Old Feb 06, 2011, 10:20 PM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
Originally Posted by DRAMJET View Post
I'm running 1000mA 3s batts. Rarely do I go to full power and mostly run at 50 - 60% so the motor and esc are running cool. I find it too fast flat out but it will continue vertical until too small for orientation.
I have the elevator rods in the middle hole and expo'd down, as it is powerful in pitch.
Just make sure the Cog is correct as this bird is quite tail heavy.
Thanks for the answer!
Like an impatient kid, I pulled the trigger on a couple of 1800mAh 2s so I'll be runnin this 2s for a while.
1 more question, for 2s setup which GWS prop would you recommend?
queadlunnrau is offline Find More Posts by queadlunnrau
Old Feb 07, 2011, 08:21 PM
acuamie is offline
Find More Posts by acuamie
acuamie's Avatar
Malaysia, Federal Territory of Putrajaya, Putrajaya
Joined Apr 2009
i had flown my fms mini p51 with 1500mah 3s and doing fine. using TowerPro 18A esc. full throttle a few second and the esc seem ok.
acuamie is offline Find More Posts by acuamie
Old Feb 08, 2011, 09:06 AM
Omhra is offline
Find More Posts by Omhra
Solve et cuagula
Omhra's Avatar
United States, CA, San Jose
Joined Oct 2009
2410-12D motor wit a 30A ESC and 1500Mah 3S 30C.... it screams.
Moved the LG wheels back to just in front the CG to keep it from bouncing on landing.
It is just a thing of beauty... Like her big sister is...
Omhra is offline Find More Posts by Omhra
Old Feb 10, 2011, 01:10 AM
DRAMJET is offline
Find More Posts by DRAMJET
2 metre rule applies!
DRAMJET's Avatar
BOOGI, Australia
Joined Dec 2008
Quead,
I'm sure the 1800's will be ok as long as they fit the batt area they should be good for forward weight which is what we all are discovering is needed.
My 3s is pulling a 7060 very nicely. I have had an 8043 on it briefly and it seemed to run nice also. The only prop I had problems with was a stiffer 8060 which I thought would be good but performance was reduced markedly!
I would think that an 8043 or even 8060 would do well on 2s. Mine were GWS slowflyer props. The 7060 howls with cavitation before release but is super quiet at power in flight.
It continually turns heads with its form and turn of speed!
DRAMJET is offline Find More Posts by DRAMJET
Old Feb 10, 2011, 08:10 AM
gatorlynch is offline
Find More Posts by gatorlynch
gatorlynch's Avatar
United States, FL, Sarasota
Joined Mar 2010
What prop (manuf. & size) are you using, please?
gatorlynch is offline Find More Posts by gatorlynch
Old Mar 27, 2011, 03:07 PM
gatorlynch's Avatar
Joined Mar 2010
OK to belly land ?
Omhra - what prop are you using, please?
also -
I'm wanting to convert my Corsair to a belly lander, but I'm afraid the aileron servos will get damaged. With the gull wing, it seems to me the servo horns will hit before the fuselage and stip the gears.
Anybody have any experience with this?
Thanks for any input.
Old Mar 27, 2011, 06:19 PM
DRAMJET is offline
DRAMJET's Avatar
BOOGI, Australia
Joined Dec 2008
Gator, I ditched the wheels a few weeks into ownership as landing on grass soccer field resulted in mostly tail over manouvres and a cracked fin. So for 2 months I have been belly landing with no damage to the servos. Although I was aware that there could be problems I have had none so far. As you know it takes a long glide to bleed off energy for touchdown and aim for as slow as possible touchdown speed. I haven't programmed flaps so it is landing clean.
Also it does look better flying clean and at 3/4 throttle leaps out of my hand from an underhanded lob at about 50-60 degree angle.
Old Mar 28, 2011, 11:55 AM
acuamie is offline
acuamie's Avatar
Joined Apr 2009
anyone know how to repair the rear wheel (mini corsair) or any mod of that area. my iron binding to the wheel has been broken. tq
Old Mar 28, 2011, 12:16 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
also -
I've not flown mine yet but I plan to belly land as well.
I added wing skids to mine right by the servo to protect the horns.
http://www.hobbyking.com/hobbyking/s...idProduct=8702
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Mar 29, 2011, 08:47 PM
gatorlynch's Avatar
Joined Mar 2010
Dramjet - thanks for the input. I'm going to start belly landing mine. It will be a lot easier, as I never got to where I could consistently land well on the gear. Plus, removing the tail wheel will help reduce the nose weight needed to balance.
Schooner2000 - I like your idea of skids to protect the servos. I'm going to go the el cheapo route and just stick a tapered piece of credit card plastic into the wing with some CA. My Corsair is so beat up now, I'm past the point of caring what she looks like ...
Old Mar 29, 2011, 09:03 PM
gatorlynch's Avatar
Joined Mar 2010
Try this post from another thread. Hope this helps.
http://www.rcgroups.com/forums/showp...&postcount=862
Old Mar 30, 2011, 12:11 AM
acuamie is offline
acuamie's Avatar
Joined Apr 2009
gatorlynch : good job bro. i'll use this for my p51. but for fms mini corsair i cant find any screw to unlock. before i open everything need to know how they assemble the rear wheel.
Old Mar 30, 2011, 04:06 AM
DRAMJET is offline
DRAMJET's Avatar
BOOGI, Australia
Joined Dec 2008
Acuamie,
no screws involved with this one. Mine started to pull out from belly landing in the grass so I removed for when I need to have wheels again. Pics show it is just pressed in and glued so removal will just be like extracting a tooth (minus the cost!)
The wire is actually bent into the slot at the base of the plastic clip so you could bend your own replacement if that is what has been broken. Looks like it is bent into a U shape and pressed into the slot. Hope this helps.
Schooner, I like your idea ditto with Gators. The way the wing is shaped means that the landing is taken on the gear clip area and not primarily on the servo and rods so these only take the passing grass leaves and runners if you get a wings level landing. Mine probably gets a hiding with some wing down on touchdown but as I said no damage to either yet. Maybe an extension in the gear area like a pair of bombs or drop tanks would lift the servos up and out of the fast grass but I dont know if the Corsair actually carried any so may spoil the almost scale looks.
Old Mar 30, 2011, 11:47 PM
acuamie is offline
acuamie's Avatar
Joined Apr 2009
this is my problem.
any suggestion on how to repair those rear wheel. (fms mini/800 corsair)
Old Mar 31, 2011, 12:42 AM
DRAMJET is offline
DRAMJET's Avatar
BOOGI, Australia
Joined Dec 2008
Acuamie, pics of where my tail wheel came out from the fuselage. The tail wheel assembly is the same as that on the P51 and instead of clipping to the outside of the rudder it pushes into the two slots so use some glue so mine was not able to turn. Hope this helps
New Product FMS F4U Corsair 1400mm EPO Warbird jbc Electric Warbirds 9199 Today 01:02 PM
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 89 Oct 03, 2015 04:58 PM
Sold NitroPlanes Airfield RC/FMS 800mm Corsair Reciever Ready $80.00 Shipped Mikey 68 Aircraft - Electric - Airplanes (FS/W) 6 Aug 14, 2010 03:18 PM
Sold NitroPlanes Airfield RC/FMS 800mm Corsair Reciever Ready $100.00 Shipped Mikey 68 Aircraft - Electric - Airplanes (FS/W) 1 Aug 09, 2010 11:40 AM
Discussion New ParkZone F4U Corsair for FMS/CV ggunners Simulators 5 Oct 16, 2008 10:42 AM
