Old Sep 07, 2010, 02:22 AM
RJPIoW is offline
Find More Posts by RJPIoW
Parkesflyer
RJPIoW's Avatar
United Kingdom, Ryde
Joined May 2006
Motor fo UH Haoye EDF Ducted Fan Unit 7 Blade 3.5inch
Has anyone found a cheapish motor suitable for this UH supplied EDF
The blurb says a 2000kv 39mm motor.
I want to use 2 in a scale seaplane project but dont want to spend a fortune !
Richard
RJPIoW is offline Find More Posts by RJPIoW
Old Sep 08, 2010, 12:05 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
I have one data point for that fan in my notes, someone posted these numbers for the Turnigy B36-56-06 1800kv motor on 5S 5000, it pulled 69 amps and 1200 watts at the start, then dropping from there as is usually as the voltage stabilizes for a while. The motor was 63 degrees C.
If building a twin I'd be tempted to go with a lower kv motor and higher cell count so that you can run two 5S packs in series so that both fans are fed by one "pack". That way you don't have to worry about one pack running out first and losing a motor on one side and getting assymetrical thrust. Of course if you ever want to run those motors in a different airplane with a single fan you'll still need a high S count to get usefull power out of them but heck they're so cheap, you could probably just buy new motors.
You'll need high voltage speed controls but from hobbykingthey're so cheap it's not that big of a cost increase.
Go to hobbyking.com and look at motors. I think 2000kv is almost too high, I like keeping my amp draw no higher than 75 amps, a 2000kv motor would be right at that I think on 5S, maybe a bit more, but I don't have a lot of data for that fan. The search function might help find more.
You might be better off using the Wemtoec Midifan. More data out there and it probably pulls 10 amps less for the same thrust, it has less pitch.
Ed Waldrep is offline Find More Posts by Ed Waldrep
For Sale 90mm/3.5inch Haoye EDF - new in box Phoenix426 Aircraft - Electric - Jets (FS/W) 4 Aug 13, 2010 07:02 AM
Sold 127mm / 5inch EDF fan unit $50 dirkyboy098 Aircraft - Electric - Jets (FS/W) 4 May 24, 2010 02:12 PM
Help! EDF Ducted Fan Unit 7 Blade 3.5inch NowoN Electric Ducted Fan Jet Talk 19 Aug 25, 2009 04:04 PM
Help! EDF Ducted Fan Unit 7 Blade 3.5inch NowoN Power Systems 2 Jun 13, 2009 07:07 AM
Discussion United Hobbies EDF Ducted Fan Unit 7 Blade 5 inch 127mm bryadelm Electric Ducted Fan Jet Talk 10 Nov 06, 2008 11:47 AM
