Old Nov 24, 2012, 07:23 PM
Apphoard is online now
Find More Posts by Apphoard
Apphoard's Avatar
United States, MD, Silver Spring
Joined Mar 2011
Weird my push rod is connected to the bottom hole furthest away from the elevator wing. Where is yours connected? Which one would give me the most movement the bottom?
Apphoard is online now Find More Posts by Apphoard
Old Nov 24, 2012, 08:19 PM
TheCure is offline
Find More Posts by TheCure
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Thats the position that will give you the least travel.
Closer to the wing increases throw.
TheCure is offline Find More Posts by TheCure
Old Nov 24, 2012, 11:06 PM
comanch is offline
Find More Posts by comanch
United States, FL, Satellite Beach
Joined Jul 2012
Could it be too nose heavy. Haven't seen an 800mm FMS bird that didn't fly well with pushrods on outer horn positions. Things just happen a little quicker as the pushrods get positioned closer to the control surfaces, as deflection becomes greater.
comanch is offline Find More Posts by comanch
Old Nov 25, 2012, 12:37 PM
Apphoard's Avatar
Joined Mar 2011
I will move them to the center holes. I did ad about 28 grams to the nose. Which made my CG 45mm.
Old Nov 25, 2012, 06:42 PM
comanch is offline
Joined Jul 2012
The one I have handles well at 55 - 60mm, measured from just outside the leading edge inlet. If you look back from the leading edge to the two panel lines that are about 7mm apart ( coming off the fuse and running outboard), that is the spot. All my pushrods are set to middle holes and its a fun bird.
Old Nov 26, 2012, 01:34 PM
Apphoard's Avatar
Joined Mar 2011
I am guessing I didn't need the weight up front then to get the 45mm. I am new to the planes. I went back out and broke my last three bladed prop before it got off the ground . I need to find a more durable cheap alternative for this stock setup. Well I have a 1300 2s pack. Do you all know of a good prop for my setup? I see people saying 8x6, 7x5 I would think those would be way to big for this plane.
In the meantime I ordered the HK Radjet 800. It's probably a little to fast for me. But I think I will be ok with enough airspace I hope. So I am going to try and find a better spot to fly.
Old Nov 26, 2012, 04:42 PM
Banjofrog is offline
Find More Posts by Banjofrog
Geez That's A Big Fly
Banjofrog's Avatar
Australia, WA, Parkerville
Joined Sep 2011
7x5 two blade prop is too small, the standard is 7x6x3, HobbyKing does sell them but a MAS will be stronger.
Shaun.
Banjofrog is offline Find More Posts by Banjofrog
Old Nov 26, 2012, 05:46 PM
fathergoat is offline
Find More Posts by fathergoat
How do I land this thing?
fathergoat's Avatar
United States, IN, Warsaw
Joined Feb 2012
GWS 8x6 2-blade works great. In fact that's what I fly with 1300mah 2s packs.
fathergoat is offline Find More Posts by fathergoat
Old Nov 26, 2012, 05:48 PM
DRAMJET is offline
Find More Posts by DRAMJET
2 metre rule applies!
DRAMJET's Avatar
BOOGI, Australia
Joined Dec 2008
2 blade 7060 on stock esc and 3 cell, has worked so well on my F4u and now on the A1.
DRAMJET is offline Find More Posts by DRAMJET
Old Nov 26, 2012, 10:22 PM
comanch is offline
Joined Jul 2012
I'm running a ground down 800mm Spitfire prop on mine with 3s. On the stock setup a 2 blade from the Mustang or Spit would work as well. Much stronger than the 3 blade.
Old Nov 27, 2012, 08:02 AM
Apphoard's Avatar
Joined Mar 2011
So would this prop here work? Is the adapters and a nut all I need to mount it? Thanks for your help guys
http://item.mobileweb.ebay.com/viewi...id=93670359695
Old Nov 27, 2012, 10:55 AM
fathergoat's Avatar
Joined Feb 2012
That should work. you'll want some washers too
Old Nov 27, 2012, 02:23 PM
DRAMJET is offline
DRAMJET's Avatar
BOOGI, Australia
Joined Dec 2008
App, these look like same but somewhat cheaper, maybe some reselling going on...
http://www.rctimer.com/index.php?gOo...7&productname=
Or 8040s
http://www.rctimer.com/index.php?gOo...9&productname=
Old Nov 27, 2012, 04:40 PM
Banjofrog's Avatar
Joined Sep 2011
That prop looks exactly like the TGS Sport prop sold by HobbyKing........
Old Nov 27, 2012, 09:52 PM
Apphoard's Avatar
Joined Mar 2011
Thanks Dramjet I ordered the 8x6's seemed like a good deal.
New Product FMS F4U Corsair 1400mm EPO Warbird jbc Electric Warbirds 9021 Yesterday 07:53 PM
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 89 Oct 03, 2015 04:58 PM
Sold NitroPlanes Airfield RC/FMS 800mm Corsair Reciever Ready $80.00 Shipped FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 6 Aug 14, 2010 03:18 PM
Sold NitroPlanes Airfield RC/FMS 800mm Corsair Reciever Ready $100.00 Shipped FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 1 Aug 09, 2010 11:40 AM
Discussion New ParkZone F4U Corsair for FMS/CV ggunners Simulators 5 Oct 16, 2008 10:42 AM
