Old Sep 10, 2010, 07:29 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Originally Posted by scorpion1 View Post
The whole motor/drivetrain seems undersized/low quality from what i'm reading............ It cant be very fast with a 3656(?) 1500kv motor on 4s, can it?
What this boat needs is a new flex drive and a leopard 4068-4074 in it, powered by a couple of beefy 2s lipos thru a 120a ESC. Just one man's opinion.
I believe they're running in the mid 30's stock, and hitting 40's with some setup and prop work.
If you think of the cost difference, putting a motor and ESC that size in it would put the price well beyond what buyers of RTR boats are willing to pay.
Plus, this was designed for P Spec racing, which is limited to a handful of 36mm motors.
wparsons is offline Find More Posts by wparsons
Old Sep 10, 2010, 07:31 AM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I was suggesting that someone put those items in one themselves............. i bet someone does it in the near future.
scorpion1 is offline Find More Posts by scorpion1
Old Sep 10, 2010, 08:13 AM
thomaslambo is offline
Find More Posts by thomaslambo
thomaslambo's Avatar
So. Cal.
Joined Dec 2009
Thanks for the info guys.
I believe the Motor is a:3630-1500Kv Water-Cooled Brushless....recommended 2x 2s Lipos for juice.
The turning problem can easily be resolved by replacing what appears to be a weak servo from the factory.
The canopy issue is common to most all boats that are driven hard and one should reinforce any canopy with resin and/or fiberglass (SOP in my book).
I intended to install a Spektrum MR Rx and use my DX3s Radio like I do for all my boats.
Speeds in the mid 30's, and up to 40 with setup is fine with me. So the engine would be acceptable….not so sure about the ESC thought (would run it stock and see what happens).
I've got one on hold at the LHS that I'm going to check out today, but at this point I have some reservations about purchasing this boat today. I might just wait for one of the other Violators to buy one so I can check it out on the water up close and personal
Boomer, can you confirm the speed on this puppy?
thomaslambo is offline Find More Posts by thomaslambo
Old Sep 10, 2010, 08:19 AM
So. Cal.
Joined Dec 2009
Originally Posted by Jeff Wohlt View Post
This is a solid set up for motor and ESC...very time proven. The twitching servo is just hit and miss.
I just got my hull and it will be built with 4074-2200kv, 180 ESC and probably a 78 wire drive or a 3/16" cable,4-5S lipos.
Should be around 60mph, I am hoping.
Jeff,
Can you buy the finished bare hull, or finished hull with hardware less motor and ESC?
Old Sep 10, 2010, 09:23 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
From what I've read other places, if you do some minor sanding/blocking on the ride pads it will improve speed and handling a worthwhile amount.
Old Sep 10, 2010, 10:11 AM
STRINGFLY is offline
Find More Posts by STRINGFLY
STRINGFLY's Avatar
Little Rock Regional, Arkansas, United States
Joined Sep 2002
Bare hull
Bare hull and canopy 198.00 from Horizon.
Stringfly <>+++++
STRINGFLY is offline Find More Posts by STRINGFLY
Old Sep 10, 2010, 10:29 AM
STRINGFLY's Avatar
Joined Sep 2002
gear
The motor and esc is the same as in my Fastech Forumula and it runs great. The biggest difference with this RTR is the 2.4 ghz marine radio which I like better than the 27mhz in mine. I have had glitches twice on mine.
Stringfly <>+++++
Old Sep 10, 2010, 11:20 AM
tman52804 is offline
Find More Posts by tman52804
tman52804's Avatar
United States, IA, Eldridge
Joined Aug 2003
I have a new miss geico and I am waiting for a new flexshaft.
It appears that the Esc shouldn't need any programming for lipo? Just want to make sure I don't need a special programmer as well.
tman52804 is offline Find More Posts by tman52804
Old Sep 10, 2010, 11:37 AM
Boomer1 is offline
Find More Posts by Boomer1
Boomer1
Boomer1's Avatar
United States, CA, Temecula
Joined Sep 2009
It must be programed for lipos!
tman,
The boat's ESC has to be programed with the Proboat programing module #PRB3311
Won't work other wise. Check out this video. It shows you how to do it. http://www.horizonhobby.com/Articles...ArticleID=1801
If order one before 9-15 you can get 10% off by using this discount code Promo Code: STF106F4AE
Saves you a couple of bucks!
Boomer
Boomer1 is offline Find More Posts by Boomer1
Old Sep 10, 2010, 11:41 AM
tman52804's Avatar
Joined Aug 2003
That is retarded. I can't run it now?
Old Sep 10, 2010, 11:47 AM
So. Cal.
Joined Dec 2009
I'm wondering the same thing?
However, I was planning on buying a program card anyway as this would be my second Proboat with a programable ESC.
One wrong move and you can kiss your electronics good bye....it's all in the beep beep beep
Boomer1 is offline
Boomer1
Boomer1's Avatar
Joined Sep 2009
Tman
Life isn't fair. The card ships in a day or so, and comes in the mail. Takes a day or two. The flex shaft is most likely defective anyway, so you'll have to wait for a new one.
That is the way it is with lipos.
Boomer
Old Sep 10, 2010, 11:55 AM
So. Cal.
Joined Dec 2009
Originally Posted by Boomer1 View Post
Tman
Life isn't fair.
Amen
Old Sep 10, 2010, 12:22 PM
JimClark is offline
Find More Posts by JimClark
JimClark's Avatar
United States, WA, Seattle
Joined Apr 2002
You could reverse the motor and use a Righthand prop on it
JimClark is offline Find More Posts by JimClark
Old Sep 10, 2010, 12:43 PM
Boomer1 is offline
Boomer1
Boomer1's Avatar
Joined Sep 2009
Jim
He still has to program the ESC.
Boomer
Discussion Bluefish Maiden Voyage linerfanatic Scale Boats 4 Nov 14, 2010 05:34 PM
Video Calypso's maiden voyage 15 september 2009 dan.lord Dock Talk 4 Sep 20, 2009 08:24 AM
Help! F4 Maiden Voyage Motor Blew up f355 Banana Hobby 16 Sep 17, 2009 01:35 AM
Video YAPT Yet Another PT 109 Maiden Voyage daemuon Dock Talk 5 Sep 16, 2009 03:34 PM
Discussion Disney Nautilus has her Maiden Voyage! Nemo Submarines 16 Sep 11, 2009 11:45 AM
