Old Oct 16, 2011, 07:32 PM
BrettAltea is offline
Find More Posts by BrettAltea
Australia, VIC, Melbourne
Joined Aug 2011
Gee they are tough planes though. My transmitter battery worked loose and it crashed full speed into the ground. This is the second time it has been broken as bad as this.
Broke into a number of pieces however all glued back as good as new. The main problem was the broken engine mount but I took this out and reinforced the back of it with a piece of carbon fibre sheeting. I think it is now as much glue as EPO.
BrettAltea is offline Find More Posts by BrettAltea
Old Oct 16, 2011, 10:30 PM
Stuka_99 is offline
Find More Posts by Stuka_99
Callsign: Zulu
Stuka_99's Avatar
Somewhere in the skies!
Joined Feb 2011
Thats one hell of a crash, great job rebuilding it though!
Stuka_99 is offline Find More Posts by Stuka_99
Old Oct 17, 2011, 01:32 AM
Joined Aug 2011
Thanks. I also added a gyro for more stability with wind whilst I was doing the rebuild. Unfortunately when I installed it the ailerons got reversed and I forgot to check it. Short flight but luckily it was a quick repair. Next flight I've promised myself no crashes.
Old Oct 17, 2011, 07:01 AM
Neurothief is offline
Find More Posts by Neurothief
Joined Sep 2011
I'm interested in how you are adding the Gyro, I have one from an Blade CP, and had considered that myself, but really not sure how to go about doing it. Can you elaborate on that please? Pics would be great too, and lastly, would love to hear how it does once you get the ailerons worked out.
Michael
Neurothief is offline Find More Posts by Neurothief
Old Oct 17, 2011, 03:00 PM
Joined Aug 2011
Will do. Maybe try tonight for some pics.
Old Nov 06, 2011, 10:14 AM
djmoose is offline
Find More Posts by djmoose
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
Guys, just wanted to let all of you know that we're giving away a FMS 800mm Corsair KIT in the AllThingsThatFly Podcast November giveaway! (sponsored by snhobbies)
http://allthingsthatfly.com/prize.php
djmoose is offline Find More Posts by djmoose
Old Nov 20, 2011, 10:00 AM
TxToast is offline
Find More Posts by TxToast
Joined Oct 2011
Nitro Planes had the kit on sale for $37.70 so I grabbed one.
Built it out with the following...
Motor $12.95 1820 kv optima 300
http://www.hobbypartz.com/75m31-opti...08-1820kv.html
Servo's $28 4 x T-Pro MG90 9G metal gear
Receiver Orange RX R610 $5.99
http://www.hobbyking.com/hobbyking/s...Sat_Port_.html
ESC Proton 30A $15
http://www.hobbypartz.com/07e04-proton-30a.html
I've got an APC 7x5 prop on it for the maiden....should be good on both 2S and 3S.
TxToast is offline Find More Posts by TxToast
Old Nov 28, 2011, 11:30 PM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
I've had my corsair 9 months now, and through 2 multiple-piece fights with earth, 5 full speed encounters with tree's and 1 nose dive into a lake, I still LOVE my corsair, she's a tough bird.
Airfield 800mm F4U Corsair (2 min 57 sec)
queadlunnrau is offline Find More Posts by queadlunnrau
Old Nov 29, 2011, 04:37 AM
Stuka_99 is offline
Callsign: Zulu
Stuka_99's Avatar
Joined Feb 2011
Aw man! rebuild time?
Old Nov 29, 2011, 10:58 AM
Luck is my skill
Joined Jun 2009
Naw that crash was months ago, this bird fixes real well.
Glad my GF is an artist, she can match paint real well.
Old Nov 29, 2011, 04:56 PM
inspector5419 is offline
Find More Posts by inspector5419
inspector5419's Avatar
USA, TX, Van Alstyne
Joined Nov 2010
What color blue are you guys using to touch up the paint
I got one on the way sould be here Fri
but the kids are going to put it under the Christmas tree
will be doing some mods to her so I will need to do some touch ups
inspector5419 is offline Find More Posts by inspector5419
Old Nov 29, 2011, 05:41 PM
TxToast is offline
Joined Oct 2011
Just flew mine today for the 1st time (actually 2nd but I was a bit to nose heavy so I only did 1 lap and put her down.
Optima 300 (1820 KV)
30@ proton ESC
nano-tech 850 3S 25C
6 x 4 APC
Flies very nicely with good speed (50-60 mph) and good verticals. Very tight loops and great control throws. I've got Tx dialed down to 70/30 and she still rolls very quickly. Not as stable as my Sky Angel P40 at extremely low speeds but tracks very nicely at about 1/8 throttle on final. Actually makes it a bit easier to land in the sense that it's got a more dependable sink rate then the P40 which glides forever.
If you set nominal power as you transition from your base leg to final you can leave the power alone and fly pitch to the flare with no problem. Cut throttle right as you flare and she settles in perfectly. With the Sky angel birds they will actually tend to climb a bit even at low speeds....leaving you nose up 4 ft off the ground. I actually fly my P40 into about 6 inches and let it settle in the ground effects with no flare at all. When it finally decides its time to land I flare it right as it drops.
Obviously limited flights but a great bird to learn proper landing techniques. I always pick a specific spot for touchdown and on the last flight set power about 70 yds out as I turned on final and landed within a foot or two of my mark with almost no changes in pitch (wind cooperated nicely)....great kit for anyone interested in building out an 800mm warbird.
Old Nov 30, 2011, 10:39 AM
Luck is my skill
Joined Jun 2009
I could not find an exact match, my GF mixed some paint and matched it.
Old Nov 30, 2011, 01:17 PM
Joined Nov 2010
Thanks for getting back to me
I should be able to work it out
Old Nov 30, 2011, 06:07 PM
aracer is offline
Find More Posts by aracer
UK, Hereford and Worcester, Worcester
Joined Feb 2009
Indeed - I've also had multi-piece fights with earth, and whilst mine doesn't look so pretty any more it flies just fine. Yay for electric powered foam planes - somebody who watched the ground jump out in front of my plane whilst it was on full throttle commented that he used to own old-fashioned balsa planes and they'd have just been matchwood after that. I flew again later the same day.
aracer is offline Find More Posts by aracer
New Product FMS F4U Corsair 1400mm EPO Warbird jbc Electric Warbirds 9184 Yesterday 08:13 PM
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 89 Oct 03, 2015 04:58 PM
Sold NitroPlanes Airfield RC/FMS 800mm Corsair Reciever Ready $80.00 Shipped Mikey 68 Aircraft - Electric - Airplanes (FS/W) 6 Aug 14, 2010 03:18 PM
Sold NitroPlanes Airfield RC/FMS 800mm Corsair Reciever Ready $100.00 Shipped Mikey 68 Aircraft - Electric - Airplanes (FS/W) 1 Aug 09, 2010 11:40 AM
Discussion New ParkZone F4U Corsair for FMS/CV ggunners Simulators 5 Oct 16, 2008 10:42 AM
