Old Sep 06, 2010, 06:58 PM
spllouder is offline
Find More Posts by spllouder
spllouder's Avatar
SW Missouri
Joined Aug 2006
Bought RCE-BL35x & Thypoon 2215 Somethings not working .
well i hooked up the esc to the RX the rx powers up but when i hooked up the motor . and plug in the battery i hear no beeps at all and motor will not spin no matter what stick input .
dx6i being used ?
How do i test each compent to detremine which is faultly ?
spllouder is offline Find More Posts by spllouder
Old Sep 06, 2010, 07:26 PM
bad400 is offline
Find More Posts by bad400
crashs come easy patience dont
bad400's Avatar
USA, MI, Shelby Township
Joined Jan 2009
with the 35x plugged into the thro channel not batt port of the receiver, turn on the radio and move the throttle to full, then plug in the heli.
follow the instructions on setting up the esc.
bad400 is offline Find More Posts by bad400
Old Sep 06, 2010, 09:37 PM
spllouder's Avatar
SW Missouri
Joined Aug 2006
it is connected to thorttle port not battery . i did not get instructions . bought on flea bay and lookes like a pulled part off a heli ( bulllets solders on and thats it and was desribe as used pulled from new heli even now it said NEW in Box
What do i do ? i tested voltage and get 6 volts when connect blue and red plug but if i plug red and black i get 0 volts on the motor leads idk help
Old Sep 06, 2010, 09:55 PM
9sec240 is offline
Find More Posts by 9sec240
Advanced Heli Collector
9sec240's Avatar
USA, IL, Carol Stream
Joined Jan 2009
What radio system?
Is the motor installed in a heli? If it is not installed, the beeps will be very quiet. It uses the body of the helicopter to resonate the beeps.
9sec240 is offline Find More Posts by 9sec240
Old Sep 06, 2010, 09:57 PM
bad400 is offline
bad400's Avatar
Joined Jan 2009
man im not sure really.
do you have any other esc to test the motor with? or any other motor to test the esc?
with the esc hooked up to the receiver do you get servo movement?
ive tested motors by hooking them straight to a battery, with quick touchs of the wires i could atleast tell if the motor worked.
now im cant remember if i had two wires in one post and one in the other, its been so long.
now i have spare`s to test problems with.
Old Sep 07, 2010, 12:41 AM
spllouder's Avatar
SW Missouri
Joined Aug 2006
Originally Posted by 9sec240 View Post
What radio system?
DX6I with AR6200
Old Sep 07, 2010, 12:42 AM
spllouder's Avatar
SW Missouri
Joined Aug 2006
ii alrerady ardered a exceed volcano 30 amp esc from hobby parts and a hobby wing program card since it will work right ? thw volcano is a clone of hobby wing right ? ...
BUT NO i do not have any other motors or secs to try .yet
I do have a muti voltage reader probe ...
Old Sep 07, 2010, 12:53 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Did you try lowering the throttles Travel Adjust?
Roto Rob is offline Find More Posts by Roto Rob
Old Sep 08, 2010, 02:49 PM
spllouder's Avatar
SW Missouri
Joined Aug 2006
Update ... a 30 amp esc came in for another project and i tried that esc and all works well now . time to send back the fautly esc . dam fleabay
Question RCE-BL35G vs RCE-BL35X? LaurenceGough Mini Helis 4 Jan 04, 2010 06:47 PM
Discussion RCE-BL35G vs RCE-BL35X ESC? LaurenceGough Electric Heli Talk 3 Jan 04, 2010 02:12 PM
Sold Align RCE-BL35X esc---SOLD!! flyeraroo Aircraft - Electric - Helis (FS/W) 0 Oct 04, 2009 12:57 PM
Sold Align RCE-BL35X ESC signal7 Aircraft - Electric - Helis (FS/W) 0 Sep 27, 2009 10:50 AM
Help! just bought a king 2 its not working mattgto91 Micro Helis 13 Sep 10, 2008 04:36 PM
