPV Funjet JohnyGab FPV Talk 21 Jul 30, 2009 11:17 AM
To prime...or not to prime Simon_au Slope 12 Dec 18, 2004 09:04 PM
