australia
Joined Jul 2010
hi losi thanks for clearing that up it was a huge help and it was easy to understand and yer as long as it has some control i was worried that it only had like 10 percent then like 90 percent or 100 and it makes sence about being a rtr esc and being basic thats why the boat is great value but yer ill run it and go from there.
Like i said i just wanted to know it can be contollable incase i really need to make a slow turn and not burn up the esc but i should be able to get back up to speed soon enough. But yer as you said run it and go from there i prob will go the 180 as its like 30 bucks more than the 120 and handles 60 more amps plus it has 2 inlets and 2 outlets and looks cool. As i was going to run it like the motley crew and have the motor outlet run back through the esc then out through the rear and run esc coolers from kintec racing between the esc and motor inlet and outlet for added cooling. Once again thanks for helping me understand in a way it was easy for me to understand with this hobby you defianately learn more each day but its an awesome hobby and its way cool im glad i got into it even though it can be complicated lol buti have always been into power boats as long as i can remember. |
Shaft grease.
Aquacraft makes Grim Racer speed grease, and Pro Boat makes Marine Grease both available at RC hobby shops or on line at Tower Hobbies or Horizon. I like AMSOIL synthetic water resistant lithium complex grease #GWRCR, available from AMSOIL online. Don't use a outboard motor lower end grease, wont take the rpms.
Stringfly <>+++++ |
australia
Joined Jul 2010
wparsons and stringfly thank you both for the tips i will definatley check but i may end up just stickin with the 120 amp as it should be plenty and fit easier.
And since im doin the outboard the exit for the water will come out of the outboard anyways and plus the 120 is much lighter and it will only be set up for 4s2p as it will be a spec boat. And when i go up 2 a 6s set up it will be a twin build with a bare hull from fighter cat racing using the 37 inch hull twin cyclon watercooled outrunners and twin 180 amp escs but thats at least a year or two down the track. I have thought about getting them in advance as their rare and trying one in the geico at some stage. |
United States, CA, San Marcos
Joined Feb 2007
The 180 fits just fine. I ran it mine for a while before I ripped all the wood out. I say for the money, go with the 180. You will not need another upgrade unless it smokes, which is unlikely unless you thow in a super high kv motor and a large prop.
I use the Pro Boat grease with the grease gun attachment. Makes greasing so much easier! |
australia
Joined Jul 2010
cool sounds like a plan and the most i will go is a 2200 kv motor or very close and an x642 prop as it seems like what everybody is using with good results.
And yer it would save money in the long run as it wouldnt need another esc and would give me peace of mind plus lookin cool. And yer that grease gun looks like a good thing to pick up. |
Joined Feb 2007
Just thought I would share this video to get you more excited about this boat. This is from yesterday. I put my Castle 1800kv outruner back in(very small motor), 2 5000mah 20c 2S packs, and an Octura X445 prop. Very much lighter than my high rpm setup. Still, no bounce at all at WOT. Don't know why but she always bounces 3 times as it gets out of the corners but that doesn't bother me.Temps are very low so I think I will run an even bigger X447 prop next time.
So i was wondering if i should get a sharpened and balanced X642 for 40 bucks from http://www.offshoreelectrics.com/pro...rod=octsb-x642
or one from this website for 13 bucks but it doesn't say its sharpened and balanced? http://www.kintecracing.com/Props.html or any other websites that have the X642 that i should buy from? |
australia
Joined Jul 2010
hi losi cheers man first of all u made your boat go awesome it really goes hard as if reading all the threads wasnt making me want the boat more you had to throw in a wicked vid to make me more exited and want it even more lol im so exited about getting it its annoying that i cant till i get more work coming in.
Plus i gotta pay over a hundred bucks to get it from ya country to get it here to aus but its defiantely worth it as the local RTR F/E offerings are nothin worth mentioning. There is a thunder tiger mono and tunnel that i have seen in a LHS but they are around 650 - 700 bucks which i think is too much as twice the retail price of the geico. Because the problem here in aus the F/E boating community is no where as popular as it is in the states and it shows in what the hobby stores are selling which are mostly toys or nitro boats which is fine for the people who want them. But for new boaters looking into the sport are left to buy nitros or get a F/E built or import thats the best option so far. Thats why im doin the gieco to show the local people that you can have a competative boat to get you started and still have plenty of change from 500 bucks it does help pointing people to forums like this. But not having the numbers the local clubs not having the numbers or interest they have their hands tied when it comes to F/E they only have the standard rules of EA,EB,EC and offshore classes only cater for huge boats with fuel engines. So even though ill be racing against 4s boats with big dollar escs and motors or limited tunnels though i think there much harder to drive and setup for a newb which are built from bare hulls anyways because if thats all they see is big dollar boats and fuel boats then thats what they think they have to get i know coz i thought exactly the same thing and wanting to fit in but now thanks to the great F/E communtiy on these forums i now know there are much cheaper and more newb friendly options so hopefully i can spread the RTR race F/E movment over here lol. I hopefully will be able to encourage others that you can have a great comp boat for well under 1000 bucks which includes a few packs and charger and a prop or 2. All i can say is go geico !!!!! lol |
Joined Feb 2007
Thanks Scorp! I do realize that but when it's only me out there I like to run counter clockwise because that way I'm running away from the dock as I accelerate out from around the buoy just off shore. I've had a few scares coming around the bouye that's about 20' away from the end of the dock at full speed coming around the other way. From where I was standing you lose sight of the boat for a second as the boat comes at you full speed and we all know it fakes less than that to end badly.
| Thread Tools | |
| Discussion Bluefish Maiden Voyage | linerfanatic | Scale Boats | 4 | Nov 14, 2010 05:34 PM |
| Video Calypso's maiden voyage 15 september 2009 | dan.lord | Dock Talk | 4 | Sep 20, 2009 08:24 AM |
| Help! F4 Maiden Voyage Motor Blew up | f355 | Banana Hobby | 16 | Sep 17, 2009 01:35 AM |
| Video YAPT Yet Another PT 109 Maiden Voyage | daemuon | Dock Talk | 5 | Sep 16, 2009 03:34 PM |
| Discussion Disney Nautilus has her Maiden Voyage! | Nemo | Submarines | 16 | Sep 11, 2009 11:45 AM |
