Old Dec 14, 2012, 04:54 PM
fathergoat is offline
Find More Posts by fathergoat
How do I land this thing?
fathergoat's Avatar
United States, IN, Warsaw
Joined Feb 2012
A 5sec pre-flight check can save hours on repairs. I've learned that the hard way.
fathergoat is offline Find More Posts by fathergoat
Old Dec 15, 2012, 12:24 AM
Banjofrog is offline
Find More Posts by Banjofrog
Geez That's A Big Fly
Banjofrog's Avatar
Australia, WA, Parkerville
Joined Sep 2011
I am currently taking to rest of the flaky paint off so I can repaint it, I may do a black and white Reno racer esque, I will post some photo's when finished if you guy's would like.
Shaun.
Banjofrog is offline Find More Posts by Banjofrog
Old Dec 15, 2012, 04:41 AM
Banjofrog's Avatar
Joined Sep 2011
Here it is it looks way better now rather than flaking paint, with the paint removed the foam has a waxy coating to it but the paint (lacquer) I used did have a reaction with the foam and has given the crocodile skin effect, but I am not going to notice in the sky.
Name: FMS 800mm Corsair1.jpg
Description: Name: FMS 800mm Corsair2.jpg
Description: Name: FMS 800mm Corsair3.jpg
Description:
Shaun.
Old Dec 15, 2012, 05:09 AM
DRAMJET is offline
Find More Posts by DRAMJET
2 metre rule applies!
DRAMJET's Avatar
BOOGI, Australia
Joined Dec 2008
Quick work, looking good Shaun!
DRAMJET is offline Find More Posts by DRAMJET
Old Dec 15, 2012, 07:14 AM
comanch is offline
Find More Posts by comanch
United States, FL, Satellite Beach
Joined Jul 2012
Looks great Shaun! Especially like the stripe down the side of the fuse. Do you use stencils vs tape for the stripes?
comanch is offline Find More Posts by comanch
Old Dec 15, 2012, 07:49 AM
Banjofrog's Avatar
Joined Sep 2011
Thanks Guy's for your comments, it is ashame about the croc skin, I used cloth tape for all the strips, it does stick well and adds some protection. I really do like this little plane, it flies brilliantly.
Shaun.
Old Dec 15, 2012, 12:55 PM
Apphoard is offline
Find More Posts by Apphoard
Apphoard's Avatar
United States, MD, Silver Spring
Joined Mar 2011
Guys I think I asked this before but I am still not 100% positive I understand. Ok a right hand rotation prop is a anti-clockwise prop correct? They are for quads or multiple motor planes right? They could be used on a single motor plane right but the motor would have to turn anti-clockwise right? Also clockwise is the right way to have your single motor plane setup to spin right?
Thanks for your help guys !
Apphoard is offline Find More Posts by Apphoard
Old Dec 16, 2012, 03:18 PM
sjharris68 is offline
Find More Posts by sjharris68
New Zealand, Canterbury, Christchurch
Joined Mar 2012
Wow Shaun, that looks fantastic!
I just got back from first flight, needs some adjustment on the ailerons and elevator, but fine otherwise.
Only complaint is the prop adapter seems to me not centred and it is hellishly rattly.
Got some work to do there.
What is the prop you are using, an APC by the grey look?
Using 1000mAh 45C NanoTech 3 cells and 35gms in the nose. Heart racing, sweaty palms, wow what a heap of fun!
I look forward to getting this one up in the air a lot.
Lots of fun with the TigerMoth to prepare and then wind down on afterwards.
Its so fast, makes the Hell cat seem slow!
Stephen.
sjharris68 is offline Find More Posts by sjharris68
Old Dec 17, 2012, 03:48 AM
Banjofrog's Avatar
Joined Sep 2011
Stephen.
Hey Stephen, thanks for the comments I have also added #22 to under the canopy and some other decals just behind the engine cowl.
The prop is a apc 8x6 slow fly and I am still running it on 2s and it runs rings around the Durafly F4U and it turns inside it A mate and I had to see which is faster yesterday, he thought his DF was but I am glad to say he was WRONG hehe
Shaun.
** If you look at mine and then yours you can see the difference in the control surfaces hmmmm **
Old Dec 19, 2012, 03:57 PM
Joined Mar 2012
Hi Shaun, yes that is interesting how the control surfaces are different.
The ailerons are on the lowest throw on the servo and still damn responsive.
It is a little slow to barrel roll so I might move them out a slot and see.
Trying to balance 3 blade prop while waiting for 2 bladers to turn up.
I ran a 8*6 on the plane last night and just after a few seconds I could smell very hot speed controller!
3 cell 1000 with 20 amp ESC, so must off been drawing at least 20A!
Didnt shutdown so cant of been at the limit right? Ha!
That is assuming that the FETs do actually shutdown when overheated!
Might just have to keep at 3/4 power, but that is still way fast enough with this little beasty!
Old Dec 21, 2012, 11:07 PM
comanch is offline
Joined Jul 2012
Replaced the stock 20a with a 30a esc, 3s 30 or 40c and 1000mah with a shortened 800mm spitfire prop. Stays cool, runs good.
Old Dec 22, 2012, 03:34 AM
Joined Mar 2012
Hi all , I flew the orig and then the 8*6 this morning.
I am amazed just how much better it is with the bigger prop.
Never had to go over 3/4 power and even just a trickle was enough.
I like it more and more!
What have you cut yours down to Comanch? 7"?
That would make it rotate at higher rpm, works ok?
Cheers all.
Stephen
Old Dec 22, 2012, 09:02 AM
karltrek is offline
Find More Posts by karltrek
Santa Cruz, CA
karltrek's Avatar
United States, CA, Santa Cruz
Joined Sep 2011
Mini V2 Corsair is coming!!
This is from the FMS Facebook page! I especially like the reference to a new 1400mm version is coming soon!
https://www.facebook.com/media/set/?...6557695&type=1
Material: Durable EPO
- Wing Span: 800mm ( 31.5in )
- Length: 660mm ( 26.0in )
- Flying Weight: Around 450g
- Servo: 9g Servo x 4,
- Landing Gear : Steerable Rear Landing Gear
- Motor: KV1700 Powerful Out runner Brushless Motor
- ESC: 20A Brushless ESC
- Propeller: 7.5*4 4 Blade Propeller With Spinner
- Battery: Li-Po 7.4V 1,000mAh 15C
- Radio: 4Ch Radio Control
CG Position: 50mm (From Leading Edge)
New Feature:
1. Scale 4 blades propeller
2. Scale Landing gear
3. Fuel tank and missiles
4. New color box design looks much nicer!
5. New strong box to protect the plane
6. New pilot which is the same as the 1400mm’s. (Coming soon)
7. New FMS own Servo with high quality performance
8. New FMS own Motor with KV1700 and better quality, the issue that losing the motor when flying will never happen again!
9. New FMS own mini Radio with better performance.
10. Better manual with lots of details for easy assembling.
11. Better Performance, no CG issue, easy to control.
Our new V2 mini wabirds have many NEW scale features including a beautify 4 blade propeller and scale hub, scale Fuel tank and missiles, scale removable landing gear, new details decal, new pilot. The aircraft features a brushless motor, 20Amp ESC and 4 ready installed servos. Assembly takes minutes following the simple photo step by step assembly guide. The EPO construction gives a light yet resilient airframe that will take much punishment and just bounce right back into the air! Compact, adrenaline fuelled, big packet of fun still doesn’t do verbal justice to this airframe, we love it! With all this modifications, it looks as a 1400mm wabirds, flies as a trainer plane! Dog fights really become genuine fun with this range of aircraft so what are you waiting for!!
karltrek is offline Find More Posts by karltrek
Old Dec 22, 2012, 12:17 PM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
The v2 is already out at nitroplanes.com I like the gray one and the 4 blade scale prop. Though they have it with a 1300kv motor.
F4U
queadlunnrau is offline Find More Posts by queadlunnrau
Old Dec 22, 2012, 12:32 PM
karltrek is offline
Santa Cruz, CA
karltrek's Avatar
Joined Sep 2011
F4U
That model is not made by FMS! It's made by A-RC. Which is a new vendor that Nitroplanes has contracted with to make their Airfield product line. The models look very similar. The specs are very different. The FMS plane uses a hotter motor at 1700kv. And runs a 2s vs a 1300kv 3s setup for the A-RC.
New Product FMS F4U Corsair 1400mm EPO Warbird jbc Electric Warbirds 9129 Yesterday 01:49 PM
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 89 Oct 03, 2015 04:58 PM
Sold NitroPlanes Airfield RC/FMS 800mm Corsair Reciever Ready $80.00 Shipped FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 6 Aug 14, 2010 03:18 PM
Sold NitroPlanes Airfield RC/FMS 800mm Corsair Reciever Ready $100.00 Shipped FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 1 Aug 09, 2010 11:40 AM
Discussion New ParkZone F4U Corsair for FMS/CV ggunners Simulators 5 Oct 16, 2008 10:42 AM
