Old Oct 01, 2010, 07:03 PM
Griffindor is offline
Find More Posts by Griffindor
Crash it first, Then fly it
Griffindor's Avatar
The Big Apple
Joined Jul 2008
here would be the advanced system loosley slapped together
Griffindor is offline Find More Posts by Griffindor
Old Oct 01, 2010, 08:50 PM
Prime_8 is offline
Find More Posts by Prime_8
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
that would work.
personaly i would go with alowr foot print .
& glass re-enforce a ply wood , or CF mount.
lik so .
here ridder axis and Elevator can act on motor independent of each other.
note teh push rod passes throug a small Alu id tube actine as a axis and a bushing .
the E 's push rod is inline with rudders axis , so rudder & E won't mix.
pulling and pushing will drive teh bell crank attached to outer ring ( rudder).
it pushes/pulls on inner mount plate to give E .
Prime_8 is offline Find More Posts by Prime_8
Old Oct 01, 2010, 09:16 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
While yer building .. Suggest this motor: http://www.hobbyking.com/hobbycity/s...trunner_2050kv
Better built , More power and even cheaper.
Bare is offline Find More Posts by Bare
Old Oct 01, 2010, 09:24 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
Bare , i think that motor ?26g , seems over kill . this plane / my plane only weighs as much as the UM P-51D. ?
Old Oct 01, 2010, 10:35 PM
boardman is offline
Find More Posts by boardman
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
Ready for maiden! 20" W/S, 5oz AUW (with 2 cell 500mah). Hot glue build with acrylic paint and sharpie. Will maiden with 2 cell but will mainly fly with 3 cells.
Will maiden at our club field tomorrow so will probably get some video and will post if all goes well
boardman is offline Find More Posts by boardman
Old Oct 02, 2010, 12:25 AM
Griffindor's Avatar
The Big Apple
Joined Jul 2008
Originally Posted by Prime_8 View Post
that would work.
lik so .
Im not sure if my drawings were very clear. this system is also independent of each other.
Old Oct 02, 2010, 01:36 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
Grif' it's hard to tell but it looked like 2 hinges stacked.
If so , if the 2nd hinge is not in same axis as first , when the first moves , the pushrod for 2nd or it's actuator , will mix a bit as 2nd hinges horn distance from servo changes .
you can have independent input , but axis not inline will cuase unwanted input mix.
can you pop up a render from diff view ? .
sliding plates is one way i never figured out myself. but sliding plates wit pivots can do this too.
Old Oct 02, 2010, 10:34 AM
Kronikpilot is offline
Find More Posts by Kronikpilot
BOXFUSE KING!
Kronikpilot's Avatar
NO WIND CITY GUAM U.S.A
Joined Jan 2009
AWESOME LOOKING FJ BOARDMAN! Dont worry about the maiden she will fly just fine! great job, super clean build!
mayday.
Kronikpilot is offline Find More Posts by Kronikpilot
Old Oct 02, 2010, 11:14 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
personly i'm digging the wing pattern.
had to look at it close i thout it was water slide decal at first . LOL
Old Oct 02, 2010, 12:12 PM
matk is offline
Find More Posts by matk
I like EPP
matk's Avatar
Victoria BC Canada
Joined Sep 2005
Hi Russ,it nice, another neat clean built you are a king of depron in the club.I shall miss the maiden today. but will see you next time.
K
PS: is there one for me ? please.please.
matk is offline Find More Posts by matk
Old Oct 03, 2010, 07:29 AM
inline300 is offline
Find More Posts by inline300
Joined Jan 2009
Can anyone doppler the plane in the first videos, with the 20" version and the listed electronics, maybe of either prop?
Im curious what its capable of.
inline300 is offline Find More Posts by inline300
Old Oct 03, 2010, 09:00 AM
boardman is offline
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
Thanks guys. I didn't have a successful maiden but I figured it out when I got home. A piece of the blenderm hinge tape came away on my right wing and acted like a brake on that side. It just went all over the place on the first toss but landed without damage. I thought it was tail heavy so I put a bigger battery in and it it flew but banked hard left and eventually I lost it and it went in with minor damage. It's fixed and should be no probs now. Will try later today.
Prime 8 - those thrust vectoring plates look cool and is something I have been meaning to try. I saw some vid of a Funjet with one on and it adds a whole new dimension. Someone out of Germany manufactures them for the Funjet for about 50 bucks I think. I think they were carbon fibre. Anyways, it would have to be a bit bigger plane to handle the extra servos.
Mayday - I know it will fly great next time (today)
Matk - it's the Duke of Depron (he is the Earl of EPP). And yes I have a kit cut out for you and was going to give it to you yesterday but you were a no show bro.
Old Oct 03, 2010, 02:54 PM
boardman is offline
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
Did a quick flight this morning and it flew pretty good. I have a couple of things to improve. I am a bit nose heavy and not near enough throws. Rolls are not very axial but that may be c of g. May add a canard later if the nose still wants to drop.
Old Oct 03, 2010, 04:00 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
boardman ,
lol i was looking for fiberglass sheets to "mill" some VT mount parts from .
if you have decent servos you can run split linkage with the control surfaces .
the A.E. mount is easier and stronger but we like our jets with elevons LOL .
as far as bigger if i can get my current forward swept one up and flying well i will make a ~40 inch version , for my big beast of a motor i have now .
i would say CG . Mayday & SNice found better flight with ajusted CG .
Old Oct 03, 2010, 04:15 PM
BOXFUSE KING!
Joined Jan 2009
COOL! you're almost there Russ, If you add fix canards make sure you angle them up at least 2 degrees for that wingspan. My BAE HAWK was a huge success using my famous parkflyer set-up we used on the rafale.
BAE HAWK MAIDEN! (3 min 47 sec)
....I will be building V2 soon and I know we will have another badass jet with this set-up....I'm waiting for the mailman to bring my case of foam
mayday.
Build Log A Mini funjet - type thing ( full fuse ) Prime_8 Scratchbuilt Indoor and Micro Models 168 Nov 18, 2010 01:37 PM
Discussion Prime Cut + 20 KevinSheen Giant Scale Airplanes 1 Jul 27, 2010 07:48 AM
Discussion Yet another Funjet FPV hakuna FPV Talk 0 Jun 02, 2010 10:15 PM
Discussion Another FPV Funjet JohnyGab FPV Talk 21 Jul 30, 2009 10:17 AM
To prime...or not to prime Simon_au Slope 12 Dec 18, 2004 08:04 PM
