Old Sep 06, 2010, 06:49 PM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
FMS F4U Mini Corsair
Unboxing the FMS´ F4U Corsair.
Nice little bird. With 3 blade propeller, the scale looks good.
It took me only 5 minutes to put together.
I am planning to power her with a 2S 1200mAh and maiden this weekend.
Tartago is offline Find More Posts by Tartago
Old Sep 06, 2010, 07:11 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Looks nice.
freechip is offline Find More Posts by freechip
Old Sep 07, 2010, 12:17 AM
jumboman is offline
Find More Posts by jumboman
California
Joined Aug 2010
You got the landing gear on wrong
jumboman is offline Find More Posts by jumboman
Old Sep 07, 2010, 01:42 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
You're right. I already fixed it but not in the pics.
Old Sep 07, 2010, 08:35 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Some history
This plane belonged to the VC-3 squadron aboard the USS Princeton, CV-37, during the Korean war.
In the same squadron was the only ace in night fighter and in a propeller plane Guy P. Bordelon, with the plane number 21.
This plane should have a 4 blade prop and a radar on the starboard wing to be accurate with the 5N model.
Old Sep 07, 2010, 10:45 PM
Mikey 68 is offline
Find More Posts by Mikey 68
Joined Sep 2004
By the way I had one of those and flew it without the gear and had to add nose weight for it to cg It flys great not very fast. Later on I did replace the motor and flew it on 3 cells
Mikey 68 is offline Find More Posts by Mikey 68
Old Sep 08, 2010, 07:22 AM
rimripper is offline
Find More Posts by rimripper
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
How much did the plane cost?
rimripper is offline Find More Posts by rimripper
Old Sep 08, 2010, 10:19 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Around 90 bucks.
Old Sep 12, 2010, 01:50 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Twits: Where did you put the CG?
Old Sep 27, 2010, 05:55 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Mini Corsair maiden
First flight: I used a Align High-Power 40C 7.4V 1900mAh for power. CG as per manual. The plane took off but was uncontrollable and crased hard on the paved runway. Only damage was the 3 blade prop lost 1 blade and minor scratches.
Second flight: This time with a Turnigy 30C 11.1v 1000mAh and a 2 blade 7x5 master airscrew prop. The plane took off easily and flew a bit jumpy. There was gentle crosswind. The plane is very fast. It was not easy to get a proper slope for landing and ended in some bushes without damage.
Third flight was similar. this is a quite fast plane and you need fast fingers during final approach and landing. I think it is better to hand launch w/o wheels and belly land on grass.
iWhen it is flying it is easy to spot, I was worried about the dark color, but the bent wing is visible at all times (almost).
I liked it.
Old Sep 27, 2010, 09:02 PM
oldtoys1961 is offline
Find More Posts by oldtoys1961
Nashville TN.
Joined May 2010
Nice looking Corsair. I had the Airfield 800mm BF-109 but it met with disaster due to my lack of experience. I also had a P-40 kit and stuck it in the tree so many times I tossed it out after chronic weight gain from hot glue. They are tough I have to say that. Now that I got more stick time and crashing less, I wouldn't mind trying that brand again. The detail is good and tough.
oldtoys1961 is offline Find More Posts by oldtoys1961
Old Sep 28, 2010, 01:24 AM
Rudi is online now
Find More Posts by Rudi
Rudi's Avatar
Österreich, Oberösterreich, Laakirchen
Joined Jan 2001
Nice bird,but you mounted the gear wrong. The wheel should look to the outside.
Rudi
Rudi is online now Find More Posts by Rudi
Old Sep 28, 2010, 03:20 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
That looks alot like the Nitroplanes one my buddy has. but the cowl is different.
http://www.nitroplanes.com/gl601-f4u-brushless.html
Melnic is offline Find More Posts by Melnic
Old Sep 28, 2010, 06:27 PM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
They have the same problem with the gears than my first pictures! LOL
Old Oct 17, 2010, 02:33 PM
boler79 is offline
Find More Posts by boler79
Joined Oct 2010
How much weight did you use and where was the cg?
boler79 is offline Find More Posts by boler79
New Product FMS F4U Corsair 1400mm EPO Warbird jbc Electric Warbirds 9207 Sep 27, 2016 11:25 PM
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 89 Oct 03, 2015 04:58 PM
Sold NitroPlanes Airfield RC/FMS 800mm Corsair Reciever Ready $80.00 Shipped Mikey 68 Aircraft - Electric - Airplanes (FS/W) 6 Aug 14, 2010 03:18 PM
Sold NitroPlanes Airfield RC/FMS 800mm Corsair Reciever Ready $100.00 Shipped Mikey 68 Aircraft - Electric - Airplanes (FS/W) 1 Aug 09, 2010 11:40 AM
Discussion New ParkZone F4U Corsair for FMS/CV ggunners Simulators 5 Oct 16, 2008 10:42 AM
